no busy tone when dialing an engaged number (and no VM)
I have the following problem on a call manager 5.1.1 install:
when a user dials an engaged number it does not recieve a busy tone.
setup:
call manager 5.1.1
GW=2821 IOS: c2800nm-ipvoicek9-mz.124-10.bin
I do get the busy signal/disconnect coming into the gateway:
VGW-Cisco2821-MEL#
*Nov 14 04:35:35: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 9010
*Nov 14 04:35:35: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Called num 96141466
*Nov 14 04:35:35: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x244B
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98382
Exclusive, Channel 2
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0181, '9010'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x80, '96xxxxxx'
Plan:Unknown, Type:Unknown
*Nov 14 04:35:35: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xA44B
*Nov 14 04:35:36: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0xA44B
Cause i = 0x8291 - User busy
Progress Ind i = 0x8288 - In-band info or appropriate now available
*Nov 14 04:35:36: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0xA3FD
*Nov 14 04:35:41: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x244B
*Nov 14 04:35:41: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xA44B
the strange thing is that when I add a new phone to the network it works, but when I log a user in (extension mobility) and log him out again, after that on the same phone, I get no busy signal anymore. It just dials and disconnects.
I have set the progress indicators on the appropriate dial-peers:
dial-peer voice 11 pots
description ** Mobile telephone dial-peer **
destination-pattern 004........
progress_ind setup enable 3<------------
progress_ind disconnect enable 8<-------
direct-inward-dial
port 0/0/0:15
forward-digits 10
anyone seen this before? does this have to do with network locale (set to Australia)??
Please remember to rate useful posts, by clicking on the stars below.
172
