No dial tone and you cannot make a call
Sometimes a phone doesnot work no dial tone and you cannot call. when I look show voice call summary
it says
50/0/27 .1 - - - EFXS_W_SETUP_ACK_ONHOOK
I can solve that issue after restarting the call manager express... why is that happening ?
Hall of Fame Super Gold
Re: No dial tone and you cannot make a call
Which exact IOS version are you using ?
Was there a fix to this? I have seen this on 12.4(9)T1 and a reboot of the router was the only fix.
This is what we saw:
PORT CODEC VAD VTSP STATE VPM STATE
0/0/0 - - - FXOLS_ONHOOK
0/0/1 - - - FXOLS_ONHOOK
0/0/2 - - - FXOLS_ONHOOK
0/0/3 - - - FXOLS_ONHOOK
0/1/0 - - - FXOLS_ONHOOK
0/1/1 - - - FXOLS_ONHOOK
0/1/2 - - - FXOLS_ONHOOK
0/1/3 - - - FXOLS_ONHOOK
50/0/1 .1 - - - EFXS_ONHOOK
50/0/2 .1 - - - EFXS_ONHOOK
50/0/3 .1 - - - EFXS_ONHOOK
50/0/4 .1 - - - EFXS_ONHOOK
50/0/5 .1 None - S_WAIT_RELEASE_RESP EFXS_W_SETUP_ACK_ONHOOK
50/0/5 .2 - - - EFXS_ONHOOK
50/0/6 .1 - - - EFXS_INIT
50/0/6 .2 - - - EFXS_INIT
50/0/7 .1 - - - EFXS_ONHOOK
50/0/7 .2 - - - EFXS_ONHOOK
50/0/8 .1 None - S_WAIT_RELEASE_RESP EFXS_W_SETUP_ACK_ONHOOK
50/0/8 .2 - - - EFXS_ONHOOK
50/0/9 .1 - - - EFXS_INIT
50/0/9 .2 - - - EFXS_INIT
50/0/10 .1 None - S_WAIT_RELEASE_RESP EFXS_W_SETUP_ACK_ONHOOK
50/0/10 .2 - - - EFXS_ONHOOK
50/0/11 .1 - - - EFXS_ONHOOK
50/0/12 .1 - - - EFXS_ONHOOK
50/0/13 .1 - - - EFXS_INIT
50/0/14 .1 - - - EFXS_INIT
50/0/15 .1 - - - EFXS_INIT
50/0/16 .1 - - - EFXS_ONHOOK
50/0/16 .2 - - - EFXS_ONHOOK
50/0/17 .1 - - - EFXS_ONHOOK
50/0/17 .2 - - - EFXS_ONHOOK
50/0/18 .1 - - - EFXS_ONHOOK
50/0/18 .2 - - - EFXS_ONHOOK
50/0/19 .1 - - - EFXS_INIT
50/0/20 .1 - - - EFXS_ONHOOK
50/0/20 .2 - - - EFXS_ONHOOK
50/0/21 .1 - - - EFXS_INIT
50/0/21 .2 - - - EFXS_INIT
50/0/23 .1 - - - EFXS_ONHOOK
50/0/24 .1 - - - EFXS_ONHOOK
50/0/25 .1 None - S_WAIT_RELEASE_RESP EFXS_W_SETUP_ACK_ONHOOK
50/0/25 .2 - - - EFXS_ONHOOK
50/0/26 .1 None - S_WAIT_RELEASE_RESP EFXS_W_SETUP_ACK_ONHOOK
50/0/26 .2 - - - EFXS_ONHOOK
50/0/27 .1 - - - EFXS_ONHOOK
50/0/27 .2 - - - EFXS_ONHOOK
50/0/30 .1 - - - EFXS_INIT
yep reboot is the only way I could find.
CSCsg74357 Bug Details
Call hung and stuck in active state, ephone-dn is stuck in on hook
Symptom:
Call hung and stuck in active state, so the ephone-dn is stuck in on hook.
Conditions:
intermittent. hard to recreate but happens a few times a week.
Workaround:
reload GW
Problem Description
Some ephone-dn is stuck in on hook
Example:
show ephone-dn summary
Port       Ch  DN STATE  VTSP STATE                    VPM STATE
50/0/10  1   DOWN         S_WAIT_RELEASE_RESP  EFXS_W_SETUP_ACK_ONHOOK
show call active voice brief
 shows the call as active but tx0/0 rx0/0 and there’s no actual call.
Inbound call get busy tone since the line is stucked, outbound call also not get through since it’s a single line.
Bug and workaround
The bug id is CSCsg74357
And right now the corrent version is 12.4.11XJ which is being affected, so we need to do the upgrade to provent it happen again.
While according to the bug, the temperate workaround is to reload router.
May need upgrade ios to 12.4(11)T2 or 12.4.22 and 12.4.24 main line.
1199
