no dial tone
The below dial-peer does not give any dial tone to the caller
dial-peer voice 402 voip
 destination-pattern 3XXX
 session protocol sipv2
 session target ipv4:FAXSERVERIP
 dtmf-relay rtp-nte
 codec g711ulaw
 fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
 no vad
Please help
destination-pattern should be
destination-pattern should be 3...
Mohammed Noor
 sorry , i actually mask the
sorry , i actually mask the destination pattern :).the real one is  "destination-pattern 3389"
The real pattern is dial-peer voice 402 voip
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
I used the exact did , so that other than 3389 will fo to call manager
these are the other dial-peers
dial-peer voice 201 voip
 preference 9
 destination-pattern ..
 voice-class codec 1
 session target ipv4:CUCM-2
 incoming called-number .
 dtmf-relay h245-alphanumeric
 no vad
dial-peer voice 202 voip
 preference 10
 voice-class codec 1
 session target ipv4:CUCM-1
 no vad
Hi Supportsib,Can you confirm
Hi Supportsib,
Can you confirm whats the call flow.
Please describe end user experience of this call, When you say no dial tone are you refering to secondary dial tone.
provide me output of show tech voice
For a sample call gather following debug "debug voice ccapi inout" and "debug ccsip messages"
Below is the procedure to capture logs on router buffer
Collecting debugs in Router logging buffer
Router#configuration terminal
Router(config)#no logging console
Router(config)#no logging monitor
Router(config)#ntp update-calendar
Router(config)#ntp server <IP Address of NTP Server>
Router(config)#service timestamps debug datetime msec
Router(config)#logging buffered <buffer size> debugging
Router(config)#service sequence
Router(config)#no logging rate-limit
Router(config)#exit
Router#
Note: NTP configuration is required when the problem involves multiple gateways.
Mohammed Noor
Hi There are two problems  As
As per the dial peer preference  the call should match  the below dial peer instead it matching  the dial-peer2 .
But If I run ‘sh dialplan number 5349 ‘   ,  In the output  it shows ‘VoiceOverIpPeer402’ on top   . But the call never going  to the fax server .
The tone I mentioned is the continuous two tone from the gateway  .
Dial –peer1
 preference 1
 destination-pattern 5...
 session target ipv4:faxserver:5062
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
Dial –peer2
 preference 9
 voice-class codec 1
 session target ipv4:CUCM IP
 no vad
attached log
57
