No More MTP Resources available?
Hello! I have CUCM 6.01 using SOFTWARE conference bridge. Everything is configured correctly, registered, running, etc. But when i try to add more than 3 people to a conference call, it drops or busy signal. Software is pretty straight forward, so Im not sure why its failing. My codecs are all G711, same region, same location, etc. Meet-Me max is set to 8 (default is 4)
Green
Re: No More MTP Resources available?
Which Phones any IP Communicator involved?
Using under Audio Optimize for Low Bandwith....?
Do you have the CCM detailed trace?
No communicator involved
Audio is unlimited at this site.
What type of traces?
Green
SDI CCM (cisco CallManager Detailed traces)
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml#calm
Include Calling number, called and timestamps
If you can try using RTMT to see Streams vailable for that CFB. Or perhaps restarting IPVMS service.
Traces will tell us what is the problem
Yeah, Im not sure whats going, but now its working. I did restart the CFB on Sub and Pub. Automagically it started working again. odd.
Simple. Please have the value changed on your service parameters, change "Maximum Ad Hoc" value to suit your need. Also since you are using g711, prioritize your software resource on Media Resources List. This should help.
202
