No CLI or web access to Suscriber 8.6.1
A customer has a CUCM version 8.6.1 cluster with 1 Publisher and 1 suscriber. In this moment, they can't access to the suscriber by CLI nor web. When they tried to access directly, they enter user and password but they are asked again to enter the login, we have already check that user/pass are correct.  I tried to access using SSH but after enter user/password the session is closed. The last message I have is:
/usr/local/platform/bin/cliscript.sh: Too many open files in system
The replication is also broken and all the phones are connected to the Published. Do you have any idea what happens? I've never seen this error before.
Many thanks,
Leire
Is this on VMWare or on
Is this on VMWare or on hardware?  Do you have access to the console?
It might need to be rebooted.
Hi Brian, It's hardware and
Hi Brian,
It's hardware and using console happens the same...We haven't tried to reboot it because I prefered to know what the error could mean.
The CLI script is what runs
The CLI script is what runs when you log in.  It's the special Cisco CLI running on top of RHEL.  The script is failing to run due to too many files being opened on the system.  Since you can't really do much to close out the files, a reboot is going to be the only way to resolve.  Also, 8.6.1 is very old and this may be a known issue.  I'd suggest trying to upgrade to the latest 8.6.2 SU as soon as possible to get on a much more stable release.
VIP Purple
try rebooting the server .If
try rebooting the server .If it still does not work, rebuild the server.
regds,
aman
Hi Leire,Did these errors
Hi Leire,
Did these errors appear after an IP address / DNS / hostname change on the cluster, or after a DRS restore?
Are you able to pull any logs from the subscriber via RTMT? If yes, try downloading the app / sys logs to begin with to look for any pointers.
If the server is inaccessible from RTMT as well then a server reboot as suggested by Brian and Aman would be required. Once the server is up and running you should run a database status report from Cisco Unified Reporting tool and check the subscriber health by running the following commands:
utils diagnose test
utils core active list
show status
Manish
50
