No Audio from Unity when using Dial-Peer 103...?
I have what I believe to be a transcoding issue and need your feedback or tips. An inbound PSTN call to a DN at a remote site rings the IP phone using my 103 voip dial-peer which points to the subscriber on my network. If the phone is not answered and the call gets transferred to Unity, I just get silence. If I shutdown 103 and force the inbound calls to use 104 and process through the publisher Unity works just fine. Below are the two dial-peer configs and the codec statement:
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
dial-peer voice 103 voip
description VPN_TO_CCM
destination-pattern 58..
progress_ind setup enable 1
progress_ind progress enable 1
voice-class codec 1
session target ipv4:145.10.144.10
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 104 voip
preference 1
voice-class codec 1
session target ipv4:145.14.10.10
no vad
Any thoughts as to why it would work while going through the pub and not the sub? Thanks.
Hall of Fame Super Red
Re: No Audio from Unity when using Dial-Peer 103...?
Hi Ryan,
I am sure your on the right track here with the Transcoding issue. I am curious about one setting in 104 that is not in 103;
**preference 1**
Let us know,
Rob
Check your TSP versions on Unity. If you just updated this, there is a possibility that the TSPs do not recognize what you are trying to do. Also check to ensure Unity is properly configured for this as well.
114
