Community Member
No conference at remote site via WAN
hello,
i have call Manager 5.1 and the phones that resides at remote site via WAN.
i have used at local sie the G711 codec and via the WAN i have used G729.The problem is that the conference feature is not activated at the remote site.
Regards?
Re: No conference at remote site via WAN
if you're using the SW conference bridge it only supports G711.
If you need to enable conference for the remote users and to keep using G729 add a HW CFB or XCODER
java
if this helps, please rate
www.cisco.com/go/pdi
Community Member
hello,
thanks for reply, but how can i do this.
Please let me know.
Thanks at advance
First of all you need DSP resources in a router to do this, if you have them the following links have the instructions on how to configure any of which i mentioned (HW CFB / XCODER)
Of course that after the configuration you need to arrange the MRGL to have the remote phones use them
Configuring Enhanced Conferencing and Transcoding for Voice Gateway Routers
http://www.cisco.com/en/US/partner/products/ps6441/products_configuration_guide_chapter09186a0080541bf3.html
CallManager and IOS Gateway DSP Farm Configuration Example
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_configuration_example09186a0080334294.shtml
java
171
