12-13-2011 01:18 AM - edited 03-16-2019 08:30 AM
I have got a problem with no audio on calls when calling between 2 CUCM clusters via SIP trunk. It works from Cluster 2 to Cluster 1 but not vice versa. Call get connected (ringing) but after I pick up the call I can't hear anything. There is no firewall between those 2 phones. Thank you for help.
Cluster 1: x.x.x.136
Cluster 2: x.x.x.73
ACME SIP proxy: x.x.x.141
Topology looks like this:
CUCM Cluster 1 -> ACME SIP proxy -> CUCM Cluster 2
SIP trace from ACME SIP proxy (x.x.x.141). Call from Cluster 1 to Cluster 2, !!!! UNSUCESSFULL !!!
Session ID: 0x0CC3B25A6F137040
Call ID: b26a9200-ee51c29d-a246-88b99509@x.x.x.136
Timestamp : 09:00:14.158 2011-12-12
Direction : RX
Remote IP/Port: x.x.x.136/40590
Local IP/Port : x.x.x.141(eth2)/5060
Transport : TCP
INVITE sip:1000@x.x.x.141:5060 SIP/2.0
Date: Mon, 12 Dec 2011 09:00:13 GMT
Call-Info: <sip:x.x.x.136:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
From: <sip:1001@x.x.x.136>;tag=db473620-456f-4d24-9195-d807c3d6ce15-155400543
Allow-Events: presence, kpml
P-Asserted-Identity: <sip:1001@x.x.x.136>
Supported: timer,resource-priority,replaces
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Min-SE: 1800
Remote-Party-ID: <sip:1001@x.x.x.136>;party=calling;screen=yes;privacy=off
Content-Length: 0
User-Agent: Cisco-CUCM7.1
To: <sip:1000@x.x.x.141>
Contact: <sip:1001@x.x.x.136:5060;transport=tcp>
Expires: 180
Call-ID: b26a9200-ee51c29d-a246-88b99509@x.x.x.136
Via: SIP/2.0/TCP x.x.x.136:5060;branch=z9hG4bK239f8a21c237
CSeq: 101 INVITE
Session-Expires: 1800
Max-Forwards: 70
Direction : TX
Remote IP/Port: x.x.x.136/5060
Transport : TCP
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Timestamp : 09:00:14.248 2011-12-12
Direction : TX
Remote IP/Port: x.x.x.73/5060
Transport : UDP
INVITE sip:1000@x.x.x.73:5060 SIP/2.0
From: <sip:1001@x.x.x.141>;tag=8db99509-13c4-4ee5c29e-7994b765-85cfca
CSeq: 1 INVITE
Via: SIP/2.0/UDP x.x.x.141:5060;branch=z9hG4bK-a07c95-4ee5c29e-7994b765-7e85353b
Supported: timer,resource-priority,replaces,X-cisco-srtp-fallback,Geolocation
Max-Forwards: 70
Allow: INVITE,OPTIONS,INFO,BYE,CANCEL,ACK,PRACK,UPDATE,REFER,SUBSCRIBE,NOTIFY
Allow-Events: presence,kpml
Min-SE: 180
Expires: 180
Session-Expires: 7200;refresher=uas
Contact: <sip:1001@x.x.x.141:5060;maddr=x.x.x.141;transport=udp>
Content-Length: 0
Timestamp : 09:00:14.299 2011-12-12
Direction : RX
Transport : UDP
SIP/2.0 100 Trying
Content-Length: 0
CSeq: 1 INVITE
Timestamp : 09:00:14.303 2011-12-12
Direction : RX
Transport : UDP
SIP/2.0 180 Ringing
P-Asserted-Identity: <sip:1000@x.x.x.73>
Remote-Party-ID: <sip:1000@x.x.x.73>;party=called;screen=yes;privacy=off
Content-Length: 0
To: <sip:1000@x.x.x.141>;tag=b198b18d-c724-4969-b786-ed1c32fbf1b6-22806454
Contact: <sip:1000@x.x.x.73:5060>
CSeq: 1 INVITE
Timestamp : 09:00:14.304 2011-12-12
Direction : TX
Transport : TCP
SIP/2.0 180 Ringing
To: <sip:1000@x.x.x.141>;tag=8db99509-13c4-4ee5c29e-7994b79d-6c07ea17
CSeq: 101 INVITE
Supported: X-cisco-srtp-fallback,Geolocation
Contact: <sip:1000@x.x.x.141:5060;maddr=x.x.x.141;transport=tcp>
Content-Length: 0
Timestamp : 09:00:16.704 2011-12-12
Direction : RX
Transport : UDP
SIP/2.0 183 Session Progress
Content-Length: 372
Content-Type: application/sdp
CSeq: 1 INVITE
v=0
o=CiscoSystemsCCM-SIP 2000 1 IN IP4 x.x.x.73
s=SIP Call
c=IN IP4 x.x.35.124
t=0 0
m=audio 4000 RTP/AVP 0 8 116 18 101
a=rtpmap:0 PCMU/8000
a=ptime:20
a=rtpmap:8 PCMA/8000
a=ptime:20
a=rtpmap:116 iLBC/8000
a=ptime:20
a=maxptime:60
a=fmtp:116 mode=20
a=rtpmap:18 G729/8000
a=ptime:20
a=sendonly
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
Direction : TX
Transport : TCP
CSeq: 101 INVITE
Content-Length: 372
v=0
s=SIP Call
c=IN IP4 x.x.35.124
t=0 0
a=ptime:20
a=ptime:20
a=ptime:20
a=maxptime:60
a=fmtp:116 mode=20
a=ptime:20
a=fmtp:101 0-15
a=sendonly
Direction : RX
Transport : UDP
SIP/2.0 200 OK
P-Asserted-Identity: "Test 2" <sip:1000@x.x.x.73>
Supported: replaces
Remote-Party-ID: "Test 2" <sip:1000@x.x.x.73>;party=called;screen=yes;privacy=off
Content-Length: 372
Require: timer
CSeq: 1 INVITE
v=0
s=SIP Call
c=IN IP4 x.x.35.124
t=0 0
a=ptime:20
a=ptime:20
a=ptime:20
a=maxptime:60
a=fmtp:116 mode=20
a=ptime:20
a=sendonly
a=fmtp:101 0-15
Timestamp : 09:00:16.705 2011-12-12
Direction : TX
Transport : TCP
SIP/2.0 200 OK
CSeq: 101 INVITE
Min-SE: 1800
Supported: replaces,X-cisco-srtp-fallback,Geolocation
Require: timer
Content-Length: 372
v=0
s=SIP Call
c=IN IP4 x.x.35.124
t=0 0
a=ptime:20
a=ptime:20
a=ptime:20
a=maxptime:60
a=fmtp:116 mode=20
a=ptime:20
a=fmtp:101 0-15
a=sendonly
Timestamp : 09:00:16.855 2011-12-12
Direction : RX
Transport : TCP
ACK sip:1000@x.x.x.141:5060;maddr=x.x.x.141;transport=tcp SIP/2.0
Content-Length: 247
Via: SIP/2.0/TCP x.x.x.136:5060;branch=z9hG4bK239fc14824f1a
CSeq: 101 ACK
Max-Forwards: 70
v=0
o=CiscoSystemsCCM-SIP 2000 2 IN IP4 x.x.x.136
s=SIP Call
c=IN IP4 x.x.44.241
t=0 0
m=audio 24576 RTP/AVP 18 101
a=ptime:20
a=fmtp:18 annexb=no
a=recvonly
a=fmtp:101 0-15
Timestamp : 09:00:16.856 2011-12-12
Direction : TX
Transport : UDP
ACK sip:1000@x.x.x.73:5060 SIP/2.0
CSeq: 1 ACK
Via: SIP/2.0/UDP x.x.x.141:5060;branch=z9hG4bK-a07cb0-4ee5c2a0-7994c195-730860
Max-Forwards: 70
Content-Length: 247
v=0
s=SIP Call
c=IN IP4 x.x.44.241
t=0 0
a=ptime:20
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=recvonly
Timestamp : 09:00:17.186 2011-12-12
Direction : RX
Transport : UDP
INVITE sip:1001@x.x.x.141:5060;maddr=x.x.x.141;transport=udp SIP/2.0
Date: Mon, 12 Dec 2011 09:00:16 GMT
Call-Info: <sip:x.x.x.73:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
From: <sip:1000@x.x.x.141>;tag=b198b18d-c724-4969-b786-ed1c32fbf1b6-22806454
Min-SE: 1800
Remote-Party-ID: "Test 2" <sip:1000@x.x.x.73>;party=calling;screen=yes;privacy=off
Content-Length: 158
To: <sip:1001@x.x.x.141>;tag=8db99509-13c4-4ee5c29e-7994b765-85cfca
Expires: 180
Via: SIP/2.0/UDP x.x.x.73:5060;branch=z9hG4bK1c1f65bd59dd
CSeq: 101 INVITE
Session-Expires: 7200;refresher=uac
Max-Forwards: 70
v=0
o=CiscoSystemsCCM-SIP 2000 2 IN IP4 x.x.x.73
s=SIP Call
c=IN IP4 x.x.35.124
t=0 0
m=audio 24582 RTP/AVP 18
a=ptime:20
Direction : TX
Transport : UDP
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Timestamp : 09:00:17.187 2011-12-12
Direction : TX
Local IP/Port : x.x.x.141(eth2)/2499
Transport : TCP
INVITE sip:1001@x.x.x.136:5060 SIP/2.0
From: <sip:1000@x.x.x.141>;tag=8db99509-13c4-4ee5c29e-7994b79d-6c07ea17
To: <sip:1001@x.x.x.136>;tag=db473620-456f-4d24-9195-d807c3d6ce15-155400543
CSeq: 1 INVITE
Via: SIP/2.0/TCP x.x.x.141:5060;branch=z9hG4bK-a07cb1-4ee5c2a1-7994c2df-95f93bf
Max-Forwards: 70
Min-SE: 180
Expires: 180
Content-Length: 158
v=0
s=SIP Call
c=IN IP4 x.x.35.124
t=0 0
a=ptime:20
Timestamp : 09:00:17.188 2011-12-12
Direction : RX
Transport : TCP
SIP/2.0 100 Trying
Content-Length: 0
CSeq: 1 INVITE
Timestamp : 09:00:17.387 2011-12-12
Direction : RX
Transport : TCP
SIP/2.0 200 OK
Supported: replaces
Remote-Party-ID: <sip:1001@x.x.x.136>;party=called;screen=yes;privacy=off
Content-Length: 179
Require: timer
CSeq: 1 INVITE
v=0
o=CiscoSystemsCCM-SIP 2000 3 IN IP4 x.x.x.136
s=SIP Call
c=IN IP4 x.x.44.241
t=0 0
m=audio 24578 RTP/AVP 18
a=ptime:20
a=fmtp:18 annexb=no
Timestamp : 09:00:17.388 2011-12-12
Direction : TX
Transport : UDP
SIP/2.0 200 OK
CSeq: 101 INVITE
Min-SE: 1800
Content-Length: 179
v=0
s=SIP Call
c=IN IP4 x.x.44.241
t=0 0
a=ptime:20
a=fmtp:18 annexb=no
Timestamp : 09:00:17.438 2011-12-12
Direction : RX
Transport : UDP
ACK sip:1001@x.x.x.141:5060;maddr=x.x.x.141;transport=udp SIP/2.0
Content-Length: 0
Via: SIP/2.0/UDP x.x.x.73:5060;branch=z9hG4bK1c20452fbba8
CSeq: 101 ACK
Max-Forwards: 70
Timestamp : 09:00:17.439 2011-12-12
Direction : TX
Transport : TCP
ACK sip:1001@x.x.x.136:5060;transport=tcp SIP/2.0
CSeq: 1 ACK
Via: SIP/2.0/TCP x.x.x.141:5060;branch=z9hG4bK-a07cb4-4ee5c2a1-7994c3dc-6b1d8378
Max-Forwards: 70
Content-Length: 0
Timestamp : 09:01:51.358 2011-12-12
Direction : RX
Transport : UDP
BYE sip:1001@x.x.x.141:5060;maddr=x.x.x.141;transport=udp SIP/2.0
Content-Length: 0
Via: SIP/2.0/UDP x.x.x.73:5060;branch=z9hG4bK1c2c96e899c
CSeq: 102 BYE
Max-Forwards: 70
Direction : TX
Transport : UDP
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
Timestamp : 09:01:51.359 2011-12-12
Direction : TX
Transport : TCP
BYE sip:1001@x.x.x.136:5060;transport=tcp SIP/2.0
CSeq: 2 BYE
Via: SIP/2.0/TCP x.x.x.141:5060;branch=z9hG4bK-a08161-4ee5c2ff-799632bc-3b1bc195
Max-Forwards: 70
Content-Length: 0
Timestamp : 09:01:51.362 2011-12-12
Direction : RX
Transport : TCP
SIP/2.0 200 OK
Date: Mon, 12 Dec 2011 09:01:50 GMT
Content-Length: 0
CSeq: 2 BYE
Solved! Go to Solution.
12-15-2011 03:56 AM
It sounds like a codec negotiation issue. Judging from your trace, you plan to use G.729 across or ?
Try to remove G.729 Annex B silence suppresion as a G.729 variant. Go to:
System -> Services -> "Choose any Server" -> Cisco Callmanager
"Strip G.729 Annex B (Silence Suppression) from Capabilities Required Field" and set it to True.
It will automatically get replicated to all nodes in your cluster.
It might help or it might be something else.
12-15-2011 03:56 AM
12-15-2011 05:41 AM
Hello Rasdolav
From the network of the IP Phone registered in cluster 1 to the network of the IP Phone registered on the cluster 2 do you have reachability?
12-15-2011 05:44 AM
the issue is solved now. The problem was with the "Silence Suppression" suppression as David descripted. Once we turned it off it started to work. Thank you!
12-02-2014 06:43 AM
David,
Thanks very much for this solution, not even Cisco TAC has been able to pinpoint this issue until I decided to look at the traces and troubleshoot this myself.
Kudos for you!
Wilson
