Community Member
no dsp
the scenario is: CCM - CUE - VG - H323 - FXO - PSTN.
I configured the unity express to transfer the call to the PSTN, the issue is that the FXO ports hang and when I issue show voice call status I see no dsp under the Slot/DSP:Ch
any one faced this issue.
Hall of Fame Super Gold
Re: no dsp
Which exact IOS are you using ?
Community Member
Re: no dsp
IOS version: 124-24.T1
appreciate your reply.
Community Member
Re: no dsp
what do you get for
show voice dsp
show inventory
show voice call summary | exclude -
you may want to look at some debugs:
debug vpm signal
debug voice ccapi inout
debug voice dialpeer
Community Member
Re: no dsp
Show voice dsp
----------------------------FLEX VOICE CARD 0 ------------------------------
*DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND : (bad)bad (shut)shutdown (dpend)download pending
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABRT PACK COUNT
*DSP SIGNALING CHANNELS*
C5510 001 01 {flex} 24.3.1 alloc idle 0 0 0/0/0 02 0 47/0
C5510 001 02 {flex} 24.3.1 alloc idle 0 0 0/0/1 06 0 37/0
C5510 001 03 {flex} 24.3.1 alloc idle 0 0 0/0/2 10 0 38/0
C5510 001 04 {flex} 24.3.1 alloc idle 0 0 0/0/3 14 0 50/0
C5510 001 05 {flex} 24.3.1 alloc idle 0 0 0/1/0 02 0 47/0
C5510 001 06 {flex} 24.3.1 alloc idle 0 0 0/1/1 06 0 47/0
C5510 001 07 {flex} 24.3.1 alloc idle 0 0 0/1/2 10 0 38/0
C5510 001 08 {flex} 24.3.1 alloc idle 0 0 0/1/3 14 0 48/0
C5510 001 09 {flex} 24.3.1 alloc idle 0 0 0/2/0 02 0 40/0
C5510 001 10 {flex} 24.3.1 alloc idle 0 0 0/2/1 06 0 44/0
C5510 001 11 {flex} 24.3.1 alloc idle 0 0 0/2/2 10 0 41/0
C5510 001 12 {flex} 24.3.1 alloc idle 0 0 0/2/3 14 0 37/0
C5510 001 13 {flex} 24.3.1 alloc idle 0 0 0/3/0 02 0 37/0
C5510 001 14 {flex} 24.3.1 alloc idle 0 0 0/3/1 06 0 37/0
C5510 001 15 {flex} 24.3.1 alloc idle 0 0 0/3/2 10 0 203/0
C5510 001 16 {flex} 24.3.1 alloc idle 0 0 0/3/3 14 0 191/0
------------------------END OF FLEX VOICE CARD 0 ----------------------------
show inventory
NAME: "2821 chassis", DESCR: "2821 chassis"
PID: CISCO2821 , VID: V04 , SN: FCZ114774X5
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 0", DES
CR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO , VID: V03 , SN: FOC13110F5A
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 1", DES
PID: VIC2-4FXO , VID: V01 , SN: FOC10380SE3
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 2", DES
PID: VIC2-4FXO , VID: V03 , SN: FOC13110FAF
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 3", DES
PID: VIC2-4FXO , VID: V01 , SN: FOC11311GEE
NAME: "PVDMII DSP SIMM with one DSP on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with one
DSP"
PID: PVDM2-16 , VID: V01 , SN: FOC10310HGJ
NAME: "NM-CUE-EC on Slot 1", DESCR: "NM-CUE-EC"
PID: NM-CUE-EC , VID: V03, SN: FOC10354M08
NAME: "40GB IDE Disc Daughter Card on Slot 1 SubSlot 0", DESCR: "40GB IDE Disc Daughter Ca
rd"
PID: , VID: , SN: FOC10374CPT
I tried all debugs I didn't see any issue.
Community Member
Re: no dsp
Please let me know did u find any fix for this issue.
i am also facing same problem with FXO lines
Thanks & regards
Community Member
Re: no dsp
I am also having this problem. Any resolutions?
Community Member
no dsp
Hi Cisco,
May we know what resolution do we fix this issue? Is it a bug issue?
Thank you,
RJ
Purple
no dsp
Community Member
no dsp
Hi Aman,
Thanks for the link, however, there is an error. May we know if there any workarounds to resolve this issue? We have already upgraded the IOS of the router but the issue occurred again.
RJ
Purple
no dsp
Hi Ralph,
Please provide the output of command show voice dsp group all to check if any dsp is failing.
regds,
aman
606
