no busy tone and no Announcement Messages from pstn/gsm gateway
make an outbond call from sccp ip phone to pstn/gsm phone using SIP gateway (cisco 2800) no busy tone and Announcement Messages received, Continuously bell are ringing please help
Silver
Re: no busy tone and no Announcement Messages from pstn/gsm gate
Configure the Cisco IOS Software global configuration command, voice call convert-discpi-to-prog.
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a0080111b58.shtml
Hi there
I have the same issue and the cimmand you suggest does not solve the problem.
Victor
Hi Victor,
I have the same issue. Even with this commad, the call is still ringing and I don't receive the announcement from the operator in case of wrong number.
Did you solve this issue?
Thank you.
Yorick
Try the command "voice call convert-discpi-to-prog" in global configuration as stated by an earlier reply. At first I was not putting the command right but now it is ok.
Victor
Hi Victor,
I tried this command but I cannot see any difference with or without it.
Which IOS version do you use? I tried with 12.4(9)T7 and 12.4(15)T8.
Thank you.
Yorick Petey
My IOS was 12.4(15)T7
Victor
Victor,
Can you send me your running-config?
It's strange, I am using 12.4(15)T8 which is only a Maintenance release, so it should work.
What is your CUCM version? I am using the new 6.1.3.
Thank you very much.
Yorick
try adding this command:
voice rtp send-recv
http://www.cisco.com/en/US/docs/ios/12_3t/voice/command/reference/vrht_v2_ps5207_TSD_Products_Command_Reference_Chapter.html#wp1191272
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hi java,
This command is already here. Please find attached my current configuration.
(removed some infos for privacy)
Yorick
Sorry, forgot the attachment.
383
