No entry into CUE GUI
eriktatsapaugh
Today's problem is I'm unable to see/enter CUE GUI. CME is up and functioning and I've gone through the CUE initialization wizard. When I attempt to log in to http://10.0.200.1/ccme.html, I receive a login pop-up, put in the usrn/pswd, and receive a blank browser page. I'm using IE7 in XP, and have tried Opera with same results. Pop-up blockers on browser and firewall are off.
Attachments are Router config (with elimination of clutter) and flash contents.
Ideas?
one of the procedure that cisco's user admin guide stated is that
no ip http secure-server --- you wrote ip http secure-server
in order tu access unity GUI
http://ipaddress/WEB
11 Replies 11
Brandon Buffin
Are you trying to access the CUE GUI or the CME GUI? The CUE GUI should be at http://. The link in your post should take you to the CME GUI assuming 10.0.200.1 is the address of the CME box.
BTW, I do not see any attachments to your post.
Hope this helps. If so, please rate the post.
Brandon
Trying to acces the CUE GUI. Unable to access CME GUI too.
The attachments are a seperate post. But here they are again.
eriktatsapaugh
Here are those attachments.
Hi, can you try IE6 ?
No. I only have IE7 available. I've tried to downgrade to IE6 with no success. I would really like someone at Cisco to fix the issue with IE7 SOON.
As an internal you're in a good position to try asking for improvement. TME is Tony Huyhn,not sure the who the PM is. And while you're there, remember them IE is not the only browser in use :)
The deletion of the "ip http secure-server" has allowed the browser "Opera" to connect to the CUE GUI and a router GUI, but not the CME GUI. (No, was never able to open CME GUI) Any suggestions? Because I can open the CUE (http://10.0.200.2/) should not that mean that the error is either in the config on the router, or I'm missing a file in flash? (CME: http://10.0.200.1/ccme.html)
You can debug if any file is missing with "debug ip http all", and "term mon".
I'm not sure how "debug ip http all" will show me a missing file, but I used it during my attempt to open the CME GUI. The output is attached. All it showed me was a GET cmd, and a request for authentication, but no response.
I am going to open a new conversation with this problem called "No CME GUI access", as my initial CUE connection problem was solved.
(Thank you for that)
Ok I think I got what you got. You have the files in a subdirectory called flash. Consequently you need:
ip http flash:/flash
Maybe rename the subdirectory something like cme_files ?
