no audio on inbound pri calls transfered across wan
scenario:
inbound call to gateway1 via PRI circuit. call is answered by attendant, then transferred to remote location. remote ip phone rings, but when remote ip iphone answers call, there is NO AUDIO on either end (dead air). call was normal until transfer.
if call is placed by remote ip phone through gateway1 across wan(same call path, different direction), call has audio in BOTH directions and is normal.
issue is only with inbound calls from gateway1 to remote ip phone.
all routing has been tested and working. seems to be some rtp issue. any help would be great.
gateway1 is a 2821-v using mgcp. point to point t1 and pri interface cards. ip phones are 7940.
Re: no audio on inbound pri calls transfered across wan
These documents will help you to troubleshoot one-way voice issue. In the past, I had used "voice rtp send-recei" to resolve my issue. You might want to doublecheck that H232 is bound to the interface.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080115a52.shtml
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a008009484b.shtml
HTH,
hieu
gateway is using MGCP, not h323. also, does not appear to be only a one-way voice issue, but no voice is heard from either party. only stuff i can find is regarding 'mgcp bind' commands. not really sure what these command would do. thanks!
Can you post the configs of both the local and remote router(without the sensitive info)?
hieu
local 2821 config
Current configuration : 5870 bytes
version 12.4
service password-encryption
boot-start-marker
boot system flash:c2800nm-ipvoicek9-mz.124-11.T.bin
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
clock timezone CST -6
network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip dhcp pool VOICE
ip dhcp pool PCPOOL
no ip domain lookup
isdn switch-type primary-ni
voice-card 0
no dspfarm
controller T1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
class-map match-any AutoQoS-VoIP-RTP-Trust
match ip dscp ef
class-map match-any AutoQoS-VoIP-Control-Trust
match ip dscp cs3
match ip dscp af31
policy-map AutoQoS-Policy-Trust
class AutoQoS-VoIP-RTP-Trust
priority percent 70
class AutoQoS-VoIP-Control-Trust
bandwidth percent 5
class class-default
fair-queue
interface GigabitEthernet0/0
description "VLAN 1"
ip address 192.168.0.253 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
description "VLAN 100"
ip address 10.0.2.254 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/1/0
ip address 10.10.1.1 255.255.255.0
auto qos voip trust
service-policy output AutoQoS-Policy-Trust
ip route 0.0.0.0 0.0.0.0 192.168.0.251
ip route 10.0.3.0 255.255.255.0 10.10.1.2
ip route 192.168.2.0 255.255.255.0 10.10.1.2
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
rmon event 33333 log trap AutoQoS description "AutoQoS SNMP traps for Voice Drops" owner AutoQoS
voice-port 0/0/0:23
voice-port 0/2/0
no echo-cancel enable
timing hookflash-out 500
voice-port 0/2/1
signal groundStart
ccm-manager redundant-host TSWCCM1
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.0.2.200 10.0.2.201
ccm-manager config
mgcp
mgcp call-agent TSWCCM2 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
no mgcp explicit hookstate
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 999020 pots
service mgcpapp
port 0/2/0
dial-peer voice 999021 pots
service mgcpapp
port 0/2/1
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
line con 0
login local
line aux 0
scheduler allocate 20000 1000
end
remote 2610 config(for this scenario only involved in routing, not call endpoint)
version 12.3
service timestamps debug uptime
service timestamps log uptime
hostname 261001
boot-start-marker
boot system flash:c2600-ipvoice-mz.123-8.T4.bin
boot-end-marker
no network-clock-participate slot 1
no network-clock-participate wic 0
voice-card 1
no aaa new-model
ip subnet-zero
ip cef
ip tcp synwait-time 13
ip dhcp pool DATA
ip dhcp pool VOICE
no ftp-server write-enable
isdn switch-type primary-5ess
isdn voice-call-failure 0
voice call send-alert
voice rtp send-recv
ccm-manager fallback-mgcp
ccm-manager mgcp
ccm-manager config
controller T1 1/0
framing esf
linecode b8zs
controller T1 1/1
framing sf
linecode ami
match ip dscp ef
match ip dscp cs3
match ip dscp af31
priority percent 70
bandwidth percent 5
class class-default
fair-queue
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
description VLAN 1
encapsulation dot1Q 1 native
ip address 192.168.2.254 255.255.255.0
interface FastEthernet0/0.100
description VLAN 100
encapsulation dot1Q 100
ip address 10.0.3.254 255.255.255.0
interface Serial0/0
ip address 10.10.1.2 255.255.255.0
auto qos voip trust
interface Serial1/0:23
no ip address
no logging event link-status
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.1.1
no ip http server
snmp-server community public RO
snmp-server enable traps tty
control-plane
rmon alarm 33333 cbQosCMDropBitRate.1059.1061 30 absolute rising-threshold 1 33333 falling-threshold 0 owner AutoQoS
call application alternate DEFAULT
voice-port 1/0:23
echo-cancel coverage 32
mgcp
mgcp sdp simple
mgcp fax t38 inhibit
dial-peer cor custom
dial-peer voice 1 pots
application mgcpapp
destination-pattern 9T
incoming called-number .
direct-inward-dial
port 1/0:23
max-conferences 4
ip source-address 192.168.2.254 port 2000
max-ephones 36
max-dn 144
keepalive 10
default-destination 304
line con 0
line aux 0
end
also, another way to duplicate the problem is to dial into remote router pri transfer to local router across wan, if call is placed on hold, no music on hold is heard by calling party.
426
