Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
NM-HDV2-2T1/E1 Clocking - CRC Errors
We have a NM-HDV2-2T1/E1 in a 2821 router. We have PRI's from a provider connected to both interfaces. We're seeing a few CRC errors on both interfaces. Currently, we have "no network-clock-participate" with both interfaces set to clock source line. We are planning to set the card to "network-clock-participate" and then "network-clock-select" on the first T1 interface. Then, setting the first T1 interface to clock source line and the second to clock source internal. Is this correct?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: NM-HDV2-2T1/E1 Clocking - CRC Errors
Leave default of clock source line for both interfaces. Set network-clock-select with a decreasing priority of your choice.
Note, you don't need the NM-HDV2 in a 2821. You can host the PVDM2 directly on motherboard, and the VWIC in the slots.
Great, thanks. Turns out we had spare NM-HDV2-2T1/E1's but no VWIC's. I made the change and will keep an eye on the interface errors. I'll mark this one as solved.
You should be able to reclaim the VWIC from the NM simply pulling it out.
Thanks for the nice rating and good luck!
418
