No Dial Tone in Analog Ports
Hi There,
We have configured Analog Ports in VG224 , It showing registered in CUCM, But there is no dial tone in FXS Ports, may i know what could be a problem?
Faxmode is: Fax Relay
Bala
Hall of Fame Super Silver
So, when you connect analog port and you go off hook you do not hear anything? Sounds like cabling issue.
Are you sure your patching/cabling is correct?  Are you using patch panel/110 block/66 block to extend the ampahol connection?
Chris
Hi Chris,
Yes, Cabling is fine, We used 2 more VG224 in the same LAN, It worked, This one is new VG224 which is not gving dial tone.
Bala
Green
Bala,
If you are sure your wiring set up is good.
Have wee look at this link.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00805552e9.shtml
May be a DC voltage level issue
Alex
Regards, Alex. Please rate useful posts.
Are these VG224s all running the exact same version of IOS ?
GTG
Please rate all helpful posts.
850
