No Mobility "Primary User Device" drop-down for end users
I am attempting to set up Unified Mobility for the first time in CUCM 9.1.2. I have ensured that the Cisco Unified Mobile Voice Access Service is activated and running on the server. However, when I go to the end user there is no field for Primary User Device under the Enable Mobility check box. (I have attached a screenshot.) I feel like something necessary must not be turned on, since even the Help section says there should be a Primary User Device drop-down there. I have several devices (an 8961 and 8851) assigned to me. Any ideas? Thank you.
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hi there,That field has been
Hi there,
That field has been removed in CUCM 9.x, where we moved on to ELM, as its only purpose was DLU calculation:
https://tools.cisco.com/bugsearch/bug/CSCub89839
Hope that helps,
-Mateusz
Hi there,
Hope that helps,
-Mateusz
Great. Thank you for the
Great. Thank you for the reply.
43
