NME-CUE connectivity issue
Hi all,
I want to configure a NME-CUE module. I have the following configuration:
interface GigabitEthernet0/0
description Inside net
ip address 10.85.1.150 255.255.0.0
ip helper-address 10.85.1.11
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex auto
speed auto
no cdp enable
no mop enabled
h323-gateway voip interface
interface Integrated-Service-Engine1/0
ip unnumbered GigabitEthernet0/0
service-module ip address 10.85.1.157 255.255.0.0
service-module ip default-gateway 10.85.1.150
no keepalive
ip forward-protocol nd
ip route 10.0.0.0 255.0.0.0 10.85.1.223
ip route 10.85.1.157 255.255.255.255 Integrated-Service-Engine1/0
ip route 10.161.0.0 255.255.0.0 10.85.1.223
ip route 89.200.209.14 255.255.255.255 217.153.77.113 name Starnet
ip route 172.19.20.0 255.255.255.0 Tunnel99
ip route 172.21.85.1 255.255.255.255 10.85.1.223 name VPN
ip route 217.119.64.62 255.255.255.255 217.153.77.113 name ETEL
ip route 217.119.66.231 255.255.255.255 217.153.77.113 name Etel
the output from the sh ip route command in the service-module:
10.85.0.0 0.0.0.0 255.255.0.0 eth0
0.0.0.0 10.85.1.150 0.0.0.0 eth0
Problem
- I can ping the Service module from the gateway
- I cannot ping the Service module from a device that is in the same VLAN is as the gateway and CUE module..
Does anybody had a similar situation? This is kinda weard, as I have configured simular setups multiple times without any problems..
Thanks in advance,
Kind regards,
Green
Re: NME-CUE connectivity issue
Not sure if you already tried booting up the CUE and change use internal interface to extenral or viceversa.
Silver
Tell us what the host IP configuration is please?
The other thing you can do is issue debug ip icmp packet on the gateway. Do that with some caution - if it's live device think about the impact carefully.
Ajaz
189
