Community Member
no DTMF tones when I dial digits out to PSTN
no DTMF tones when I dial digits out to PSTN. I get digit tones when dialing IP phone to IP phone though. Just not out to the PSTN. This system is in Switzerland, so Swiss Telecom. dial-peers below. What am I missing?
dial-peer voice 10 pots
incoming called-number .
direct-inward-dial
forward-digits all
dial-peer voice 11 voip
incoming called-number .T
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 1000 pots
description <==10 Digit Local Dialing==>
preference 1
destination-pattern 0[1-9]........
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 1/0/0:15
forward-digits all
dial-peer voice 1001 pots
description <==INT Digit Local Dialing==>
preference 1
destination-pattern 00[2-9]%
direct-inward-dial
port 1/0/0:15
forward-digits all
I can't seem to find what else to add.
1 ACCEPTED SOLUTION
Green
Re: no DTMF tones when I dial digits out to PSTN
could u please check which is your incoming voip-dial-peer when dialing to pstn, per config it may be 11.
In that one add both 245 alphanumeric and h245-signal
CUCM understands incoming h245 alpha and sends h245 signals for dtmf
Green
Community Member
One of thing, our 7921 wireless phones have no dtmf tone while dialing. Is this a default characteristic?
329
