No DTMF tones to PSTN over MGCP Gateway
when a Phone is connected to a service and sends DTMF tones the tones are not recognized. Seems like the Gateway does not transmit the tones.
MGCP uses follwing DTMF configuration with the BRI interface on basic-net3:
- mgcp dtmf-relay voip codec all mode out-of-band
What can i do?
with kind Regards
i.A. Martin
Green
Re: No DTMF tones to PSTN over MGCP Gateway
Could you please try to turn on:
debug mgcp packet
debug vpm signal
debug vtsp tone
and upload the info.
here is the trace. Seems like the gateway gets the tones.
Martin
*Mar 21 06:40:44.287: MGCP Packet received from 192.168.3.230:2427--->
CRCX 1058 BRI/S0/SU0/P0/2@lab_srst MGCP 0.1
C: D00000000100027d000000F500000006
L: p:20, a:PCMU, s:off, t:b8
M: recvonly
*Mar 21 06:40:44.299: MGCP Packet sent to 192.168.3.230:2427--->
200 1058 OK
I: 7
v=0
c=IN IP4 192.168.3.249
m=audio 17710 RTP/AVP 0 100
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
*Mar 21 06:40:44.999: MGCP Packet received from 192.168.3.230:2427--->
MDCX 1059 BRI/S0/SU0/P0/2@lab_srst MGCP 0.1
I: 7
X: 2
M: sendrecv
R: D/[0-9ABCD*#]
S:
Q: process,loop
v=0
o=- 7 0 IN EPN BRI/S0/SU0/P0/2@lab_srst
s=Cisco SDP 0
t=0 0
m=audio 26226 RTP/AVP 0
c=IN IP4 192.168.3.157
*Mar 21 06:40:45.003: MGCP Packet sent to 192.168.3.230:2427--->
200 1059 OK
*Mar 21 06:40:46.987: MGCP Packet received from 192.168.3.230:2427--->
RQNT 1060 BRI/S0/SU0/P0/2@lab_srst MGCP 0.1
X: 2
R: D/[0-9ABCD*#]
S: D/#
Q: process,loop
*Mar 21 06:40:46.987: MGCP Packet sent to 192.168.3.230:2427--->
200 1060 OK
*Mar 21 06:40:50.523: MGCP Packet received from 192.168.3.230:2427--->
RQNT 1061 BRI/S0/SU0/P0/2@lab_srst MGCP 0.1
X: 2
R: D/[0-9ABCD*#]
S: D/9
Q: process,loop
*Mar 21 06:40:50.527: MGCP Packet sent to 192.168.3.230:2427--->
200 1061 OK
1367
