NO CallForwardAll when using OverlapSending
Have a 0.X route pattern using OverlapSending. Everything works OK for PSTN calls.
But when trying to CFwdALL to a PSTN destination is impossible, the diverted number is accepted straight away after 2nd digits.
1 ACCEPTED SOLUTION
Re: NO CallForwardAll when using OverlapSending
to overcome this, you need to configure an additional route pattern with a wildcard character, such as "0.!" and put this in a separate partition. Create a additional CSS and assign this on the line CallForward-CSS.
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_configuration_example09186a008012f948.shtml
regards
mehmet
1 REPLY
regards
mehmet
93
