08-13-2009 12:52 PM - edited 03-15-2019 07:21 PM
This is really crazy - All users are using IPC - each user can talk with other users in different LAN segments, but users within the same LAN segment can not always hear each other.
All users are using IPC on an XP laptop connected to a Cisco AP - 1131. Somtimes I can reset the wireless adapter and it will start to work, other times this has no effect. No Firewalls are configured on the Wireless Adapters of the Dell Laptops.
I am at a loss - any ideas?
CUCMBE Version 7.0
IPC Version 2.1.2
Heath
08-13-2009 01:00 PM
When this happens, can you ping between involved PC's ?
08-13-2009 01:02 PM
Yes - The call is connected and we can ping.
08-13-2009 01:30 PM
Press ? twice on the IPC, will tell you if packets are lost.
Just another way to isolate further.
08-13-2009 01:02 PM
Have you tried to isolate problem? I mean check RX and TX when CIPC call is made, next you can wireshark packets, then check settings on switch, etc...
