03-04-2010 06:14 AM - edited 03-15-2019 09:38 PM
I want to configure clocking on a router with this configuration:
QUEEN#show inventory
NAME: "2651XM chassis", DESCR: "2651XM chassis"
PID: C2651XM-2FE , VID: 2.0, SN: JAE08083B32
NAME: "Enhanced High Density Voice Network Module", DESCR: "Enhanced High Density Voice Network Module"
PID: NM-HD-2VE= , VID: V , SN: FOC08440BH5
NAME: "One port E1 voice interface daughtercard", DESCR: "One port E1 voice interface daughtercard"
PID: VWIC-1MFT-E1= , VID: 1.0, SN: 34128133
PID: VWIC-1MFT-E1= , VID: 1.0, SN: 32513251
But I have this error:
QUEEN(config)#network-clock-participate slot 1
% ERROR: "network-clock-participate slot 1" is not
% appropriate under the current router hardware configuration.
Does any one know why this error occurs?
QUEEN#show ver
Cisco IOS Software, C2600 Software (C2600-ADVIPSERVICESK9-M), Version 12.4(25b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 12-Aug-09 10:59 by prod_rel_team
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
QUEEN uptime is 13 minutes
System returned to ROM by reload at 18:26:18 MSK Sun Feb 28 2010
System restarted at 18:25:42 MSK Sun Feb 28 2010
System image file is "flash:c2600-advipservicesk9-mz.124-25b.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 2651XM (MPC860P) processor (revision 2.0) with 125986K/5086K bytes of memory.
Processor board ID JAE08083B32
M860 processor: part number 5, mask 2
2 FastEthernet interfaces
32 Serial interfaces
2 Channelized E1/PRI ports
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
03-04-2010 06:26 AM
Granted I have not messed around with a 2600 in quite some time, but I didn't see any PVDMs in your "show inventory" output. Do you have PVDMs (carrier cards for DSP resources) installed in the router? If not, then that may lead to the error you are seeing.
HTH.
Bill
03-04-2010 07:15 AM
As I understand PVDMs NM-HD2-VE allready has a PVDM on board (equal to PVDM2-48 ???), any I have created pri-group on each controller, and I think this means that PVDMs resources are available. Anyway thank you for yor reply
