No more MTP resources available
I am getting the following error in my event logs of our subscriber server running call manager4.2(3)sr1 and OS version 200.4.1. We are having problems calling internally to them and also 10 digit dialing them. Whenever we try to call them we get a busy signal. The problem is very intermittent, sometimes we are able to get through, other times we get a busy signal. Any ideas what this error message means?
Event Type: Error
Error: MtpNoMoreResourcesAvailable - No more MTP resources available.
App ID: Cisco CallManager
Cluster ID: StandAloneCluster
Explanation: MTP resource is not available.
Recommended Action: Install additional MTP or transcoder resources..
Re: No more MTP resources available
Green
This error normally means a codec negotitation problem.
If using MOH select all codecs under Service Parameters for IPVMS service.
The test is IP to IP Phone call or something is in the middle? like IPCC etc...
We had one of our Cisco techs out changing our codec to 729 externally and 711 internally. All of our other subscribers are working properly. I wasn't there when he set it up. Any ideas what I can do to check if thats the problem?
Green
Check Region configuration.
And if H323, SIP check voip dial-peers and codecs configured.
I checked the region configuration, all the locations appear to be consistent. I checked the SIP and the H323, but aren't those values clusterwide? so If its working on all the other subscribers why would there be a problem with only one of them?
Green
I would gather ccm detailed trace to narrow down the problem and see what exactly is happening
Well we had to contact the cisco rep who did the codec changes for us. It seems that there were several issues all at once. First we were having problems with our PRI going up and down and secondly useres kept getting bandwidth errors because the router was misconfigured to 256k instead of unlimited. Once we got those resolved the calls started working again. Thanks so much for all of your help!
370
