No dsps found either locally or globally
Ive started having this problem out of no where....
Cisco 2801 with pvdm-8 and a VIC2-FXO.
I had 5 dsp resources allocated to transcoding and everything was working fine. Calls to the PSTN worked and transcoding worked.
i started having trouble with making calls to the PSTN reciving this error:
Feb 14 06:16:18.666: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
I noticed that the "in use" light on my FXO port was lit up, and stayed lit up after removing the cable. IOS reported the port was in use.
I rebooted the router and although the port is in dorm idle state, the problem still exists.
The only way I can fix it is by reducing the "maximum sessions" on the transcoding profile to 4 or less.
Does anyone know what may be wrong?
And can you shed some light as to why only a max 5 sessions are available with 2 x FXO when I have a PVDM-8?
CCME-2#show voice dsp group all
DSP groups on slot 0:
dsp 1:
State: UP, firmware: 8.4.0
Max signal/voice channel: 8/8
Max credits: 240
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 10, reserved credits: 0
Signaling channels allocated: 2
Voice channels allocated: 0
Credits used: 0
Group: FLEX_GROUP_XCODE, complexity: MEDIUM
Shared credits: 0, reserved credits: 150
Transcoding channels allocated: 0
Credits used: 0
3 DSP resource allocation failure
CCME-2#show voice dsp signaling
edsp 001 01 g729r8 p 0.1 IDLE 50/0/1.1
edsp 002 02 g729r8 p 0.1 IDLE 50/0/1.2
edsp 003 01 g729r8 p 0.1 IDLE 50/0/2.1
edsp 004 01 g729r8 p 0.1 IDLE 50/0/3.1
edsp 005 01 g711ulaw 0.1 IDLE 50/0/4.1
edsp 006 02 g729r8 p 0.1 IDLE 50/0/4.2
edsp 007 01 g729r8 p 0.1 IDLE 50/0/12.1
edsp 008 01 g729r8 p 0.1 IDLE 50/0/20.1
----------------------------FLEX VOICE CARD 0 ------------------------------
*DSP SIGNALING CHANNELS*
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABRT PACK COUNT
C5510 001 01 {flex} 8.4.0 alloc idle 0 0 0/0/0 02 0 40/0
C5510 001 02 {flex} 8.4.0 alloc idle 0 0 0/0/1 06 0 37/0
------------------------END OF FLEX VOICE CARD 0 ----------------------------
voice-card 0
dsp services dspfarm
voice-port 0/0/0
cptone AU
connection plar opx 202
impedance complex1
caller-id enable
voice-port 0/0/1
cptone AU
connection plar opx 222
impedance complex1
caller-id enable
sccp local Vlan100
sccp ccm 10.0.10.1 identifier 1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register mtp0018babaa9a6
keepalive retries 5
dspfarm profile 1 transcode
codec g729ar8
codec g711alaw
codec g711ulaw
codec g729abr8
maximum sessions 5
associate application SCCP
telephony-service
sdspfarm units 1
sdspfarm transcode sessions 20
sdspfarm tag 1 mtp0018babaa9a6
Re: No dsps found either locally or globally
anyone?
do you have the show voice dsp detail?
also, a show diag and show version?
Would like to see them
CCME-2#show voice dsp detailed
edsp 001 01 g711ulaw 0.1 IDLE 50/0/1.1
edsp 005 01 g729r8 p 0.1 IDLE 50/0/4.1
*DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND : (bad)bad (shut)shutdown (dpend)download pending
C5510 001 01 None 8.4.0 idle idle 0 0 0 0/0
C5510 001 02 None 8.4.0 idle idle 0 0 0 0/0
C5510 001 03 None 8.4.0 idle idle 0 0 0 0/0
C5510 001 04 None 8.4.0 idle idle 0 0 0 0/0
C5510 001 05 None 8.4.0 idle idle 0 0 0 0/0
C5510 001 06 None 8.4.0 idle idle 0 0 0 0/0
C5510 001 07 None 8.4.0 idle idle 0 0 0 0/0
C5510 001 08 None 8.4.0 idle idle 0 0 0 0/0
C5510 001 01 {flex} 8.4.0 alloc idle 0 0 0/0/0 02 0 37/0
PVDM Slot 0:
8-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 4.0
Part Number : 73-8848-05
Board Revision : A0
Deviation Number : 0
Fab Version : 04
PCB Serial Number : FOC10353N2R
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-8
Version Identifier : V01
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 04 30 41 04 00 82 49 22 90 05 42 41 30
0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 30 33 35
0x20: 33 4E 32 52 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 87 50 56 44 4D 32 2D 38 89 56 30 31 20 D9 02 40
0x40: C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Cisco IOS Software, 2801 Software (C2801-SPSERVICESK9-M), Version 12.4(9)T, RELEASE SOFTWARE (fc1)
ROM: System Bootstrap, Version 12.3(8r)T9, RELEASE SOFTWARE (fc1)
CCME-2 uptime is 1 day, 22 hours, 57 minutes
System restarted at 14:04:38 GMT Mon Feb 19 2007
System image file is "flash:c2801-spservicesk9-mz.124-9.T.bin"
Cisco 2801 (revision 6.0) with 235520K/26624K bytes of memory.
Processor board ID FHK1037F13Z
6 FastEthernet interfaces
1 terminal line
2 Voice FXO interfaces
1 DSP, 8 Voice resources
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
Paul, per the DSP Calculator, it looks like there are not enough resources after all.
Per this tool the minimun needed is a PVDM2-16.
However, what is your IOS version so that I can check it out.
3213
