No GUI files for latest IOS
Hi Guys,
I have just upgraded the IOS from c2800nm-advipservicesk9-mz.124-11.XJ.bin to c2800nm-ipvoicek9-mz.124-23.bin but cannot see which GUI files i should use for the CME. Should i either downgrade to c2800nm-ipvoicek9-mz.124-22.T.bin so i can use the CME 7.0 GUI files as they not currently working with the 12.4.23 IOS.
Thanks in advance.
  • IP Telephony
Hall of Fame Super Gold
Re: No GUI files for latest IOS
Hi, GUI files are distributed in an archive from the CCME area on CCO. Use these labeled CCME 4.3.
Hope this helps, please rate post if it does
Hi Bruce,
This is an oversight on the way IOS works.
12.4 mainline is the stability release that does not have any new features in it. 12.4 mainline is what 12.3T used to be.
12.4T is the IOS with all of the new features added to it. When they're done making features for it, it will become 12.5
So, by going from 12.4(11)XJ (which is a T release) to 124-23 you are actually downgrading IOS. And by going from 12.4(23) (mainline) to 12.4(22)T you are upgrading.
Thought I would point this out for you.
12.4(22)T will use the CME 7.0 GUI.
hth,
nick
118
