no message from disconnected numbers
We are running Callmanager 4.1 and a cisco 2811 router as a voice gateway connected to the pstn over a PRI. Everything runs good except when a user dials a number that is no longer in service they receive silence instead of the message saying that the number is no longer in service. We are not getting any errors on the callmanager. We spoke with the Telco and they are telling us that, of course, there are no problems on their side. Any help would be greatly appreciated.
Bronze
Re: no message from disconnected numbers
hi,
"voice call convert-discpi-to-prog" command
should help you.
regards
mehmet
Thanks for the prompt reply mehmet. I added that line to the config and then tested but it does not appear to make a difference. Did a debug isdn q931 to see what was happening. Here's the results:
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98396
Exclusive, Channel 22
Calling Party Number i = 0x2181, ''
Plan:ISDN, Type:National
Called Party Number i = 0xA1, ''
Jan 18 21:40:10.195: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x
435
Jan 18 21:40:10.315: ISDN Se0/0/0:23 Q931: RX <- ALERTING pd = 8 callref = 0x8
34
Progress Ind i = 0x8488 - In-band info or appropriate now available
Jan 18 21:40:10.855: ISDN Se0/0/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x8
35
Cause i = 0x82BF - Service/option not available, unspecified
Jan 18 21:40:10.859: ISDN Se0/0/0:23 Q931: TX -> STATUS pd = 8 callref = 0x043
Cause i = 0x80E408 - Invalid information element contents
Call State i = 0x04
Jan 18 21:40:12.475: ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0
0018
Cause i = 0x8090 - Normal call clearing
Thanks for the help.
Does anyone know if you can customize this "non working" number message? I suppose you could link it Unity to call handler, play a message, hang up.. correct?
Hall of Fame Super Gold
Hello tcatlins,
Here is the full URL that explain how and when the PI conversion is necessary
http://cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a0080111b58.shtml
In your case, I would first verify that the annoucement is present indeed. The 'hard' way to do this, is using a circuit analyzer that has audio output, eg the DA-30.
In 'software' you can enable debugs on the gateway to verify that the RTP stram is generated, and capture to check that is not of silence only.
Bronze
Hello Orva,
Were you able to resolve the silence message receiving from telco. If so, could you please share it with me. I have the same problem.
MK
Hello MK,
No we haven't been able to resolve it yet. What we did as a workaround was put the number string they would dial in as a route pattern and set it to "block this pattern" that way they at least got a reorder tone. Obviously this isn't the greatest workaround for two reasons. 1) if the number ever becomes active you can't dial it and 2) your users have to let you know when they find another one with the same problem and you have to enter it also. If you find an answer to the problem please let me know.
Bud,
What switch-type are you running. I had this same issue and in talking to Telco, they were taking protocol errors. I am running 5ESS and telco is running custom-5ESS and I am experiencing the same issue. Let me know if this is what you have as well.
243
