11-20-2013 11:45 AM - edited 03-16-2019 08:30 PM
I am trying to configure a CUCM with a SIP trunk to a 2811 and a voice GW to my SIP trunk provider.
CUCM8.6 <SIP>2811<SIP> Callcentric.
I am able to make outgoing calls but am failing miserably with incoming.
I suspect it is my incoming dial peer.
The incoming calls hit my 2811 but do not seem to go to my CUCM.
I have attached an output from my "debug ccsip calls"
Anything help would be greatly appreciated.
11-20-2013 01:52 PM
Do you have dial-peers pointing back to CUCM??
Do the dial-peers match the number of digits telco is sending??
Do you have the right set of inbound digits and CSS?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
11-20-2013 03:25 PM
Robert,
surely that is not all the sip debug information, I am missing the INVITES, TRYING etc SIP messages, can you re-attach and maybe also debug your dial peers to see what gets hit (if anything at all ) when making an inbound call.
Cheers
Please remember to rate useful posts, by clicking on the stars below.
