No ip addresses show in callmanager
I added a subscriber server to my cluster and my database stopped replication. I tried to use DBL helper but the program would not connect to the database at all. I then reestablished the subscriptions manually in SQL.
Everything seems to be replicating but now when I search for a phone on the publisher I do not get any IP addresses associated with the phone only status not found. All my phones are still registered and when I look at the subscribers in my cluster phones have IP addresses.
In Enterprise manager when I look at Replication Monitor I see that transactions are still being delivered. It has been doing this for about 3 hours.
I have tried restarting RIS Data Collector, IIS, Database layer Monitor and have rebooted the publisher and still do not see the IP Address.
Any suggestions would be appreciated Thanks
Jason
Green
Re: No ip addresses show in callmanager
Hi Jason,
After adding the server did you reboot the cluster?
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_1/insta
ll/instcall/cm413ins.htm#wp534948
Any out of sync components CCM Admin | Help | Component versions
which ccm version?
All lmhosts, hosts, NIC settings are ok?
After adding the server I did not reboot the cluster. I rebooted the publisher and the new subscriber.
All Lmhost and host files are complete and NIC setting are all full 1000.
CCM version: 4.2.3 ES42
Jason
103
