No incoming calls in SRST mode
Hi, My problem is while in SRST mode, there is no incoming calls passing through. But there is outgoing. Using the same ISDN PRI line, in CUCM, incoming and outgoing are working fine. This is the config:
sho run
Building configuration...
Current configuration : 5295 bytes
! Last configuration change at 13:59:04 PST Fri Oct 24 2014 by admin
! NVRAM config last updated at 16:39:10 PST Thu Oct 23 2014 by admin
version 15.1
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.151-4.M9.bin
boot-end-marker
card type e1 0 0
no aaa new-model
clock timezone PST 8 0
network-clock-participate wic 0
no ipv6 cef
ipv6 spd queue min-threshold 62
ipv6 spd queue max-threshold 63
ip source-route
ip cef
isdn switch-type primary-net5
voice-card 0
 dspfarm
 dsp services dspfarm
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  bind control source-interface Port-channel2
  bind media source-interface Port-channel2
  session transport tcp
  registrar server
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
voice register global
 max-dn 100
 max-pool 100
voice register dn  1
 number 1...
voice register pool  1
 id network 172.31.36.0 mask 255.255.255.0
voice translation-rule 1
 rule 1 /026289900/ /1114/
 rule 2 /6289900/ /1114/
voice translation-profile Incoming
 translate called 1
application
 global
  service alternate Default
license udi pid CISCO2921/K9 sn FGL17121018
license boot module c2900 technology-package securityk9
hw-module pvdm 0/0
hw-module sm 1
username admin privilege 15 secret 4 E49HhhgxWTVgskvm.YMatFEEr8KG.VAZJzXWojvWq0Y
redundancy
controller E1 0/0/0
 framing NO-CRC4
 pri-group timeslots 1-31 service mgcp
 ip address 172.31.36.8 255.255.255.0
 hold-queue 150 in
interface Embedded-Service-Engine0/0
 no ip address
interface GigabitEthernet0/0
 description Link to MSCRSW01 Gig 1/0/47
 no ip address
 duplex auto
 speed auto
 channel-group 2
interface GigabitEthernet0/1
 description Link to MSCRSW01 Gig 2/0/47
 no ip address
 duplex auto
 speed auto
 channel-group 2
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0:15
 no ip address
 encapsulation hdlc
 isdn incoming-voice voice
 no cdp enable
interface GigabitEthernet1/0
 ip address 1.1.1.1 255.255.255.0
interface GigabitEthernet1/1
 description Internal switch interface connected to EtherSwitch Service Module
 no ip address
interface Vlan1
 no ip address
ip default-gateway 172.31.36.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.31.36.1
control-plane
voice-port 0/0/0:15
ccm-manager fallback-mgcp
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 172.31.36.5
ccm-manager config
mgcp
mgcp call-agent 172.31.36.5 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface Port-channel2
mgcp profile default
sccp local Port-channel2
sccp ccm 172.31.36.5 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
 associate ccm 1 priority 1
 associate profile 1 register CFB7cad74362760
dspfarm profile 1 conference
 codec g729br8
 codec g729r8
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 maximum sessions 2
 associate application SCCP
 shutdown
dial-peer voice 1 pots
 description Incoming
 translation-profile incoming Incoming
 incoming called-number .
 no digit-strip
 port 0/0/0:15
dial-peer voice 11 pots
 description Local
 destination-pattern 9[2-9]......
 clid network-number 026289900
 port 0/0/0:15
sip-ua
 retry invite 5
 retry response 10
 sip-server ipv4:172.31.36.8
gatekeeper
 shutdown
ephone-type 8945
 device-id 585
 num-buttons 1
 max-presentation 1
call-manager-fallback
 secondary-dialtone 9
 max-conferences 8 gain -6
 transfer-system full-consult
 ip source-address 172.31.36.8 port 2000
 max-ephones 100
 max-dn 100
line con 0
 exec-timeout 5 0
 logging synchronous
 login local
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line 67
 no exec
 transport input all
 stopbits 1
 flowcontrol software
line vty 0 4
 exec-timeout 5 0
 logging synchronous
 login local
 transport input telnet ssh
 transport output none
line vty 5 15
 no login
scheduler allocate 20000 1000
ntp server 172.31.35.16
end
The pilot number is (02)6289900. And the incoming calls should be answered from extension 1114.
This is the translation test:
MSCRVG#test voice translation-rule 1 026289900
Matched with rule 1
Original number: 026289900      Translated number: 1114
Original number type: none      Translated number type: none
Original number plan: none      Translated number plan: none
This is the debug:
MSCRVG#
Oct 24 14:27:17.824: //-1/A2E3B02A8C34/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=1123
   ----- ccCallInfo IE subfields -----
   cisco-ani=1123
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=9
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Oct 24 14:27:17.824: //-1/A2E3B02A8C34/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x2B2B316C, Call Info(
   Calling Number=1123,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=9(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=40004, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=2898
Oct 24 14:27:17.824: //-1/A2E3B02A8C34/CCAPI/ccCheckClipClir:
   In: Calling Number=1123(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=1123(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Oct 24 14:27:17.824: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Oct 24 14:27:17.824: :cc_get_feature_vsa malloc success
Oct 24 14:27:17.824:  cc_get_feature_vsa count is 1
Oct 24 14:27:17.824: :FEATURE_VSA attributes are: feature_name:0,feature_time:1073917872,feature_id:122
Oct 24 14:27:17.824: //2898/A2E3B02A8C34/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=1123(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=9(TON=Unknown, NPI=Unknown))
Oct 24 14:27:17.824: //2898/A2E3B02A8C34/CCAPI/cc_process_call_setup_ind:
   Event=0x40F21468
Oct 24 14:27:17.824: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 9
Oct 24 14:27:17.828: //2898/A2E3B02A8C34/CCAPI/ccCallSetContext:
   Context=0x2BE3F56C
Oct 24 14:27:17.828: //2898/A2E3B02A8C34/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 2898 with tag 40004 to app "_ManagedAppProcess_Default"
Oct 24 14:27:17.828: //2898/A2E3B02A8C34/CCAPI/ccCallSetupAck:
   Call Id=2898
Oct 24 14:27:17.828: //2898/A2E3B02A8C34/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
Oct 24 14:27:17.828: //2898/A2E3B02A8C34/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms)
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Oct 24 14:27:17.828: //2898/A2E3B02A8C34/CCAPI/ccCallReportDigits:
   (callID=0xB52, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=2898
MSCRVG#
Oct 24 14:27:17.848: //2898/A2E3B02A8C34/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x2B2B316C, callID=0xB52, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x2B2B316C, Call Id=2898
   Call Entry(Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms))
Oct 24 14:27:18.548: //2898/A2E3B02A8C34/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x1, Destination Call Id=-1,
   Source Call Id=2898, Digit=6, DigitBeginFlags=0x0,
   Rtp Timestamp=0x0, Rtp Expiration=0x0
Oct 24 14:27:18.548: //2898/A2E3B02A8C34/CCAPI/cc_api_call_digit_end:
   Source Call Id=2898, Digit=6, Duration=250,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
   Call Entry(Handoff Depth=0)
Oct 24 14:27:18.800: //2898/A2E3B02A8C34/CCAPI/cc_api_call_digit_begin:
MSCRVG#Destination Interface=0x0, Destination Mask=0x1, Destination Call Id=-1,
   Source Call Id=2898, Digit=2, DigitBeginFlags=0x0,
Oct 24 14:27:18.800: //2898/A2E3B02A8C34/CCAPI/cc_api_call_digit_end:
   Source Call Id=2898, Digit=2, Duration=250,
Oct 24 14:27:19.060: //2898/A2E3B02A8C34/CCAPI/cc_api_call_digit_begin:
   Source Call Id=2898, Digit=8, DigitBeginFlags=0x0,
Oct 24 14:27:19.064: //2898/A2E3B02A8C34/CCAPI/cc_api_call_digit_end:
   Source Call Id=2898, Digit=8, Duration=250,
Oct 24 14:27:19.328: //2898/A2E3B02A8C34/CCAPI/cc_api_call_digit_begin:
   Source Call Id=2898, Digit=9, DigitBeginFlags=0x0,
Oct 24 14:27:19.328: //2898/A2E3B02A8C34/CCAPI/cc_api_call_digit_end:
   Source Call Id=2898, Digit=9, Duration=250,
Oct 24 14:27:19.468: //2898/A2E3B02A8C34/CCAPI/cc_api_call_digit_begin:
Oct 24 14:27:19.468: //2898/A2E3B02A8C34/CCAPI/cc_api_call_digit_end:
Oct 24 14:27:19.840: //2898/A2E3B02A8C34/CCAPI/cc_api_call_digit_begin:
   Source Call Id=2898, Digit=0, DigitBeginFlags=0x0,
Oct 24 14:27:19.840: //2898/A2E3B02A8C34/CCAPI/cc_api_call_digit_end:
   Source Call Id=2898, Digit=0, Duration=250,
Oct 24 14:27:20.056: //2898/A2E3B02A8C34/CCAPI/cc_api_call_digit_begin:
Oct 24 14:27:20.056: //2898/A2E3B02A8C34/CCAPI/cc_api_call_digit_end:
Oct 24 14:27:20.056: //2898/A2E3B02A8C34/CCAPI/ccCallReportDigits:
   (callID=0xB52, digit_event=0x0, enable=FALSE, consume=FALSE)
Oct 24 14:27:20.056: //2898/A2E3B02A8C34/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x2B2B316C, callID=0xB52, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Oct 24 14:27:20.056: //2898/A2E3B02A8C34/CCAPI/ccCallProceeding:
Oct 24 14:27:20.060: //2898/A2E3B02A8C34/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=11, Params=0x2BE40A7C, Progress Indication=NULL(0)
Oct 24 14:27:20.060: //2898/A2E3B02A8C34/CCAPI/ccCheckClipClir:
   Out: Calling Number=026289900(TON=Unknown, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Destination Pattern=9[2-9]......, Called Number=96289900, Digit Strip=TRUE
   Calling Number=026289900(TON=Unknown, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=96289900(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=J. Alibanto
   Account Number=1123, Final Destination Flag=FALSE,
   Guid=A2E3B02A-5A7D-11E4-8C34-8485CC431430, Outgoing Dial-peer=11
Oct 24 14:27:20.060: //2898/A2E3B02A8C34/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=1123
   cisco-ani=026289900
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=96289900
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Oct 24 14:27:20.060: //2898/A2E3B02A8C34/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x418D1528, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=026289900,(Calling Name=J. Alibanto)(TON=Unknown, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=96289900(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=FALSE, Outgoing Dial-peer=11, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Oct 24 14:27:20.060: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Oct 24 14:27:20.060: :cc_get_feature_vsa malloc success
Oct 24 14:27:20.060:  cc_get_feature_vsa count is 2
Oct 24 14:27:20.060: :FEATURE_VSA attributes are: feature_name:0,feature_time:1073917648,feature_id:123
Oct 24 14:27:20.060: //2899/A2E3B02A8C34/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Oct 24 14:27:20.060: //2899/A2E3B02A8C34/CCAPI/ccCallSetContext:
   Context=0x2BE40A2C
Oct 24 14:27:20.060: //2898/A2E3B02A8C34/CCAPI/ccSaveDialpeerTag:
Oct 24 14:27:20.128: //2899/A2E3B02A8C34/CCAPI/cc_api_call_proceeding:
   Interface=0x418D1528, Progress Indication=INBAND(8)
Oct 24 14:27:20.128: //2898/A2E3B02A8C34/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
   Call Entry(Responsed=TRUE)
Oct 24 14:27:20.128: //2898/A2E3B02A8C34/CCAPI/ccConferenceCreate:
   (confID=0x2BE07008, callID1=0xB52, gcid=A2E44C52-5A7D11E4-8C378485-CC431430, tag=0x0)
Oct 24 14:27:20.128: //2899/A2E3B02A8C34/CCAPI/ccConferenceCreate:
   (confID=0x2BE07008, callID2=0xB53, gcid=A2E44C52-5A7D11E4-8C378485-CC431430, tag=0x0)
   Conference Id=0x2BE07008, Call Id1=2898, Call Id2=2899, Tag=0x0
Oct 24 14:27:20.128: //2898/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Oct 24 14:27:20.128: cc_api_get_xcode_stream : 4702
Oct 24 14:27:20.132: //2898/A2E3B02A8C34/CCAPI/cc_api_bridge_done:
   Conference Id=0x2A, Source Interface=0x2B2B316C, Source Call Id=2898,
   Destination Call Id=2899, Disposition=0x0, Tag=0x0
Oct 24 14:27:20.132: //2899/A2E3B02A8C34/CCAPI/cc_api_bridge_done:
   Conference Id=0x2A, Source Interface=0x418D1528, Source Call Id=2899,
   Destination Call Id=2898, Disposition=0x0, Tag=0xFFFFFFFF
Oct 24 14:27:20.132: //2898/A2E3B02A8C34/CCAPI/cc_generic_bridge_done:
Oct 24 14:27:20.132: //2898/A2E3B02A8C34/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2A, Destination Call Id=2899)
Oct 24 14:27:20.132: //2899/A2E3B02A8C34/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2A, Destination Call Id=2898)
Oct 24 14:27:20.132: //2899/A2E3B02A8C34/CCAPI/cc_api_caps_ind:
   Destination Interface=0x2B2B316C, Destination Call Id=2898, Source Call Id=2899,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Oct 24 14:27:20.132: //2898/A2E3B02A8C34/CCAPI/cc_api_caps_ind:
   Destination Interface=0x418D1528, Destination Call Id=2899, Source Call Id=2898,
   Caps(Codec=0x4, Fax Rate=0x2, Vad=0x2,
   Modem=0x0, Codec Bytes=20, Signal Type=2)
Oct 24 14:27:20.132: //2898/A2E3B02A8C34/CCAPI/cc_api_caps_ack:
   Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
   Modem=OFF(0x0), Codec Bytes=20, Signal Type=2, Seq Num Start=6095)
Oct 24 14:27:20.132: //2899/A2E3B02A8C34/CCAPI/cc_api_caps_ack:
Oct 24 14:27:20.132: //2898/A2E3B02A8C34/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=2898
Oct 24 14:27:20.132: //2898/A2E3B02A8C34/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2A, Call Id1=2898, Call Id2=2899
Oct 24 14:27:20.136: //2899/A2E3B02A8C34/CCAPI/cc_api_voice_mode_event:
   Call Id=2899
   Call Entry(Context=0x2BE40A2C)
Oct 24 14:27:20.620: //-1/A48EF0E28024/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=026289900
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=9900
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Oct 24 14:27:20.620: //-1/A48EF0E28024/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x418D1528, Call Info(
   Calling Number=026289900,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=9900(TON=Subscriber, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=1, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Oct 24 14:27:20.620: //-1/A48EF0E28024/CCAPI/ccCheckClipClir:
   In: Calling Number=026289900(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=026289900(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
Oct 24 14:27:20.620: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Oct 24 14:27:20.620: :cc_get_feature_vsa malloc success
Oct 24 14:27:20.620:  cc_get_feature_vsa count is 3
Oct 24 14:27:20.620: :FEATURE_VSA attributes are: feature_name:0,feature_time:1073917424,feature_id:124
Oct 24 14:27:20.620: //2900/A48EF0E28024/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=026289900(TON=Na
MSCRVG#tional, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=9900(TON=Subscriber, NPI=ISDN))
Oct 24 14:27:20.620: //2900/A48EF0E28024/CCAPI/cc_process_call_setup_ind:
   Event=0x40F21468
Oct 24 14:27:20.620: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 9900
Oct 24 14:27:20.620: //2900/A48EF0E28024/CCAPI/ccCallSetContext:
   Context=0x2BE41EEC
   >>>>CCAPI handed cid 2900 with tag 1 to app "_ManagedAppProcess_Default"
Oct 24 14:27:20.624: //2900/A48EF0E28024/CCAPI/ccCallSetupAck:
   Call Id=2900
Oct 24 14:27:20.624: //2900/A48EF0E28024/CCAPI/cc_api_set_transfer_info:
Oct 24 14:27:20.624: //2900/A48EF0E28024/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=2900
Oct 24 14:27:20.624: //2900/A48EF0E28024/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
Oct 24 14:27:20.624: //2900/A48EF0E28024/CCAPI/ccCallReportDigits:
   (callID=0xB54, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=2900
Oct 24 14:27:20.624: //2900/A48EF0E28024/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x418D1528, callID=0xB54, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x418D1528, Call Id=2900
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
Oct 24 14:27:20.796: %ISDN-6-CONNECT: Interface Serial0/0/0:30 is now connected to 6289900 N/A
Oct 24 14:27:20.800: //2899/A2E3B02A8C34/CCAPI/cc_api_call_connected:
   Interface=0x418D1528, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Oct 24 14:27:20.800: //2898/A2E3B02A8C34/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
   Call Entry(Connected=TRUE, Responsed=TRUE)
Oct 24 14:27:20.800: //2898/A2E3B02A8C34/CCAPI/ccCallNotify:
Oct 24 14:27:20.800: %ISDN-6-CONNECT: Interface Serial0/0/0:25 is now connected to 026289900 N/A
MSCRVG#
Oct 24 14:27:24.112: //2899/A2E3B02A8C34/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Sum Network, Params=0x0, Call Id=2899
Oct 24 14:27:24.116: //2898/A2E3B02A8C34/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x2B2B316C, Call Id=2898
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Oct 24 14:27:24.116: //2898/A2E3B02A8C34/CCAPI/ccConferenceDestroy:
   Conference Id=0x2A, Tag=0x0
Oct 24 14:27:24.116: //2898/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Oct 24 14:27:24.116: cc_api_get_xcode_stream : 4702
Oct 24 14:27:24.116: //2899/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Oct 24 14:27:24.116: //2898/A2E3B02A8C34/CCAPI/cc_api_bridge_drop_done:
Oct 24 14:27:24.116: //2899/A2E3B02A8C34/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=2898, Disposition=0x0, Tag=0x0
Oct 24 14:27:24.116: //2898/A2E3B02A8C34/CCAPI/cc_generic_bridge_done:
Oct 24 14:27:24.116: //2898/A2E3B02A8C34/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Oct 24 14:27:24.116: //2899/A2E3B02A8C34/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Oct 24 14:27:24.116: //2899/A2E3B02A8C34/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Oct 24 14:27:24.120: //2898/A2E3B02A8C34/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2B2B316C, Tag=0x0, Call Id=2898,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Oct 24 14:27:24.120: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Oct 24 14:27:24.120: :cc_free_feature_vsa freeing 4002AFA8
Oct 24 14:27:24.120:  vsacount in free is 2
Oct 24 14:27:24.140: %ISDN-6-DISCONNECT: Interface Serial0/0/0:30  disconnected from 6289900 , call lasted 3 seconds
Oct 24 14:27:24.208: //2899/A2E3B02A8C34/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x418D1528, Tag=0x0, Call Id=2899,
Oct 24 14:27:24.208: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Oct 24 14:27:24.208: :cc_free_feature_vsa freeing 4002AEC8
Oct 24 14:27:24.208:  vsacount in free is 1
Oct 24 14:27:24.212: %ISDN-6-DISCONNECT: Interface Serial0/0/0:25  disconnected from 026289900 , call lasted 3 seconds
Oct 24 14:27:24.212: //2900/A48EF0E28024/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x418D1528, Call Id=2900
   Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Oct 24 14:27:24.212: //2900/A48EF0E28024/CCAPI/ccCallDisconnect:
Oct 24 14:27:24.212: //2900/A48EF0E28024/CCAPI/cc_api_get_transfer_info:
MSCRVG#
Oct 24 14:27:24.420: //2900/A48EF0E28024/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x418D1528, Tag=0x0, Call Id=2900,
Oct 24 14:27:24.420: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Oct 24 14:27:24.420: :cc_free_feature_vsa freeing 4002ADE8
Oct 24 14:27:24.420:  vsacount in free is 0
MSCRVG#
Here, I'm dialing out with an IP phone with a 1123 extension. I dialled 96289900. So you will see here the incoming and outgoing dial peer.
Gelo
1 ACCEPTED SOLUTION
 apply below and testdial
direct-inward-dial
test belowvoice translation
test below
 rule 1 /9900/ /1114/
i already done this. still
i already done this. still does not work.
make a call from PSTN and
make a call from PSTN and send the logs
Oct 24 15:33:51.090: //-1
Oct 24 15:33:51.090: //-1/EF0FC5C1802B/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=026355904
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=9900
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Oct 24 15:33:51.090: //-1/EF0FC5C1802B/CCAPI/cc_api_call_setup_ind_common:
   Calling Number=026355904,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Incoming Dial-peer=1, Progress Indication=NOT END TO END ISDN(1), Calling IE Present=TRUE,
Oct 24 15:33:51.090: //-1/EF0FC5C1802B/CCAPI/ccCheckClipClir:
   In: Calling Number=026355904(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=026355904(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
Oct 24 15:33:51.090: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Oct 24 15:33:51.090: :cc_get_feature_vsa malloc success
Oct 24 15:33:51.090:  cc_get_feature_vsa count is 1
Oct 24 15:33:51.090: :FEATURE_VSA attributes are: feature_name:0,feature_time:1073917648,feature_id:166
Oct 24 15:33:51.090: //2993/EF0FC5C1802B/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=026355904(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
Oct 24 15:33:51.090: //2993/EF0FC5C1802B/CCAPI/cc_process_call_setup_ind:
   Event=0x40F21468
Oct 24 15:33:51.090: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Oct 24 15:33:51.090: //2993/EF0FC5C1802B/CCAPI/ccCallSetContext:
   Context=0x2BE2A96C
   >>>>CCAPI handed cid 2993 with tag 1 to app "_ManagedAppProcess_Default"
Oct 24 15:33:51.090: //2993/EF0FC5C1802B/CCAPI/ccCallSetupAck:
   Call Id=2993
MSCRVG#C1802B/CCAPI/cc_api_set_transfer_info:
Oct 24 15:33:51.090: //2993/EF0FC5C1802B/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=2993
Oct 24 15:33:51.090: //2993/EF0FC5C1802B/CCAPI/ccSetDigitTimeouts:
Oct 24 15:33:51.090: //2993/EF0FC5C1802B/CCAPI/ccCallReportDigits:
   (callID=0xBB1, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=2993
Oct 24 15:33:51.090: //2993/EF0FC5C1802B/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x418D1528, callID=0xBB1, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x418D1528, Call Id=2993
Oct 24 15:33:51.146: %ISDN-6-CONNECT: Interface Serial0/0/0:2 is now connected to 026355904 N/A
MSCRVG#
Oct 24 15:34:02.414: %ISDN-6-DISCONNECT: Interface Serial0/0/0:2  disconnected from 026355904 , call lasted 11 seconds
Oct 24 15:34:02.414: //2993/EF0FC5C1802B/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x418D1528, Call Id=2993
Oct 24 15:34:02.414: //2993/EF0FC5C1802B/CCAPI/ccCallDisconnect:
Oct 24 15:34:02.414: //2993/EF0FC5C1802B/CCAPI/cc_api_get_transfer_info:
MSCRVG#
Oct 24 15:34:02.598: //2993/EF0FC5C1802B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x418D1528, Tag=0x0, Call Id=2993,
Oct 24 15:34:02.602: //2993/EF0FC5C1802B/CCAPI/cc_api_call_disconnect_done:
Oct 24 15:34:02.602: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Oct 24 15:34:02.602: :cc_free_feature_vsa freeing 4002AEC8
Oct 24 15:34:02.602:  vsacount in free is 0
did you add what i requested
did you add what i requested ?
is 1114 registered ?
yes. and yes, 1114 is
yes. and yes, 1114 is registered.
 translate called 1
MSCRVG#sho dial-peer voice summary
dial-peer hunt 0
             AD                                    PRE PASS                OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT    KEEPALIVE
1      pots  up   up                                0                      down 0/0/0:15
11     pots  up   up             9[2-9]......       0                      up   0/0/0:15
20001  pots  up   up             1108$              0                           50/0/1
20002  pots  up   up             1104$              0                           50/0/2
20003  pots  up   up             1106$              0                           50/0/3
20004  pots  up   up             1111$              0                           50/0/4
20005  pots  up   down                              0                           50/0/5
20006  pots  up   down                              0                           50/0/6
20007  pots  up   down                              0                           50/0/7
20008  pots  up   down                              0                           50/0/8
20009  pots  up   down                              0                           50/0/9
20010  pots  up   down                              0                           50/0/10
20011  pots  up   down                              0                           50/0/11
20012  pots  up   down                              0                           50/0/12
20013  pots  up   down                              0                           50/0/13
20014  pots  up   down                              0                           50/0/14
20015  pots  up   down                              0                           50/0/15
20016  pots  up   down                              0                           50/0/16
20017  pots  up   down                              0                           50/0/17
20018  pots  up   down                              0                           50/0/18
20019  pots  up   down                              0                           50/0/19
20020  pots  up   down                              0                           50/0/20
20021  pots  up   down                              0                           50/0/21
20022  pots  up   down                              0                           50/0/22
20023  pots  up   down                              0                           50/0/23
20024  pots  up   down                              0                           50/0/24
20025  pots  up   down                              0                           50/0/25
20026  pots  up   down                              0                           50/0/26
             AD                                    PRE PASS                OUT
20027  pots  up   down                              0                           50/0/27
20028  pots  up   down                              0                           50/0/28
20029  pots  up   down                              0                           50/0/29
20030  pots  up   down                              0                           50/0/30
20031  pots  up   down                              0                           50/0/31
20032  pots  up   down                              0                           50/0/32
20033  pots  up   down                              0                           50/0/33
20034  pots  up   down                              0                           50/0/34
20035  pots  up   down                              0                           50/0/35
20036  pots  up   down                              0                           50/0/36
20037  pots  up   down                              0                           50/0/37
20038  pots  up   down                              0                           50/0/38
20039  pots  up   down                              0                           50/0/39
20040  pots  up   down                              0                           50/0/40
20041  pots  up   down                              0                           50/0/41
20042  pots  up   down                              0                           50/0/42
20043  pots  up   down                              0                           50/0/43
20044  pots  up   down                              0                           50/0/44
20045  pots  up   down                              0                           50/0/45
20046  pots  up   down                              0                           50/0/46
20047  pots  up   down                              0                           50/0/47
20048  pots  up   down                              0                           50/0/48
20049  pots  up   down                              0                           50/0/49
20050  pots  up   down                              0                           50/0/50
20051  pots  up   down                              0                           50/0/51
20052  pots  up   down                              0                           50/0/52
20053  pots  up   down                              0                           50/0/53
20054  pots  up   down                              0                           50/0/54
20055  pots  up   down                              0                           50/0/55
20056  pots  up   down                              0                           50/0/56
20057  pots  up   down                              0                           50/0/57
             AD                                    PRE PASS                OUT
20058  pots  up   down                              0                           50/0/58
20059  pots  up   down                              0                           50/0/59
20060  pots  up   down                              0                           50/0/60
20061  pots  up   down                              0                           50/0/61
20062  pots  up   down                              0                           50/0/62
20063  pots  up   down                              0                           50/0/63
20064  pots  up   down                              0                           50/0/64
20065  pots  up   down                              0                           50/0/65
20066  pots  up   down                              0                           50/0/66
20067  pots  up   down                              0                           50/0/67
20068  pots  up   down                              0                           50/0/68
20069  pots  up   down                              0                           50/0/69
20070  pots  up   down                              0                           50/0/70
20071  pots  up   down                              0                           50/0/71
20072  pots  up   down                              0                           50/0/72
20073  pots  up   down                              0                           50/0/73
20074  pots  up   down                              0                           50/0/74
20075  pots  up   down                              0                           50/0/75
20076  pots  up   down                              0                           50/0/76
20077  pots  up   down                              0                           50/0/77
20078  pots  up   down                              0                           50/0/78
20079  pots  up   down                              0                           50/0/79
20080  pots  up   down                              0                           50/0/80
20081  pots  up   down                              0                           50/0/81
20082  pots  up   down                              0                           50/0/82
20083  pots  up   down                              0                           50/0/83
20084  pots  up   down                              0                           50/0/84
20085  pots  up   down                              0                           50/0/85
20086  pots  up   down                              0                           50/0/86
20087  pots  up   down                              0                           50/0/87
20088  pots  up   down                              0                           50/0/88
             AD                                    PRE PASS                OUT
20089  pots  up   down                              0                           50/0/89
20090  pots  up   down                              0                           50/0/90
20091  pots  up   down                              0                           50/0/91
20092  pots  up   down                              0                           50/0/92
20093  pots  up   down                              0                           50/0/93
20094  pots  up   down                              0                           50/0/94
20095  pots  up   down                              0                           50/0/95
20096  pots  up   down                              0                           50/0/96
20097  pots  up   down                              0                           50/0/97
20098  pots  up   down                              0                           50/0/98
20099  pots  up   down                              0                           50/0/99
20100  pots  up   down                              0                           50/0/100
40004  voip  up   up             1123               0  syst ipv4:172.31.36.56:50
40003  voip  up   up             1121               0  syst ipv4:172.31.36.28:50
40001  voip  up   up             1114               0  syst ipv4:172.31.36.43:50
MSCRVG#
MSCRVG#
can you enable , deb voice
can you enable , deb voice translation , as well and check if 9900 is being translated?
MSCRVG#Oct 24 15:53:14.517: /
MSCRVG#
Oct 24 15:53:14.517: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_trunkgroup_internal:
   Voice port 0x418D1528 dsl=0 timeslot=4 does not belong to any trunk group
Oct 24 15:53:14.517: //-1/xxxxxxxxxxxx/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 1
Oct 24 15:53:14.517: //-1/xxxxxxxxxxxx/RXRULE/sed_subst: Successful substitution; pattern=9900 matchPattern=9900 replacePattern=1114 replaced pattern=1114
Oct 24 15:53:14.517: //-1/xxxxxxxxxxxx/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = subscriber
Oct 24 15:53:14.517: //-1/xxxxxxxxxxxx/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = isdn
   Voice port 0x418D1528 dsl=-1 timeslot=0 does not belong to any trunk group
Oct 24 15:53:14.521: //-1/A4853333802C/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x418D0470; count=1
Oct 24 15:53:14.521: //-1/A4853333802C/RXRULE/regxrule_stack_pop_callinfo_interna
MSCRVG#l: numinfo=0x2BD847A4
Oct 24 15:53:14.521: //-1/A4853333802C/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x418D0470; count=1
Oct 24 15:53:14.521: //-1/A4853333802C/RXRULE/regxrule_profile_translate_internal: number=026355909 type=national plan=isdn numbertype=calling
Oct 24 15:53:14.521: //-1/A4853333802C/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
Oct 24 15:53:14.521: //-1/A4853333802C/RXRULE/regxrule_profile_match_internal: Error: ruleset for calling number not found
Oct 24 15:53:14.521: //-1/A4853333802C/RXRULE/regxrule_profile_translate_internal: No match: number=026355909 type=national plan=isdn
Oct 24 15:53:14.521: //-1/A4853333802C/RXRULE/regxrule_profile_translate_internal: number= type=UNKNOWN plan=UNKNOWN numbertype=redirect-called
Oct 24 15:53:14.521: //-1/A4853333802C/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-called number not found
Oct 24 15:53:14.521: //-1/A4853333802C/RXRULE/regxrule_profile_translate_internal: No match: number= type=UNKNOWN plan=UNKNOWN
Oct 24 15:53:14.605: %ISDN-6-CONNECT: Interface Serial0/0/0:3 is now connected to 026355909 N/A
MSCRVG#
Oct 24 15:53:24.909: %ISDN-6-DISCONNECT: Interface Serial0/0/0:3  disconnected from 026355909 , call lasted 10 seconds
MSCRVG#
Oct 24 15:53:25.093: //-1/A4853333802C/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x418D0470; count=1
Oct 24 15:53:25.093: //-1/A4853333802C/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x2BD847A4
MSCRVG#
can you send the logs
Javelkur, it worked! we used
Javelkur, it worked! we used a different line, not the same line. A while ago, we used the same line for calling that's why I told you it did not work. sorry for that.
But we don't have DID. Why did it work? I thought it is only used if you have DID implemented.
you mean to say it worked
you mean to say it worked with DID for inbound call ?
yes!
yes!
in srst or normal mode ?
still in SRST.
still in SRST.
direct-inward-dial
applied. still not working.
168
