No audio issue
Hi All
We have cisco voip environment and sometimes users complain that when day call outside there have no audio. There is no audio on IP Phone and Mobile. Call is going outside via H323 Gateway using ISDN PRI. We can see IP Phone is transmitting packets but it receives nothing.
I have captured the “show call active voice brief” for a particular call. Can anyone explain me the below output little
66A  : 267376380hs.1 +1068 pid:56 Answer 61440 active
dur 00:01:52 tx:0/0 rx:5614/112280
IP 172.16.2.163:20922 rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8
66A  : 267376386hs.1 +1061 pid:66 Originate 1790783589184 active
dur 00:01:52 tx:5615/112300 rx:0/0
Tele 1/0:15 (128705): tx:0/0/0ms g729r8 noise:0 acom:0  i/0:0/0 dBm
No audio issue
take a look at this:
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a00800f6cf8.shtml#topic3-1
Can you take a look at the E1 controller (sho contr e1) and also the D-Channel, represented by Serial interface 1/0:15. Do you see any issues with that?
It's either something bad happening on the network side (packets are not routed), but it's more likely a problem with the telco provider.
G.
No audio issue
Hi Gergely
Thanks a lot for the information. We checked the network side and we didn't find any issue there. We saw packets from IP Phone correctly delivered to Gtaeway.
Does anyone know that problem with DSPs can cause this kind of issue?
Regrads
188
