No inbound calls while in SRST
When in SRST I get no inbound calls. I here 1 ring and then a fast busy. I'm including a sh run. Any help will be appreciated.
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
trunk-group 100
timing hookflash-out 500
connection plar 45585
voice-port 0/2/1
trunk-group 100
voice-port 0/2/2
trunk-group 100
voice-port 0/2/3
trunk-group 100
mgcp
mgcp call-agent 10.xxx.xxx.xx 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0.171
mgcp bind media source-interface FastEthernet0/0.171
mgcp profile default
dial-peer voice 999020 pots
application mgcpapp
port 0/2/0
dial-peer voice 999021 pots
application mgcpapp
port 0/2/1
dial-peer voice 999023 pots
application mgcpapp
port 0/2/3
dial-peer voice 999022 pots
application mgcpapp
port 0/2/2
dial-peer voice 200 pots
trunkgroup 100
destination-pattern 4....
dial-peer voice 201 pots
trunkgroup 100
destination-pattern 9.[2-8]........
forward-digits all
dial-peer voice 202 pots
trunkgroup 100
destination-pattern 9911
forward-digits all
dial-peer voice 203 pots
trunkgroup 100
destination-pattern 911
forward-digits all
prefix 9
dial-peer voice 204 pots
trunkgroup 100
destination-pattern 9.1[2-8].........
forward-digits all
call-manager-fallback
secondary-dialtone 9
max-conferences 8
limit-dn 7940 2
limit-dn 7960 2
ip source-address 10.xxx.xxx.x port 2000
max-ephones 36
max-dn 72 dual-line
time-zone 8
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: No inbound calls while in SRST
I don't see "ccm-manager fallback-mgcp" command in your config.
Also, try adding:
"application
global
service alternate Default"
If it still does not work, can you post
"sh ccm-manager"
HTH,
Chris
Also, try adding:
"application
global
"sh ccm-manager"
HTH,
Chris
service alternate default solved the problem. Thanks
175
