No correct time on Cisco 7961G with CCM.
Hello everybody
I have a problem with the telephones Cisco 7961G.
The time shows on the Cisco?s screen is 6 hours ahead from the time on the CallManager.
Version of the Cisco 7961g is SCCP41.80-4SR1S.
CallManager is 4.2(3)sr1.
Any help will be apreciated.
Walter Flores
1 ACCEPTED SOLUTION
Bronze
Re: No correct time on Cisco 7961G with CCM.
You might be running into DST related bugs
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCsh12444
Also check following TCC case
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K56131451
you can try upgrading the phone load to latest 8.2 or later and see if it helps
Bronze
HI NEESSHARM
After I upgraded the telephones Cisco 7961G y Cisco 7911G to the lastest version 8.2.
The show time on the phones are ok
THANK VERY MUCH FOR HELPING
Walter
136
