Community Member
No ELM option for installation
Dear Experts,
I want to install a standalone ELM Server 10.5 on VM. Is it the same ISO of CUCM 10.5? I create the VM by CUCM OVA and boot up with the CUCM 10.5 ISO but there is no option for selecting ELM to install. Is there any special setting in VM for allowing the ELM installation?
Thanks & regards,
There is a separate iso for
There is a separate iso for installing standalone Prime License Manager.  It should be provided with your UC 10.x media.
Deployment Model
Cisco Prime License Manager is installed as a standalone product. It may also be automatically installed with Unified Communications products.
For standalone installation, the Cisco Prime License Manager ISO is available either from the DVD that was sent to you, or is available at the Software Download Center under Cisco Prime License Manager Virtual Machine Templates.
For coresident installations, Cisco Prime License Manager is installed automatically as part of the installation of Cisco Unified Communications Manager, Cisco Unity Connection, as well as Cisco Business Edition 6000. You may choose to run Cisco Prime License Manager on one of these servers in a coresident configuration. Refer to the latest release of the platform-specific installation document for more information:
This was taken from the install guide:
[+5] to Kevin.You would have
[+5] to Kevin.
You would have got separate PMEDIA:Prime License Mgr Install V10.5 / Recovery and Upgrade after u have u placed.
You can download the same if opted for E-Delivery.
