Hall of Fame Super Gold
No missed calls are shown in 8.0(3) for 7912
Just found another bug for the too long list. The above defect showed after an upgrade. Downgraded to 8.0(2) and missed calls are OK.
This is with CME, not sure if it happens with CCM too.
1 REPLY
Bronze
Re: No missed calls are shown in 8.0(3) for 7912
Hi Paolo, did you have seen a similar issue with the ip phones 7941/61 in CUCM?, My problem is that the missed calls only shows the Voicemail port number. I'm using CUCM7+CUC7.
Thanks a lot
David
179
