No Caller ID on H323 PRI
Hello all,
I am having problems with CUCM not displaing any caller ID information. For all calls, I only see "External Call" and "Uknown Number".
I am running CUCM 6.1.4.2000-2. My gateway is an 2811 running H323 on flash:c2800nm-spservicesk9-mz.123-8.T6.bin.
Here is a debug. I don't see any calling party information??
VG-2811#
.Nov 21 21:49:28.952: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8  callref = 0x11D4
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Progress Ind i = 0x8283 - Origination address is non-ISDN
        Called Party Number i = 0x80, '5959'
                Plan:Unknown, Type:Unknown
.Nov 21 21:49:28.964: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x91D4
.Nov 21 21:49:29.104: ISDN Se0/0/0:23 Q931: TX -> ALERTING pd = 8  callref = 0x91D4
        Progress Ind i = 0x8188 - In-band info or appropriate now available
.Nov 21 21:49:31.180: ISDN Se0/0/0:23 Q931: TX -> CONNECT pd = 8  callref = 0x91D4
.Nov 21 21:49:31.248: ISDN Se0/0/0:23 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x11D4
.Nov 21 21:49:37.248: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected to unknown
.Nov 21 21:49:40.784: %ISDN-6-DISCONNECT: Interface Serial0/0/0:0  disconnected from unknown , call lasted 9 seconds
.Nov 21 21:49:40.788: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x91D4
        Cause i = 0x8090 - Normal call clearing
.Nov 21 21:49:40.948: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x11D4
.Nov 21 21:49:40.948: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x91D4
Below is the config:
version 12.3
hostname VG-2811
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
clock timezone CDT -5
network-clock-participate wic 0
no network-clock-participate aim 0
no network-clock-participate aim 1
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 10.10.3.1 10.10.3.50
ip dhcp excluded-address 10.10.3.250 10.10.3.254
ip dhcp pool IP-Phones
   network 10.10.3.0 255.255.255.0
   option 150 ip 10.10.1.3
   default-router 10.10.3.1
   dns-server 10.10.1.250
ip domain name yourdomain.com
no ftp-server write-enable
isdn switch-type primary-ni
voice-card 0
dspfarm
dsp services dspfarm
voice call send-alert
voice call carrier capacity active
voice rtp send-recv
voice service voip
h323
controller T1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-24
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$
ip address 10.10.3.1 255.255.255.0
ip route-cache flow
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.10.3.1
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
isdn incoming-voice voice
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.3.254
ip route 192.168.5.0 255.255.255.0 10.10.1.10
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
snmp-server enable traps tty
control-plane
voice-port 0/0/0:23
input gain -4
output attenuation 4
echo-cancel coverage 32
voice-port 0/1/0
description OUTGOING FAX
voice-port 0/1/1
description GERRIES FAX
voice-port 0/1/2
description CARDINAL MODEM
voice-port 0/1/3
description MEGAN FAX
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
dial-peer voice 1 pots
preference 1
destination-pattern .T
progress_ind setup enable 3
progress_ind progress enable 1
incoming called-number .
direct-inward-dial
port 0/0/0:23
forward-digits all
dial-peer voice 2000 voip
destination-pattern 2...
session target ipv4:10.10.1.3
dtmf-relay h245-alphanumeric
codec g711ulaw
ip qos dscp cs5 media
no vad
dial-peer voice 5959 voip
destination-pattern 5959
codec g711ulaw
no vad
dial-peer voice 2099 pots
destination-pattern 2099
incoming called-number 3582099
port 0/1/0
forward-digits 0
dial-peer voice 2016 pots
destination-pattern 2016
incoming called-number 3582016
port 0/1/1
forward-digits 0
dial-peer voice 2098 pots
destination-pattern 2098
incoming called-number 3582098
port 0/1/2
forward-digits 0
dial-peer voice 2018 pots
destination-pattern 2018
incoming called-number 3582018
port 0/1/3
forward-digits 0
call-manager-fallback
max-conferences 8
limit-dn 7910 1
limit-dn 7935 1
limit-dn 7940 2
limit-dn 7960 4
ip source-address 10.10.3.1 port 2000
max-ephones 24
max-dn 48
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
ntp clock-period 17180025
end
VG-2811#
Hall of Fame Super Silver
Looks like the carrier is not sending it to you, have you checked with your service provider if they are sending it to you?
Chris
I haven't called them yet. Is this usually an extra service? Why do you think it's this way to begin with? Also, what should I ask for when i call them up?
Thanks Chris!
what to ask to service provider?
some service provider charge for the caller id facility. tell them that you are not reciving the caller id. inform them that the isdn set up from service provider is only sending called number and not calling number.
324
