No Dialtone in SRST Mode ...
In SRST mode Ip phones do not provide dialtone and cannot make internal/external calls. (Phone receive the Call-manager-fallback System Message and are registered properly to the router.)
I'm running CallManager 4.1(3)sr7
Does someone have any idee !?
Kind Regards,
Erik
CONFIG (Version=3.3)
Version 3.3
For on-line documentation please see:
www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/index.htm
ip source-address 172.20.5.24 port 2000
max-ephones 80
max-dn 120
max-conferences 4 gain -6
dspfarm units 0
dspfarm transcode sessions 0
no huntstop
dialplan-pattern 1 223180... extension-length 4 extension-pattern 3...
moh music-on-hold.au
time-format 24
date-format dd-mm-yy
timezone 23 W. Europe Standard/Daylight Time
secondary-dialtone 0
keepalive 30
timeout interdigit 5
timeout busy 10
timeout ringing 180
caller-id name-only: enable
system message primary Local Mode
system message secondary Local Mode
Limit number of DNs per phone:
7910: 36
7935: 36
7936: 36
7940: 36
7960: 36
7970: 36
Log (table parameters):
max-size: 150
retain-timer: 15
transfer-system full-consult
local directory service: enabled.
1 REPLY
Silver
Re: No Dialtone in SRST Mode ...
What IOS version? Which IP Phone is having this problem?
526
