No Modem Country command available
I have a PVDM2-12DM along with a NM-1CE1T1-PRI. I'm running (C2800NM-ENTSERVICESK9-M), Version 12.4(3g. The Modem Country command is not available in this IOS. I assume the modem country command is mandatory. Do I need to be running a different IOS (hopefully not AES)???
thanks in advance
1 REPLY
Bronze
Re: No Modem Country command available
The DM module requires a minimum of either 12.4T or 12.4XW and it is depending on your PSTN hardware interface. You can also set country codes using the Cisco IOS modem country command. For more information, see the Cisco IOS configuration guides and command references. The modem country command takes effect immediately, but all active calls are dropped.
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t11/htpvdm2.html
97
