Community Member
No Called Party ID on CME connected to ISDN2e
Greetings, i have a UC520 connected to an ISDN2e connection and dont appear to be getting caller id presented for inbound calls.
I have enabled the following debug and cant see the calling number being presented by the carrier.
"debug voice dialpeer inout"
Snippet:
002670: Aug 28 08:58:38.988: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=509, Voice-Interface=0x865BD57C,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
002671: Aug 28 08:58:38.988: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=10
002672: Aug 28 08:58:38.988: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=509, Voice-Interface=0x0,
Peer Info Type=DIALPEER_INFO_FAX
002673: Aug 28 08:58:38.988: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=NO_MATCH(-1) After All Match Rules Attempt
002674: Aug 28 08:58:38.988: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=509, Peer Info Type=DIALPEER_INFO_SPEECH
002675: Aug 28 08:58:38.988: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=509
002676: Aug 28 08:58:38.988: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
002677: Aug 28 08:58:38.988: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=20027
002678: Aug 28 08:58:38.992: //-1/CFD8C44B8039/DPM/dpMatchPeersCore:
002679: Aug 28 08:58:38.992: //-1/CFD8C44B8039/DPM/dpMatchPeersCore:
002680: Aug 28 08:58:38.992: //-1/CFD8C44B8039/DPM/dpMatchPeersCore:
002681: Aug 28 08:58:38.992: //-1/CFD8C44B8039/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Can i ask if this is normal behavior for ISDN2e circuits?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: No Called Party ID on CME connected to ISDN2e
It can be confirmed, no calling number is present, and you should complain to telco.
If their asnwer is "all Ok", show them the trace above.
Please take "debug isdn q931". Do not enable any othet debug.
Community Member
This is a call from my mobile to extension 509. The call was disconnected before being answered.
I do have an incomming dial peer configured to strip the "642" from the beginning of the called number to match the internal extension number.
002847: Aug 28 10:00:00.728: ISDN BR0/2/0 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x8A
Exclusive, B2
Called Party Number i = 0x81, '642509'
Plan:ISDN, Type:Unknown
002848: Aug 28 10:00:00.740: ISDN BR0/2/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x81
Channel ID i = 0x8A
Exclusive, B2
002849: Aug 28 10:00:00.764: ISDN BR0/2/0 Q931: TX -> ALERTING pd = 8 callref = 0x81
Progress Ind i = 0x8188 - In-band info or appropriate now available
002851: Aug 28 10:00:05.152: ISDN BR0/2/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x4B
Cause i = 0x8090 - Normal call clearing
002852: Aug 28 10:00:05.308: ISDN BR0/2/0 Q931: RX <- RELEASE pd = 8 callref = 0xCB
002853: Aug 28 10:00:05.308: ISDN BR0/2/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x4B
002854: Aug 28 10:00:07.092: ISDN BR0/2/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x01
002855: Aug 28 10:00:07.096: ISDN BR0/2/0 Q931: TX -> RELEASE pd = 8 callref = 0x81
002856: Aug 28 10:00:07.148: ISDN BR0/2/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x01
This is a call from my mobile to extension 509. The call was answered then i ended the call after 3 seconds.
002857: Aug 28 10:02:47.580: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Standard = CCITT
Channel ID i = 0x89
Exclusive, B1
002858: Aug 28 10:02:47.596: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x81
Channel ID i = 0x89
Exclusive, B1
002859: Aug 28 10:02:47.620: ISDN BR0/1/0 Q931: TX -> ALERTING pd = 8 callref = 0x81
fh-nwk-uc520#
002860: Aug 28 10:02:49.920: ISDN BR0/1/0 Q931: TX -> CONNECT pd = 8 callref = 0x81
Channel ID i = 0x89
Exclusive, B1
002861: Aug 28 10:02:49.980: ISDN BR0/1/0 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x01
fh-nwk-uc520#
002862: Aug 28 10:02:49.980: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to N/A N/A
fh-nwk-uc520#
002863: Aug 28 10:02:53.532: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x01
Progress Ind i = 0x8288 - In-band info or appropriate now available
002864: Aug 28 10:02:53.532: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to N/A N/A
002865: Aug 28 10:02:53.532: %ISDN-6-CONNECT: Interface BRI0/1/1:1 is now connected to N/A N/A
002866: Aug 28 10:02:53.532: %ISDN-6-CONNECT: Interface BRI0/2/0:1 is now connected to N/A N/A
002867: Aug 28 10:02:53.532: %ISDN-6-CONNECT: Interface BRI0/2/1:1 is now connected to N/A N/A
002868: Aug 28 10:02:53.532: %ISDN-6-DISCONNECT: Interface BRI0/1/0:1 disconnected from unknown , call lasted 3 seconds
fh-nwk-uc520#
002869: Aug 28 10:02:53.560: ISDN BR0/1/0 Q931: TX -> RELEASE pd = 8 callref = 0x81
002870: Aug 28 10:02:53.604: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x01
Community Member
Thank you for your time, glad im not going mad!
You're welcome, please remember to rate useful posts with the scrollbox below.
219
