Community Member
No Audio in between PSTN Router and HQ/Branch1
Hi.
Could some one please help...i am not able to figure out what i am missing here resulting in no audio in between my PSTN router and HQ site...
I have attached the configurations which may be helpful in understanding...In addition to this, please note i have single 3560 SW which i am using for both sites...in short, Phone rings and after call is connected, there is no audio at all...tried both ways.
In case, if some one can share their PSTN configuration running in their home lab, it will be great.
Thanks in advance.
Mandeep
Mandeep
Hall of Fame Super Gold
Re: No Audio in between PSTN Router and HQ/Branch1
Is this a study lab that you're doing ?
Community Member
Sorry for the delay..was out. Thanks for looking into it.
yes it is a study lab where i am using single switch(3560) for all 3 sites(HQ/SB & SC).
can't hear any audio inbetween...PSTN and any site.....PSTN also shares the same switch.
it's a terrible pain...please help, if possible. Thanks again.
Mandeep
Is this a issue only with HQ site phones ???
What is the call flow ??? HQ IP Phone ---- CUCM ----- H323 GW --------PSTN (ISDN PRI) ???
can you share the below debugs output for a test call from HQ IP phone to 911 number on PSTN ?
debug isdn q931
debug cch323 h225
debug cch323 h245
debug h225 asn1
debug h245 asn1
Also make sure that your GW is able to ping phone IP address...
Piyush
Community Member
Hello there,
Thanks for looking into it. it happened to be my birthday week so couldn't reply earlier than this...
i have all the debug outputs one-by-one as asked from Site-B (H323 Gateway)...to make case study more clear.
it's a simple setup like lab. HQ(MGCP), SB(H323) and SC(CME).......all calling works perfectly fine..
if i call from HQ to SB/SC----i can hear audio it's perfect
if i call from SB to HQ/SC----i can hear audio it's perfect
if i call from SC to HQ/SB----i can hear audio it's perfect
Only when from any of the 3 site(s) i call PSTN any number...there is dead silence.
when i check codec stuff ...it says G711u-law ....i mean may be something i have done wrong...i suspect PSTN is the culprit...
Answer to your questions:
issue with all 3 site phones when they call PSTN numbers
From site-B call flow is quite normal...H323 gw registered to call-manager..route pattern on CUCM alongwith dial-peers on gateway...calls ring perfectly fine...
from Site-B gateway i was able to ping the SB phone ip address...yes
complete configuration for SB(H323 GW) and PSTN is there..if that helps. please let me know if anymore information required...
Thanks in advance..
_________________________________________________________________________________________________
SB#u all
All possible debugging has been turned off
SB#
SB#deb isd q93
debug isdn q931 is              ON.
SB#
*Sep  9 18:33:47.538: ISDN Se0/3/0:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x1, Calling num 9723033002
*Sep  9 18:33:47.538: ISDN Se0/3/0:23 Q931: Sending SETUP  callref = 0x008F callID = 0x8010 switch = primary-ni interface = User
*Sep  9 18:33:47.538: ISDN Se0/3/0:23 Q931: TX -> SETUP pd = 8  callref = 0x008F
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98383
                Exclusive, Channel 3
        Display i = 'SB PH 2'
        Calling Party Number i = 0x0181, '9723033002'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0x81, '911'
*Sep  9 18:33:47.570: ISDN Se0/3/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x808F
*Sep  9 18:33:47.578: ISDN Se0/3/0:23 Q931: RX <- ALERTING pd = 8  callref = 0x808F
        Progress Ind i = 0x8188 - In-band info or appropriate now available
*Sep  9 18:33:48.898: ISDN Se0/3/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x008F
        Cause i = 0x8090 - Normal call clearing
*Sep  9 18:33:48.910: ISDN Se0/3/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x808F
*Sep  9 18:33:48.914: ISDN Se0/3/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x008F
SB#
SB#
SB#u all
SB#
SB#
SB#deb cch323 h225
H225 State Machine tracing is enabled
SB#
*Sep  9 18:34:24.426: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type SETUPIND_CHOSEN
*Sep  9 18:34:24.426: //-1/xxxxxxxxxxxx/H323/setup_ind: Entry
*Sep  9 18:34:24.426: //33/00D75D661100/H323/setup_ind: callingNumber[3002] calledNumber[911]
*Sep  9 18:34:24.426: //33/00D75D661100/H323/setup_ind: ---- calling IE present
*Sep  9 18:34:24.426: //33/00D75D661100/H323/setup_ind: ====== PI = 0
*Sep  9 18:34:24.426: //33/00D75D661100/H323/setup_ind: Receive: infoXCap 0
*Sep  9 18:34:24.426: //33/00D75D661100/H323/setup_ind: Receive: infoXCap ccb 0
setup_ind: is_overlap = 0, info_complete = 0
*Sep  9 18:34:24.426: //33/00D75D661100/H323/setup_ind: Call Manager detected
*Sep  9 18:34:24.426: //33/00D75D661100/H323/cch323_h225_receiver: SETUPIND_CHOSEN: src address = 156.26.102.2; dest address = 142.100.64.21
*Sep  9 18:34:24.426: //33/00D75D661100/H323/run_h225_sm: Received event H225_EV_SETUP_IND while at state H225_IDLE
*Sep  9 18:34:24.430: //33/00D75D661100/H323/common_idle_setupInd_hdlr: full match is found
*Sep  9 18:34:24.430: //33/00D75D661100/H323/cch323_h225_set_new_state: Changing from H225_IDLE state to H225_SETUP state
*Sep  9 18:34:24.430: //33/00D75D661100/H323/cch323_create_incoming_callinfo_block: peer 474A1454, voice_peer_tag 2000, ccb: 4B71486C
*Sep  9 18:34:24.430: //33/00D75D661100/H323/cch323_create_incoming_callinfo_block: Calling Party is CCM
*Sep  9 18:34:24.430: //33/00D75D661100/H323/cch323_h225_handle_deferred_ind: UnBuffering deferred indications
*Sep  9 18:34:24.446: //33/00D75D661100/H323/run_h225_sm: Received event H225_EV_CALLPROC while at state H225_SETUP
*Sep  9 18:34:24.446: //33/00D75D661100/H323/cch323_h225_set_new_state: Changing from H225_SETUP state to H225_CALLPROC state
*Sep  9 18:34:24.446: //33/00D75D661100/H323/delay_h245_transport_address: CCM-ITS compatibility delay transport address for callid[21]
*Sep  9 18:34:24.446: //33/00D75D661100/H323/generic_send_callproc: ====== PI = 0
*Sep  9 18:34:24.482: //33/00D75D661100/H323/run_h225_sm: Received event H225_EV_ALERT while at state H225_CALLPROC
*Sep  9 18:34:24.482: //33/00D75D661100/H323/cch323_h225_set_new_state: Changing from H225_CALLPROC state to H225_ALERT state
*Sep  9 18:34:24.482: //33/00D75D661100/H323/delay_h245_transport_address: CCM-ITS compatibility delay transport address for callid[21]
*Sep  9 18:34:24.482: //33/00D75D661100/H323/generic_send_alert: ====== PI = 8
*Sep  9 18:34:24.482: //33/00D75D661100/H323/generic_send_alert: get ALERT displayInfo
*Sep  9 18:34:24.758: //33/00D75D661100/H323/run_h225_sm: Received event H225_EV_H245_SUCCESS while at state H225_ALERT
*Sep  9 18:34:25.298: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type RELEASEIND_CHOSEN
*Sep  9 18:34:25.298: //33/00D75D661100/H323/release_ind: Disconnect cause 16 location code 0
*Sep  9 18:34:25.298: //33/00D75D661100/H323/cch323_h225_receiver: RELEASEIND_CHOSEN: src address = 156.26.102.2; dest address = 142.100.64.21
*Sep  9 18:34:25.298: //33/00D75D661100/H323/run_h225_sm: Received event H225_EV_RELEASE_IND while at state H225_ALERT
*Sep  9 18:34:25.306: //33/00D75D661100/H323/run_h225_sm: Received event H225_EV_RELEASE while at state H225_ALERT
*Sep  9 18:34:25.310: //33/00D75D661100/H323/cch323_h225_send_release: Cause = 16; Location = 0
*Sep  9 18:34:25.310: //33/00D75D661100/H323/cch323_h225_send_release: h225TerminateRequest: src address = -1675991550; dest address = 142.100.64.21
*Sep  9 18:34:25.310: //33/00D75D661100/H323/cch323_h225_set_new_state: Changing from H225_ALERT state to H225_IDLE state
SB#
SB#
SB#u all
SB#
SB#
SB#deb cch323 h245
H245 State Machine tracing is enabled
SB#
SB#
SB#
SB#
*Sep  9 18:34:50.242: //35/0020DD751200/H323/cch323_send_event_to_h245_connection_sm: Changing to new event H245_LISTEN_REQ_EVENT
*Sep  9 18:34:50.242: //35/0020DD751200/H323/cch323_h245_connection_sm: H245_LISTEN: Received event H245_LISTEN_REQ_EVENT while at H245_NONE state
*Sep  9 18:34:50.246: //35/0020DD751200/H323/cch323_h245_set_new_state: Changing from H245_NONE state to H245_WAITING state
*Sep  9 18:34:50.358: //35/0020DD751200/H323/cch323_h245_channel_established_ind: Using fd=4 to send msgs
*Sep  9 18:34:50.358: //35/0020DD751200/H323/cch323_send_event_to_h245_connection_sm: Changing to new event H245_ESTABLISHED_EVENT
*Sep  9 18:34:50.358: //35/0020DD751200/H323/cch323_h245_connection_sm: H245_LISTEN: Received event H245_ESTABLISHED_EVENT while at H245_WAITING state
*Sep  9 18:34:50.358: //35/0020DD751200/H323/cch323_h245_set_new_state: Changing from H245_WAITING state to H245_CONNECTED state
*Sep  9 18:34:50.362: //35/0020DD751200/H323/run_h245_iwf_sm: received IWF_EV_H245_CONNECTED while at state IWF_IDLE
*Sep  9 18:34:50.362: //35/0020DD751200/H323/h245_iwf_set_new_state: changing from IWF_IDLE state to IWF_AWAIT_CAP_MSD_RESP state
*Sep  9 18:34:50.362: //35/0020DD751200/H323/cch323_run_h245_cap_out_sm: Received H245_EVENT_CAP_REQ while at state IDLE
*Sep  9 18:34:50.362: //35/0020DD751200/H323/h245_cap_out_set_new_state: changing from IDLE state to AWAITING_RESPONSE state
*Sep  9 18:34:50.362: //35/0020DD751200/H323/cch323_run_h245_ms_sm: Received event H245_EVENT_MSD while at state H245_MS_NONE
*Sep  9 18:34:50.362: //35/0020DD751200/H323/cch323_run_h245_ms_sm: Sent MSD Request
*Sep  9 18:34:50.362: //35/0020DD751200/H323/h245_ms_set_new_state: Changing from H245_MS_NONE state to H245_MS_OUTGOING_WAIT state
*Sep  9 18:34:50.410: //35/0020DD751200/H323/cch323_run_h245_cap_in_sm: Received H245_EVENT_CAP_IND while at state IDLE
*Sep  9 18:34:50.410: //35/0020DD751200/H323/h245_cap_in_set_new_state: changing from IDLE state to AWAITING_RESPONSE state
*Sep  9 18:34:50.410: //35/0020DD751200/H323/run_h245_iwf_sm: received IWF_EV_CAP_IND while at state IWF_AWAIT_CAP_MSD_RESP
*Sep  9 18:34:50.410: //35/0020DD751200/H323/h245_handle_cap_ind: TCS received from remote end. Setting h245 status flag H245_CAP_REQUEST_RCVD
*Sep  9 18:34:50.410: //35/0020DD751200/H323/cch323_run_h245_cap_in_sm: Received H245_EVENT_CAP_RESP while at state AWAITING_RESPONSE
*Sep  9 18:34:50.410: //35/0020DD751200/H323/h245_cap_in_set_new_state: changing from AWAITING_RESPONSE state to IDLE state
*Sep  9 18:34:50.414: //35/0020DD751200/H323/cch323_run_h245_cap_out_sm: Received H245_EVENT_CAP_CFM while at state AWAITING_RESPONSE
*Sep  9 18:34:50.414: //35/0020DD751200/H323/h245_cap_out_set_new_state: changing from AWAITING_RESPONSE state to IDLE state
*Sep  9 18:34:50.414: //35/0020DD751200/H323/run_h245_iwf_sm: received IWF_EV_CAP_CFM while at state IWF_AWAIT_CAP_MSD_RESP
*Sep  9 18:34:50.414: //35/0020DD751200/H323/h245_iwf_set_new_state: changing from IWF_AWAIT_CAP_MSD_RESP state to IWF_AWAIT_MSD_RESP state
*Sep  9 18:34:50.426: //35/0020DD751200/H323/cch323_run_h245_ms_sm: Received event H245_EVENT_MS_CFM while at state H245_MS_OUTGOING_WAIT
*Sep  9 18:34:50.430: //35/0020DD751200/H323/cch323_run_h245_ms_sm: MS_Determine_indication to Appl: Sent MSD ACK! MS determine status=master
*Sep  9 18:34:50.430: //35/0020DD751200/H323/h245_ms_set_new_state: Changing from H245_MS_OUTGOING_WAIT state to H245_MS_NONE state
*Sep  9 18:34:50.430: //35/0020DD751200/H323/run_h245_iwf_sm: received IWF_EV_MSD_CFM while at state IWF_AWAIT_MSD_RESP
*Sep  9 18:34:50.430: //35/0020DD751200/H323/h245_iwf_set_new_state: changing from IWF_AWAIT_MSD_RESP state to IWF_ACTIVE state
*Sep  9 18:34:50.430: //35/0020DD751200/H323/run_h245_iwf_sm: received IWF_EV_START_OLC while at state IWF_OLC_IDLE
*Sep  9 18:34:50.430: //35/0020DD751200/H323/h245_olc_out_sm: Received H245_EV_OLC_EST_REQ while at state H245_OLC_OUT_STATE_IDLE
*Sep  9 18:34:50.430: //35/0020DD751200/H323/h245_olc_out_set_new_state: Changing from H245_OLC_OUT_STATE_IDLE state to H245_OLC_OUT_STATE_AWAIT_EST state
*Sep  9 18:34:50.430: //35/0020DD751200/H323/cch323_open_logical_channel: OLC using g711ulaw
*Sep  9 18:34:50.430: //35/0020DD751200/H323/h245_iwf_set_new_state: changing from IWF_OLC_IDLE state to IWF_OLC_AWAIT_EST_CFM state
*Sep  9 18:34:50.446: //35/0020DD751200/H323/h245_olc_in_sm: Received H245_EV_OLC_IND while at state H245_OLC_IN_STATE_IDLE
*Sep  9 18:34:50.446: //35/0020DD751200/H323/h245_olc_in_set_new_state: Changing from H245_OLC_IN_STATE_IDLE state to H245_OLC_IN_STATE_AWAIT_EST state
*Sep  9 18:34:50.446: //35/0020DD751200/H323/run_h245_iwf_sm: received IWF_EV_OLC_EST_IND while at state IWF_OLC_AWAIT_EST_CFM
*Sep  9 18:34:50.450: //35/0020DD751200/H323/h245_olc_in_sm: Received H245_EV_OLC_EST_RESP while at state H245_OLC_IN_STATE_AWAIT_EST
*Sep  9 18:34:50.450: //35/0020DD751200/H323/h245_olc_in_set_new_state: Changing from H245_OLC_IN_STATE_AWAIT_EST state to H245_OLC_IN_STATE_ESTABLISHED state
*Sep  9 18:34:50.450: //35/0020DD751200/H323/h245_iwf_set_new_state: changing from IWF_OLC_AWAIT_EST_CFM state to IWF_OLC_INDONE_AWAIT_EST_CFM state
*Sep  9 18:34:50.558: //35/0020DD751200/H323/h245_olc_out_sm: Received H245_EV_OLC_CFM while at state H245_OLC_OUT_STATE_AWAIT_EST
*Sep  9 18:34:50.558: //35/0020DD751200/H323/h245_olc_out_set_new_state: Changing from H245_OLC_OUT_STATE_AWAIT_EST state to H245_OLC_OUT_STATE_ESTABLISHED state
*Sep  9 18:34:50.558: //35/0020DD751200/H323/run_h245_iwf_sm: received IWF_EV_OLC_EST_CFM while at state IWF_OLC_INDONE_AWAIT_EST_CFM
*Sep  9 18:34:50.558: //35/0020DD751200/H323/h245_iwf_set_new_state: changing from IWF_OLC_INDONE_AWAIT_EST_CFM state to IWF_OLC_DONE state
*Sep  9 18:34:50.558: //35/0020DD751200/H323/run_h245_iwf_sm: received IWF_EV_OLC_DONE while at state IWF_ACTIVE
*Sep  9 18:34:50.794: //35/0020DD751200/H323/h245_olc_in_sm: Received H245_EV_OLC_CLC_IND while at state H245_OLC_IN_STATE_ESTABLISHED
*Sep  9 18:34:50.794: //35/0020DD751200/H323/h245_olc_in_set_new_state: Changing from H245_OLC_IN_STATE_ESTABLISHED state to H245_OLC_IN_STATE_IDLE state
*Sep  9 18:34:50.794: //35/0020DD751200/H323/run_h245_iwf_sm: received IWF_EV_CLC_IND while at state IWF_OLC_DONE
*Sep  9 18:34:50.798: //35/0020DD751200/H323/h245_iwf_set_new_state: changing from IWF_OLC_DONE state to IWF_OLC_OUT_DONE state
*Sep  9 18:34:50.846: //35/0020DD751200/H323/cch323_send_event_to_h245_connection_sm: Changing to new event H245_DISCONNECT_EVENT
*Sep  9 18:34:50.846: //35/0020DD751200/H323/cch323_h245_connection_sm: H245_CONNECT: Received event H245_DISCONNECT_EVENT while at H245_NONE state
*Sep  9 18:34:50.858: //35/0020DD751200/H323/run_h245_iwf_sm: received IWF_EV_H245_DISCONN while at state IWF_ACTIVE
*Sep  9 18:34:50.858: //35/0020DD751200/H323/cch323_send_event_to_h245_connection_sm: Changing to new event H245_DISCONNECT_EVENT
*Sep  9 18:34:50.858: //35/0020DD751200/H323/cch323_h245_connection_sm: H245_CONNECT: Received event H245_DISCONNECT_EVENT while at H245_NONE state
*Sep  9 18:34:50.858: //35/0020DD751200/H323/h245_iwf_set_new_state: changing from IWF_ACTIVE state to IWF_IDLE state
SB#
SB#
SB#
SB#deb h225 asn1
H.225 ASN1 Messages debugging is on
SB#
SB#
SB#
*Sep  9 18:35:23.226: H225.0 INCOMING ENCODE BUFFER::= 20B0060008914A000501401F0053004200200050004800200032000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000022C0B50000120F436973636F43616C6C4D616E61676572003100010100C44080868889CA15911E130018018ECA410200D50D800007008E64401506B8110080868889CA15911E130018018ECA4102010001000100010010A00100140140B50000120D82040020040001030003000103
*Sep  9 18:35:23.226: H225.0 INCOMING PDU ::=
value H323_UserInformation ::=
      h323-uu-pdu
        h323-message-body setup :
          protocolIdentifier { 0 0 8 2250 0 5 }
          sourceAddress
            h323-ID : {"SB PH 2..."}
          sourceInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              productId '436973636F43616C6C4D616E61676572'H
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
          destinationAddress
            dialedDigits : "911"
          activeMC FALSE
          conferenceID '80868889CA15911E130018018ECA4102'H
          conferenceGoal create : NULL
          callType pointToPoint : NULL
          sourceCallSignalAddress ipAddress :
            ip '8E644015'H
            port 1720
          callIdentifier
            guid '80868889CA15911E130018018ECA4102'H
          mediaWaitForConnect FALSE
          canOverlapSend FALSE
          multipleCalls FALSE
          maintainConnection FALSE
        h245Tunneling FALSE
        nonStandardControl
            nonStandardIdentifier h221NonStandard :
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '82040020040001030003000103'H
*Sep  9 18:35:23.234: H225 NONSTD INCOMING ENCODE BUFFER::= 82040020040001030003000103
*Sep  9 18:35:23.234: H225 NONSTD INCOMING PDU ::=
value H323_UU_NonStdInfo ::=
      callMgrParam
        interclusterVersion 3
        enterpriseID {}
*Sep  9 18:35:23.250: //37/808688891300/H323/cch323_send_event_to_h245_connection_sm: Changing to new event H245_LISTEN_REQ_EVENT
*Sep  9 18:35:23.250: //37/808688891300/H323/cch323_h245_connection_sm: H245_LISTEN: Received event H245_LISTEN_REQ_EVENT while at H245_NONE state
*Sep  9 18:35:23.254: //37/808688891300/H323/cch323_h245_set_new_state: Changing from H245_NONE state to H245_WAITING state
*Sep  9 18:35:23.254: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body callProceeding :
          protocolIdentifier { 0 0 8 2250 0 4 }
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
          h245Address ipAddress :
            ip '9C1A6602'H
            port 55591
          callIdentifier
          multipleCalls FALSE
        h245Tunneling FALSE
*Sep  9 18:35:23.258: H225.0 OUTGOING ENCODE BUFFER::= 21C0060008914A00042800B500001240013C050100009C1A6602D927110C110080868889CA15911E130018018ECA41020100010010800100
*Sep  9 18:35:23.290: H225 NONSTD OUTGOING PDU ::=
      version 2
      protoParam qsigNonStdInfo :
        iei 30
        rawMesg '1E0281881C269E8100036774640000001B41434D...'H
*Sep  9 18:35:23.290: H225 NONSTD OUTGOING ENCODE BUFFER::= 60010200011E2C1E0281881C269E8100036774640000001B41434D2C0D0A50524E2C6973646E2A2C2C4E492A2A2A2C0D0A0D0A
*Sep  9 18:35:23.290: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body alerting :
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
            ip '9C1A6602'H
            port 55591
          callIdentifier
          multipleCalls FALSE
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '60010200011E2C1E0281881C269E810003677464...'H
        tunnelledSignallingMessage
          tunnelledProtocolID
            id tunnelledProtocolAlternateID :
              protocolType "gtd"
          messageContent
            '41434D2C0D0A50524E2C6973646E2A2C2C4E492A...'H
          tunnellingRequired NULL
*Sep  9 18:35:23.298: H225.0 OUTGOING ENCODE BUFFER::= 23C0060008914A00042800B500001240013C050100009C1A6602D9271B0C00110080868889CA15911E130018018ECA41020100010010A801003A0140B50000123360010200011E2C1E0281881C269E8100036774640000001B41434D2C0D0A50524E2C6973646E2A2C2C4E492A2A2A2C0D0A0D0A224204677464011B41434D2C0D0A50524E2C6973646E2A2C2C4E492A2A2A2C0D0A0D0A
*Sep  9 18:35:23.386: //37/808688891300/H323/cch323_h245_channel_established_ind: Using fd=4 to send msgs
*Sep  9 18:35:23.386: //37/808688891300/H323/cch323_send_event_to_h245_connection_sm: Changing to new event H245_ESTABLISHED_EVENT
*Sep  9 18:35:23.386: //37/808688891300/H323/cch323_h245_connection_sm: H245_LISTEN: Received event H245_ESTABLISHED_EVENT while at H245_WAITING state
*Sep  9 18:35:23.386: //37/808688891300/H323/cch323_h245_set_new_state: Changing from H245_WAITING state to H245_CONNECTED state
*Sep  9 18:35:23.386: //37/808688891300/H323/run_h245_iwf_sm: received IWF_EV_H245_CONNECTED while at state IWF_IDLE
*Sep  9 18:35:23.386: //37/808688891300/H323/h245_iwf_set_new_state: changing from IWF_IDLE state to IWF_AWAIT_CAP_MSD_RESP state
*Sep  9 18:35:23.386: //37/808688891300/H323/cch323_run_h245_cap_out_sm: Received H245_EVENT_CAP_REQ while at state IDLE
*Sep  9 18:35:23.386: //37/808688891300/H323/h245_cap_out_set_new_state: changing from IDLE state to AWAITING_RESPONSE state
*Sep  9 18:35:23.386: //37/808688891300/H323/cch323_run_h245_ms_sm: Received event H245_EVENT_MSD while at state H245_MS_NONE
*Sep  9 18:35:23.390: //37/808688891300/H323/cch323_run_h245_ms_sm: Sent MSD Request
*Sep  9 18:35:23.390: //37/808688891300/H323/h245_ms_set_new_state: Changing from H245_MS_NONE state to H245_MS_OUTGOING_WAIT state
*Sep  9 18:35:23.434: //37/808688891300/H323/cch323_run_h245_cap_in_sm: Received H245_EVENT_CAP_IND while at state IDLE
*Sep  9 18:35:23.434: //37/808688891300/H323/h245_cap_in_set_new_state: changing from IDLE state to AWAITING_RESPONSE state
*Sep  9 18:35:23.434: //37/808688891300/H323/run_h245_iwf_sm: received IWF_EV_CAP_IND while at state IWF_AWAIT_CAP_MSD_RESP
*Sep  9 18:35:23.434: //37/808688891300/H323/h245_handle_cap_ind: TCS received from remote end. Setting h245 status flag H245_CAP_REQUEST_RCVD
*Sep  9 18:35:23.434: //37/808688891300/H323/cch323_run_h245_cap_in_sm: Received H245_EVENT_CAP_RESP while at state AWAITING_RESPONSE
*Sep  9 18:35:23.434: //37/808688891300/H323/h245_cap_in_set_new_state: changing from AWAITING_RESPONSE state to IDLE state
*Sep  9 18:35:23.438: //37/808688891300/H323/cch323_run_h245_cap_out_sm: Received H245_EVENT_CAP_CFM while at state AWAITING_RESPONSE
*Sep  9 18:35:23.438: //37/808688891300/H323/h245_cap_out_set_new_state: changing from AWAITING_RESPONSE state to IDLE state
*Sep  9 18:35:23.438: //37/808688891300/H323/run_h245_iwf_sm: received IWF_EV_CAP_CFM while at state IWF_AWAIT_CAP_MSD_RESP
*Sep  9 18:35:23.438: //37/808688891300/H323/h245_iwf_set_new_state: changing from IWF_AWAIT_CAP_MSD_RESP state to IWF_AWAIT_MSD_RESP state
*Sep  9 18:35:23.454: //37/808688891300/H323/cch323_run_h245_ms_sm: Received event H245_EVENT_MS_CFM while at state H245_MS_OUTGOING_WAIT
*Sep  9 18:35:23.454: //37/808688891300/H323/cch323_run_h245_ms_sm: MS_Determine_indication to Appl: Sent MSD ACK! MS determine status=master
*Sep  9 18:35:23.454: //37/808688891300/H323/h245_ms_set_new_state: Changing from H245_MS_OUTGOING_WAIT state to H245_MS_NONE state
*Sep  9 18:35:23.454: //37/808688891300/H323/run_h245_iwf_sm: received IWF_EV_MSD_CFM while at state IWF_AWAIT_MSD_RESP
*Sep  9 18:35:23.454: //37/808688891300/H323/h245_iwf_set_new_state: changing from IWF_AWAIT_MSD_RESP state to IWF_ACTIVE state
*Sep  9 18:35:23.454: //37/808688891300/H323/run_h245_iwf_sm: received IWF_EV_START_OLC while at state IWF_OLC_IDLE
*Sep  9 18:35:23.454: //37/808688891300/H323/h245_olc_out_sm: Received H245_EV_OLC_EST_REQ while at state H245_OLC_OUT_STATE_IDLE
*Sep  9 18:35:23.458: //37/808688891300/H323/h245_olc_out_set_new_state: Changing from H245_OLC_OUT_STATE_IDLE state to H245_OLC_OUT_STATE_AWAIT_EST state
*Sep  9 18:35:23.458: //37/808688891300/H323/cch323_open_logical_channel: OLC using g711ulaw
*Sep  9 18:35:23.458: //37/808688891300/H323/h245_iwf_set_new_state: changing from IWF_OLC_IDLE state to IWF_OLC_AWAIT_EST_CFM state
*Sep  9 18:35:23.474: //37/808688891300/H323/h245_olc_in_sm: Received H245_EV_OLC_IND while at state H245_OLC_IN_STATE_IDLE
*Sep  9 18:35:23.474: //37/808688891300/H323/h245_olc_in_set_new_state: Changing from H245_OLC_IN_STATE_IDLE state to H245_OLC_IN_STATE_AWAIT_EST state
*Sep  9 18:35:23.474: //37/808688891300/H323/run_h245_iwf_sm: received IWF_EV_OLC_EST_IND while at state IWF_OLC_AWAIT_EST_CFM
*Sep  9 18:35:23.474: //37/808688891300/H323/h245_olc_in_sm: Received H245_EV_OLC_EST_RESP while at state H245_OLC_IN_STATE_AWAIT_EST
*Sep  9 18:35:23.474: //37/808688891300/H323/h245_olc_in_set_new_state: Changing from H245_OLC_IN_STATE_AWAIT_EST state to H245_OLC_IN_STATE_ESTABLISHED state
*Sep  9 18:35:23.478: //37/808688891300/H323/h245_iwf_set_new_state: changing from IWF_OLC_AWAIT_EST_CFM state to IWF_OLC_INDONE_AWAIT_EST_CFM state
*Sep  9 18:35:23.586: //37/808688891300/H323/h245_olc_out_sm: Received H245_EV_OLC_CFM while at state H245_OLC_OUT_STATE_AWAIT_EST
*Sep  9 18:35:23.590: //37/808688891300/H323/h245_olc_out_set_new_state: Changing from H245_OLC_OUT_STATE_AWAIT_EST state to H245_OLC_OUT_STATE_ESTABLISHED state
*Sep  9 18:35:23.590: //37/808688891300/H323/run_h245_iwf_sm: received IWF_EV_OLC_EST_CFM while at state IWF_OLC_INDONE_AWAIT_EST_CFM
*Sep  9 18:35:23.590: //37/808688891300/H323/h245_iwf_set_new_state: changing from IWF_OLC_INDONE_AWAIT_EST_CFM state to IWF_OLC_DONE state
*Sep  9 18:35:23.590: //37/808688891300/H323/run_h245_iwf_sm: received IWF_EV_OLC_DONE while at state IWF_ACTIVE
*Sep  9 18:35:24.282: //37/808688891300/H323/h245_olc_in_sm: Received H245_EV_OLC_CLC_IND while at state H245_OLC_IN_STATE_ESTABLISHED
*Sep  9 18:35:24.282: //37/808688891300/H323/h245_olc_in_set_new_state: Changing from H245_OLC_IN_STATE_ESTABLISHED state to H245_OLC_IN_STATE_IDLE state
*Sep  9 18:35:24.282: //37/808688891300/H323/run_h245_iwf_sm: received IWF_EV_CLC_IND while at state IWF_OLC_DONE
*Sep  9 18:35:24.282: //37/808688891300/H323/h245_iwf_set_new_state: changing from IWF_OLC_DONE state to IWF_OLC_OUT_DONE state
*Sep  9 18:35:24.334: H225.0 INCOMING ENCODE BUFFER::= 2580060008914A00051100110080868889CA15911E130018018ECA410210800100
*Sep  9 18:35:24.334: H225.0 INCOMING PDU ::=
      h323-uu-pdu
        h323-message-body releaseComplete :
          callIdentifier
        h245Tunneling FALSE
*Sep  9 18:35:24.338: //37/808688891300/H323/cch323_send_event_to_h245_connection_sm: Changing to new event H245_DISCONNECT_EVENT
*Sep  9 18:35:24.342: //37/808688891300/H323/cch323_h245_connection_sm: H245_CONNECT: Received event H245_DISCONNECT_EVENT while at H245_NONE state
*Sep  9 18:35:24.350: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
*Sep  9 18:35:24.354: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A00041100110080868889CA15911E130018018ECA410210800100
*Sep  9 18:35:24.358: //37/808688891300/H323/run_h245_iwf_sm: received IWF_EV_H245_DISCONN while at state IWF_ACTIVE
*Sep  9 18:35:24.358: //37/808688891300/H323/cch323_send_event_to_h245_connection_sm: Changing to new event H245_DISCONNECT_EVENT
*Sep  9 18:35:24.358: //37/808688891300/H323/cch323_h245_connection_sm: H245_CONNECT: Received event H245_DISCONNECT_EVENT while at H245_NONE state
*Sep  9 18:35:24.358: //37/808688891300/H323/h245_iwf_set_new_state: changing from IWF_ACTIVE state to IWF_IDLE state
SB#
SB#u all
SB#
SB#
SB#deb h245 asn1
H.245 ASN1 Messages debugging is on
SB#
*Sep  9 18:36:01.722: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= request : terminalCapabilitySet :
      sequenceNumber 1
      protocolIdentifier { 0 0 8 245 0 7 }
      multiplexCapability h2250Capability :
        maximumAudioDelayJitter 20
        receiveMultipointCapability
          multicastCapability FALSE
          multiUniCastConference FALSE
          mediaDistributionCapability
              centralizedControl FALSE
              distributedControl FALSE
              centralizedAudio FALSE
              distributedAudio FALSE
              centralizedVideo FALSE
              distributedVideo FALSE
        transmitMultipointCapability
        receiveAndTransmitMultipointCapability
        mcCapability
          centralizedConferenceMC FALSE
          decentralizedConferenceMC FALSE
        rtcpVideoControlCapability FALSE
        mediaPacketizationCapability
          h261aVideoPacketization FALSE
        logicalChannelSwitchingCapability FALSE
        t120DynamicPortCapability FALSE
      capabilityTable
          capabilityTableEntryNumber 34
          capability receiveRTPAudioTelephonyEventCapability :
            dynamicRTPPayloadType 101
            audioTelephoneEvent "0-16"
          capabilityTableEntryNumber 25
          capability receiveAndTransmitDataApplicationCapability :
            application nonStandard :
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              data '52747044746D6652656C6179'H
            maxBitRate 0
          capabilityTableEntryNumber 31
          capability receiveUserInputCapability : hookflash : NULL
          capabilityTableEntryNumber 30
          capability receiveUserInputCapability : dtmf : NULL
          capabilityTableEntryNumber 27
          capability receiveUserInputCapability : basicString : NULL
          capabilityTableEntryNumber 6
          capability receiveAudioCapability : g729AnnexA : 2
          capabilityTableEntryNumber 5
          capability receiveAudioCapability : g729 : 2
          capability receiveAudioCapability : g711Ulaw64k : 20
      capabilityDescriptors
          capabilityDescriptorNumber 1
          simultaneousCapabilities
              3,
              5,
              6
              34,
              30,
              27,
              25
              31
*Sep  9 18:36:01.734: H245 MSC OUTGOING ENCODE BUFFER::= 027001060008817500078013800014000100000100000100000CC001000100078000218A061404302D31368000184810B50000120C52747044746D6652656C6179000080001E83015080001D83014080001A83011080000522C00180000422800180000220C0130080010202000200040005030021001D001A001800001E
*Sep  9 18:36:01.734: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= request : masterSlaveDetermination :
      terminalType 60
      statusDeterminationNumber 7084
*Sep  9 18:36:01.734: H245 MSC OUTGOING ENCODE BUFFER::= 01003C401BAC
*Sep  9 18:36:01.782: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 86
*Sep  9 18:36:01.782: H245 MSC INCOMING ENCODE BUFFER::= 0270010600088175000A801380003C000100000100000100000CC00100010004800000860A0000070008824301030180000120C03B80000285014080000385011080002B85015000800002000001010002000300002B
*Sep  9 18:36:01.782: H245 MSC INCOMING PDU ::=
      sequenceNumber 1
      protocolIdentifier { 0 0 8 245 0 10 }
        maximumAudioDelayJitter 60
        mcCapability
      capabilityTable
          capabilityTableEntryNumber 1
          capability genericControlCapability :
            capabilityIdentifier standard : { 0 0 8 323 1 3 1 }
          capability receiveAudioCapability : g711Ulaw64k : 60
          capability receiveAndTransmitUserInputCapability : dtmf : NULL
          capabilityTableEntryNumber 4
          capability receiveAndTransmitUserInputCapability : basicString : NULL
          capabilityTableEntryNumber 44
          capability receiveAndTransmitUserInputCapability : hookflash : NULL
          capabilityDescriptorNumber 0
*Sep  9 18:36:01.794: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
*Sep  9 18:36:01.794: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
*Sep  9 18:36:01.794: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= response : terminalCapabilitySetAck :
      sequenceNumber 1
*Sep  9 18:36:01.798: H245 MSC OUTGOING ENCODE BUFFER::= 218001
*Sep  9 18:36:01.798: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 3
*Sep  9 18:36:01.798: H245 MSC INCOMING ENCODE BUFFER::= 218001
*Sep  9 18:36:01.798: H245 MSC INCOMING PDU ::=
      sequenceNumber 1
*Sep  9 18:36:01.798: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
*Sep  9 18:36:01.798: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
*Sep  9 18:36:01.814: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 2
*Sep  9 18:36:01.814: H245 MSC INCOMING ENCODE BUFFER::= 2080
*Sep  9 18:36:01.814: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= response : masterSlaveDeterminationAck :
      decision master : NULL
*Sep  9 18:36:01.814: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
*Sep  9 18:36:01.814: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
*Sep  9 18:36:01.814: H245 MSC OUTGOING PDU ::=
      decision slave : NULL
*Sep  9 18:36:01.814: H245 MSC OUTGOING ENCODE BUFFER::= 20A0
*Sep  9 18:36:01.818: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= request : openLogicalChannel :
      forwardLogicalChannelNumber 1
      forwardLogicalChannelParameters
        dataType audioData : g711Ulaw64k : 20
        multiplexParameters h2250LogicalChannelParameters :
          sessionID 1
          mediaControlChannel unicastAddress : iPAddress :
            network '9C1A6602'H
            tsapIdentifier 18689
          silenceSuppression FALSE
*Sep  9 18:36:01.818: H245 MSC OUTGOING ENCODE BUFFER::= 030000000C6013800B050001009C1A6602490100
*Sep  9 18:36:01.834: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 20
*Sep  9 18:36:01.834: H245 MSC INCOMING ENCODE BUFFER::= 030000000C6013800B050001008E6440150FA100
*Sep  9 18:36:01.834: H245 MSC INCOMING PDU ::=
          sessionID 1
            network '8E644015'H
            tsapIdentifier 4001
*Sep  9 18:36:01.838: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
*Sep  9 18:36:01.838: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
*Sep  9 18:36:01.838: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= response : openLogicalChannelAck :
      forwardMultiplexAckParameters h2250LogicalChannelAckParameters :
        mediaChannel unicastAddress : iPAddress :
          network '9C1A6602'H
          tsapIdentifier 18688
          network '9C1A6602'H
        flowControlToZero FALSE
*Sep  9 18:36:01.842: H245 MSC OUTGOING ENCODE BUFFER::= 22C000000680134C009C1A66024900009C1A6602490103000100
*Sep  9 18:36:01.974: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 23
*Sep  9 18:36:01.974: H245 MSC INCOMING ENCODE BUFFER::= 22C000000480101C00008ECA4102602E008ECA4102602F
*Sep  9 18:36:01.974: H245 MSC INCOMING PDU ::=
        sessionID 1
          network '8ECA4102'H
          tsapIdentifier 24622
          network '8ECA4102'H
          tsapIdentifier 24623
*Sep  9 18:36:01.978: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
*Sep  9 18:36:01.978: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
*Sep  9 18:36:02.494: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 5
*Sep  9 18:36:02.494: H245 MSC INCOMING ENCODE BUFFER::= 0400000000
*Sep  9 18:36:02.494: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= request : closeLogicalChannel :
      source user : NULL
*Sep  9 18:36:02.494: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
*Sep  9 18:36:02.494: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
*Sep  9 18:36:02.494: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= response : closeLogicalChannelAck :
*Sep  9 18:36:02.494: H245 MSC OUTGOING ENCODE BUFFER::= 23800000
*Sep  9 18:36:02.526: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 2
*Sep  9 18:36:02.526: H245 MSC INCOMING ENCODE BUFFER::= 4A40
*Sep  9 18:36:02.526: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= command : endSessionCommand : disconnect : NULL
*Sep  9 18:36:02.526: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
*Sep  9 18:36:02.526: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
*Sep  9 18:36:02.526: H245 MSC OUTGOING PDU ::=
*Sep  9 18:36:02.526: H245 MSC OUTGOING ENCODE BUFFER::= 4A40
SB#
SB#
SB#
SB#
SB#sh run
Building configuration...
Current configuration : 5015 bytes
version 12.4
hostname SB
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
clock timezone CST -6
clock summer-time CDT recurring
network-clock-participate wic 3
network-clock-select 1 T1 0/3/0
dot11 syslog
ip source-route
ip cef
ip dhcp pool DATA
   network 142.202.65.0 255.255.255.0
   option 150 ip 142.100.64.21
   default-router 142.202.65.254 255.255.255.0
no ip domain lookup
ip domain name ccievoice.com
no ipv6 cef
isdn switch-type primary-ni
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h225-notify cid-update
fax protocol cisco
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
  h225 timeout tcp establish 3
  h225 timeout setup 3
voice translation-rule 1
rule 1 /.*\(3...\)/ /\1/
voice translation-rule 10
rule 1 /.*\(3...\)/ /972303\1/ type any unknown plan any isdn
voice translation-rule 11
rule 1 // // type any unknown plan any isdn
voice translation-rule 20
rule 1 /.*\(3...\)/ /303\1/ type any subscriber plan any isdn
voice translation-rule 22
rule 1 // // type any subscriber plan any isdn
voice translation-rule 30
rule 1 /.*\(3...\)/ /972303\1/ type any national plan any isdn
voice translation-rule 33
rule 1 // // type any national plan any isdn
voice translation-rule 40
rule 1 /.*\(3...\)/ /+1972303\1/ type any international plan any isdn
voice translation-rule 44
rule 1 // // type any international plan any isdn
voice translation-profile EMER
translate calling 10
translate called 11
voice translation-profile IN
translate called 1
voice translation-profile INTL
translate calling 40
translate called 44
voice translation-profile NAT
translate calling 30
translate called 33
voice translation-profile SUBS
translate calling 20
translate called 22
voice-card 0
archive
log config
  hidekeys
controller T1 0/3/0
pri-group timeslots 1-3,24
controller T1 0/3/1
interface Loopback0
ip address 142.1.65.254 255.255.255.255
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.302
encapsulation dot1Q 302
ip address 142.102.65.254 255.255.255.0
ip helper-address 142.100.64.21 redundancy 142.100.64.22
interface FastEthernet0/0.402
encapsulation dot1Q 402
ip address 142.202.65.254 255.255.255.0
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
encapsulation frame-relay
interface Serial0/0/0.201 point-to-point
ip address 156.26.102.2 255.255.255.0
frame-relay interface-dlci 201
interface FastEthernet0/2/0
no ip address
shutdown
duplex auto
speed auto
interface Serial0/3/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn outgoing display-ie
isdn outgoing ie redirecting-number
no cdp enable
router ospf 10
log-adjacency-changes
network 0.0.0.0 255.255.255.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
nls resp-timeout 1
cpd cr-id 1
control-plane
voice-port 0/3/0:23
translation-profile incoming IN
dial-peer voice 911 pots
translation-profile outgoing EMER
destination-pattern 911
no digit-strip
port 0/3/0:23
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
dial-peer voice 10 pots
translation-profile outgoing NAT
destination-pattern 91[2-9]..[2-9]......$
port 0/3/0:23
prefix 1
dial-peer voice 13 pots
translation-profile outgoing INTL
destination-pattern 9011T
port 0/3/0:23
prefix 011
dial-peer voice 7 pots
translation-profile outgoing SUBS
destination-pattern 9[2-9]......$
port 0/3/0:23
dial-peer voice 2000 voip
destination-pattern 3...
voice-class codec 1
voice-class h323 1
session target ipv4:142.100.64.22
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 2001 voip
preference 1
voice-class codec 1
voice-class h323 1
session target ipv4:142.100.64.21
no vad
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 142.102.65.254 port 2000
max-dn 10
transfer-pattern .T
voicemail 914082022220
huntstop channel 1
call-forward pattern .T
call-forward busy 914082022220
call-forward noan 914082022220 timeout 20
moh music-on-hold.au
multicast moh 239.1.1.1 port 16384 route 142.102.65.254 142.1.65.254
time-zone 8
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
SB#
access_server>r4
Trying r4 (10.10.10.10, 2001)... Open
MAIN_PSTN>en
MAIN_PSTN#
MAIN_PSTN#
MAIN_PSTN#
MAIN_PSTN#deb isd q93
MAIN_PSTN#
Jul 19 10:35:02.534: ISDN Se0/1:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x0, Calling num 911
Jul 19 10:35:02.538: ISDN Se0/1:23 Q931: Applying typeplan for sw-type 0xD is 0x4 0x1, Called num 3033002
Jul 19 10:35:02.538: ISDN Se0/1:23 Q931: TX -> SETUP pd = 8  callref = 0x0082
                Standard = CCITT
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Progress Ind i = 0x8583 - Origination address is non-ISDN
        Display i = 'Emergenc 911/999'
        Calling Party Number i = 0x0080, '911'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0xC1, '3033002'
                Plan:ISDN, Type:Subscriber(local)
Jul 19 10:35:02.574: ISDN Se0/1:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8082
Jul 19 10:35:05.782: ISDN Se0/1:23 Q931: RX <- ALERTING pd = 8  callref = 0x8082
Jul 19 10:35:05.966: ISDN Se0/1:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x0082
        Cause i = 0x8290 - Normal call clearing
Jul 19 10:35:05.978: ISDN Se0/1:23 Q931: RX <- RELEASE pd = 8  callref = 0x8082
Jul 19 10:35:05.978: ISDN Se0/1:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0082
MAIN_PSTN#
MAIN_PSTN#
MAIN_PSTN#sh run
Current configuration : 9617 bytes
! No configuration change since last restart
version 12.4
hostname MAIN_PSTN
boot-start-marker
boot-end-marker
no aaa new-model
clock summer-time CHT recurring
no network-clock-participate slot 2
network-clock-participate wic 1
network-clock-participate wic 2
voice-card 2
dspfarm
dsp services dspfarm
no local-bypass
ip cef
no ip dhcp use vrf connected
ip dhcp pool IP_PHONES
   network 142.102.67.0 255.255.255.0
   option 150 ip 142.102.67.254
   default-router 142.102.67.254
ip dhcp pool DATA
   network 142.202.67.0 255.255.255.0
   default-router 142.202.67.254
no ip domain lookup
frame-relay switching
voice service voip
h323
  ip circuit max-calls 10
  h225 h245-address on-connect
  no call service stop
  call start slow
sip
voice class codec 1
rule 1 /\(^011\)\(.*\)/ /\2/
rule 2 /\(^1\)\(.*\)/ /\2/
rule 3 /\(^0011\)\(.*\)/ /\2/
rule 4 /\(^001\)\(.*\)/ /\2/
rule 5 /\(^00\)\(.*\)/ /\2/
rule 1 /^408/ /1&/ type any international
rule 2 /^852\(.*\)/ /\1/ type any subscriber
rule 3 /^44\(.*\)/ /\1/ type any international
rule 4 /^972/ /1&/ type any international
rule 1 /^972\(.*\)/ /\1/ type any subscriber
rule 2 /^408/ /&/ type any national
rule 3 /^852/ /&/ type any international
rule 4 /^44/ /&/ type any international
rule 1 /^408\(.*\)/ /\1/ type any subscriber
rule 2 /^972/ /&/ type any national
rule 3 /^44/ /&/ type any international
rule 4 /^852/ /&/ type any international
rule 1 /^900.*/ /&/ type any international plan any isdn
rule 1 /^011\(442030276666\)/ /\1/
rule 2 /^011\(321234567890\)/ /\1/
voice translation-profile BR1
translate calling 3
voice translation-profile BR2
translate calling 2
voice translation-profile GK-UK
translate called 44
voice translation-profile HQ
translate calling 4
voice translation-profile PSTN
translate called 1
archive
log config
  hidekeys
controller T1 0/0
framing esf
clock source internal
linecode b8zs
description to HQ
controller T1 0/1
framing esf
linecode b8zs
description to BR1
controller E1 0/2
pri-group timeslots 1-3,16
description E1 to BR2
controller E1 0/3
interface Loopback1
ip address 157.26.1.100 255.255.255.255
interface Loopback2
ip address 157.26.1.253 255.255.255.255
h323-gateway voip interface
h323-gateway voip id BBGK ipaddr 157.26.1.100 1719
h323-gateway voip h323-id BBGW
h323-gateway voip tech-prefix 01144
h323-gateway voip bind srcaddr 157.26.1.253
no ip address
duplex auto
speed auto
interface FastEthernet0/0.100
encapsulation dot1Q 100
ip address 142.100.64.17 255.255.255.0
interface FastEthernet0/0.157
encapsulation dot1Q 157
ip address 142.102.67.254 255.255.255.0
interface FastEthernet0/0.167
description PSTN SOFT PHONE
encapsulation dot1Q 167
ip address 142.202.67.254 255.255.255.0
interface Serial0/0:23
no ip address
encapsulation hdlc
isdn protocol-emulate network
no cdp enable
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1:23
no ip address
encapsulation hdlc
no cdp enable
interface Serial0/2:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
no cdp enable
interface Serial1/0
description PSTN TO HQ
no ip address
no fair-queue
clock rate 128000
frame-relay intf-type dce
frame-relay route 102 interface Serial1/1 201
frame-relay route 103 interface Serial1/2 301
interface Serial1/1
description PSTN TO BR1
no ip address
clock rate 128000
frame-relay route 201 interface Serial1/0 102
interface Serial1/2
description PSTN TO BR2
no ip address
clock rate 128000
frame-relay route 301 interface Serial1/0 103
interface Serial1/3
no ip address
shutdown
router ospf 1
network 142.0.0.0 0.255.255.255 area 0
network 157.26.1.0 0.0.0.255 area 0
ip http server
tftp-server flash:/phone/7941-7961/apps41.8-3-2-27.sbn alias apps41.8-3-2-27.sbn
tftp-server flash:/phone/7941-7961/cnu41.8-3-2-27.sbn alias cnu41.8-3-2-27.sbn
tftp-server flash:/phone/7941-7961/cvm41sccp.8-3-2-27.sbn alias cvm41sccp.8-3-2-27.sbn
tftp-server flash:/phone/7941-7961/dsp41.8-3-2-27.sbn alias dsp41.8-3-2-27.sbn
tftp-server flash:/phone/7941-7961/jar41sccp.8-3-2-27.sbn alias jar41sccp.8-3-2-27.sbn
tftp-server flash:/phone/7941-7961/SCCP41.8-3-3S.loads alias SCCP41.8-3-3S.loads
tftp-server flash:/phone/7941-7961/term41.default.loads alias term41.default.loads
tftp-server flash:/phone/7941-7961/term61.default.loads alias term61.default.loads
control-plane
voice-port 0/0:23
translation-profile incoming PSTN
translation-profile outgoing HQ
voice-port 0/1:23
translation-profile outgoing BR1
description BR1 9723YYXXXX
voice-port 0/2:15
translation-profile outgoing BR2
direct-inward-dial
dial-peer voice 2002 pots
destination-pattern 2022...
port 0/0:23
forward-digits all
dial-peer voice 972 pots
destination-pattern 3033...
port 0/1:23
forward-digits all
dial-peer voice 4082 pots
destination-pattern 408202....
port 0/0:23
forward-digits all
dial-peer voice 9723 pots
destination-pattern 972303....
port 0/1:23
forward-digits all
dial-peer voice 852 pots
description BR2 852240YXXXX
destination-pattern ^8522404....
port 0/2:15
forward-digits 8
dial-peer voice 2404 pots
destination-pattern 24044...
port 0/2:15
forward-digits 8
dial-peer voice 19723 pots
destination-pattern ^1972303....
port 0/1:23
forward-digits 10
dial-peer voice 300 pots
description HQ 408202XXXX
destination-pattern ^1408202....
port 0/0:23
forward-digits 10
dial-peer voice 9001408 pots
destination-pattern 9001408202....
port 0/0:23
forward-digits 10
dial-peer voice 10150 voip
translation-profile incoming GK-UK
session protocol sipv2
session transport udp
incoming called-number 011.
codec g711ulaw
dial-peer voice 2 voip
voice-class codec 1
dtmf-relay h245-signal h245-alphanumeric
dial-peer voice 1022 voip
dial-peer voice 5555 voip
incoming called-number 011321234567890
dial-peer voice 2502 pots
destination-pattern 20225..
port 0/0:23
forward-digits all
dial-peer voice 6666 voip
incoming called-number 011442030276666
dial-peer voice 4020 voip
shutdown
incoming called-number 01144.
dial-peer terminator *
num-exp 01144........ 911
gateway
timer receive-rtp 1200
gatekeeper
zone local BBGK cisco.com 157.26.1.100
zone remote CUBE ccievoice.com 142.102.64.254 1719 invia BBGK
no shutdown
telephony-service
max-ephones 4
max-dn 20 no-reg
ip source-address 142.102.67.254 port 2000
system message PSTN PHONE(COLLABRATION) ONLY
moh slot0:music-on-hold.au
multicast moh 239.1.1.1 port 2000
web admin system name admin password cisco
create cnf-files version-stamp 7960 Jul 18 2013 19:33:07
ephone-dn  1  dual-line
number 911 secondary 999 no-reg both
label Emergency 911/999
description PSTN phone
name Emergenc 911/999
ephone-dn  2  dual-line
number 4085151111 secondary 5151111 no-reg both
label HQ +1-408-515--1111
name PSTN-HQ-PHONE
ephone-dn  3  dual-line
number 9725252222 secondary 5252222 no-reg both
label SiteB +1-972-525-2222
name PSTN-SITEB-PHONE
ephone-dn  4  dual-line
number 85225353333 secondary 25353333 no-reg both
label SiteC +852-2535-3333
name PSTN-SITEC-PHONE
ephone-dn  5  dual-line
number 442030276666 secondary 011442030276666 no-reg primary
label UK PHN + 44-20-30276666
name UK-PSTN
ephone-dn  6  dual-line
number 011321234567890 secondary 321234567890 no-reg primary
label BLG PHN +32-12-34567890
name BLG-PSTN
ephone  1
device-security-mode none
ephone  2
mac-address 001B.2AC6.A2F4
button  1:1 2:2 3:3 4:4
button  5:5 6:6
ephone  3
mac-address 0016.D499.0E16
button  5:5 6:6
line con 0
line aux 0
line vty 0 4
login
ntp master 1
end
MAIN_PSTN#
Mandeep
Hi.
Can you please send a show voip rtp connections during an active call between the PSTN Gateway and site b.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Community Member
Hello there..
As asked i called from PSTN phone to SB phone..tried looking for the "show voip rtp connections" couldn't see it.
What i felt after looking at the debugs, i can see sessions..so below is the output. may be helpful.
MAIN_PSTN#debug voip rtp session
VOIP RTP All Events debugging is on
MAIN_PSTN#
Jul 19 11:09:15.530: %ISDN-6-DISCONNECT: Interface Serial0/1:0  disconnected from 3033001 , call lasted 116 seconds
MAIN_PSTN#
Jul 19 11:09:33.598: %ISDN-6-CONNECT: Interface Serial0/1:0 is now connected to 3033001 N/A
Jul 19 11:09:39.598: %ISDN-6-CONNECT: Interface Serial0/1:0 is now connected to 3033001 N/A
Jul 19 11:10:19.962: %ISDN-6-DISCONNECT: Interface Serial0/1:0  disconnected from 3033001 , call lasted 46 seconds
Jul 19 11:10:32.946: %ISDN-6-CONNECT: Interface Serial0/1:2 is now connected to 9723033001 N/A
Jul 19 11:10:36.958: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1:2, changed state to up
Jul 19 11:10:38.946: %ISDN-6-CONNECT: Interface Serial0/1:2 is now connected to 9723033001 N/A
MAIN_PSTN#sh voip rtp connections
No active connections found
I strongly believe it's something with the PSTN router config itself causing this trouble.
If there is anything else what i should try to do with it or any more information required, please let me know..Thanks ;-)
Mandeep
Hi.
Can you also send the output of a show voice call status during an active call.
Carlo
In the logs i dont see the call being connected..
Just after 1sec of  H323 Alerting message, I see that  CUCM is sending Release complete to GW which then sends Release to the  PSTN..
      h323-uu-pdu
      h323-uu-pdu
Can you collect some debugs from PSTN as well as from CUCM?
On PSTN collect following debugs:
debug voice ccapi inout
debug isdn q931
Enable both debugs at the same time unlike you collected each debug separatly.
On CUCM collect detailed level trace.. Check this document to collect trace on CUCM:
https://supportforums.cisco.com/docs/DOC-29901
Piyush
Community Member
Hi All,
Thanks for all valuable time and tips....i finally found the resolution to No AUDIO.
i could have provided you more debug outputs like you asked, but i was not feeling convinced to go into that direction....so i tried staring at PSTN config only...before i switched to this toplogy...when i had the other setup, i had a minor difference in pstn config...pasted below resolved it.
voice-card 2
dspfarm
I can hear the audio at last...............it amazing after 7-8 months. Great.
All - Thanks for looking into it.
Mandeep
733
