NME-CUE reboot
pbogaerts
I'm new with cme and cue, abd i have a problem with cue, after running yhe wizard I have tried to connect me to the cli but the sysrem is always rebooying (see in att yhe message that i have) CUE version is 3.2.1
6 Replies 6
pemelend
Level 4
Level 4
Use Boothelper to reinstall the CUE image. You can find the instructions on this link.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_2/installation/guide_/boothelp32.html
Thanks pemelend, it was the bundle with ivr, do i need also too reinstall ivr ?
u r welcome.
The boothelper will erase everything on CUE's hard drive including the IVR files and then it will upload the files from the .zip.
The IVR samples can be downloaded from this link:
http://www.cisco.com/cgi-bin/tablebuild.pl/cue-322-ivr-samples
regards
jconi
Level 3
Level 3
I've exactly the same problem with 2 different NME-CUE modules.
Did you find the problem?
jp
You should be able to reinstall these using the boothelper, you have to change boot options to boot from a tftp server, then installation would follow via ftp.
That is what I did, I reïnstalled usingb the boothelper, and after the problem was solved
