Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
no called party info on isdn q931
hi,
I have the following problem, there is no called Party Info in the ISDN debug, therefore the call could not be connectd correctly. The call will be connected but to the NULL number. I think this i why you need at least .T for incoming called number at the POTS dial peer. Is this a Cable and Wireless, which is the provider, problem? Or do I have done anything wrong.
*Aug 28 15:02:54.187: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0005
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Progress Ind i = 0x8A81 - Call not end-to-end ISDN, may have in-band info
Calling Party Number i = 0x0083, '07970132009'
Plan:Unknown, Type:Unknown
*Aug 28 15:02:54.199: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8005
Progress Ind i = 0x8188 - In-band info or appropriate now available
*Aug 28 15:02:54.199: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x8005
*Aug 28 15:02:54.315: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x0005
*Aug 28 15:02:54.315: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected to 07970132009 N/A
*Aug 28 15:03:00.315: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected to 07970132009 N/A
*Aug 28 15:03:03.595: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x0005
Cause i = 0x8290 - Normal call clearing
Display i = '*AA*CLEARED#'
*Aug 28 15:03:03.599: %ISDN-6-DISCONNECT: Interface Serial0/0/0:0 disconnected from 07970132009 , call lasted 9 seconds
*Aug 28 15:03:03.599: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x8005
*Aug 28 15:03:03.615: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0005
cheers
1 REPLY
Silver
Re: no called party info on isdn q931
During call establishment the call have entered through a Non-Isdn equipment. In other words, It seems that your isdn call could be travelling through another circuit. So whenever the call path is not end to end isdn, we will see this message during the call setup.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121newft/121limit/121x/121xi/121xi_3/dth323pi.htm#16373
126
