Community Member
no negotiated nte payload / no dtmf tones on SIP
I'm still struggeling on dtmf tones within my router. While the SCCP Phones are working well, the SIP phones do not generate any DTMF tones. Problem occurs external and internal (e.g. when the SIP Phone calls the mailbox)
Unfortunately the first on-hand solution (adding "pass-thru content sdp" in voice service voip / sip) didn't worked out. After adding this there is no more internal dial (SIP to SCCP) possible.
Configuration and debug attached.
Any ideas ?
Regards, Frank
****************** Configuration ************************
version 15.2
boot-start-marker
boot-end-marker
no logging buffered
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
network-clock-participate wic 1
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip dhcp relay information trust-all
ip dhcp excluded-address 10.10.10.1 10.10.10.10
ip dhcp pool phone
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 217.0.43.97 217.0.43.113
option 150 ip 10.10.10.1
ip name-server 217.0.43.97
ip cef
no ipv6 cef
voice rtp send-recv
voice service voip
ip address trusted list
  no ip address trusted authenticate
callmonitor
no callmonitor trace
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip handle-replaces
sip
  registrar server expires max 3600 min 180
  asymmetric payload full
  video screening
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g723r53
codec preference 4 g729r8
codec preference 5 g729br8
codec preference 6 g726r32
codec preference 7 g728
voice register global
mode cme
source-address 10.10.10.1 port 5060
max-dn 10
max-pool 4
load 9971 sip9971.9-3-2SR1-1
authenticate register
authenticate realm all
timezone 21
time-format 24
date-format D/M/Y
voicemail 999
tftp-path flash:
file text
create profile sync 0000420080667251
network-locale DE
user-locale DE
camera
video
overlap-signal
voice register dn  1
number 91
allow watch
no-reg
mwi
voice register pool  1
registration-timer max 300 min 60
id mac 0008.3030.6AAA
session-transport tcp
type 9971
number 1 dn 1
template 1
voice-class codec 1
username cisco password cisco
no vad
camera
video
voice translation-rule 1
rule 2 /^\(\+..\)\(.*\)/ /0\2/
voice translation-rule 2
rule 1 /123456/ /91/
voice translation-rule 3
rule 1 /^.*/ /123456/
voice translation-profile IN
translate calling 1
translate called 2
voice translation-profile OUT
translate calling 3
voice-card 0
license udi pid C1861-UC-B/K9-MS sn FHK144871U3
file privilege 0
no ip ftp passive
interface FastEthernet0/0
description ***ISP Provider***
ip address dhcp
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Integrated-Service-Engine0/0
ip unnumbered Vlan1
ip nat inside
service-module ip address 10.10.10.2 255.255.255.0
service-module ip default-gateway 10.10.10.1
interface Vlan1
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication aaa
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
ip nat inside source list 1 interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 87.186.225.92 254
ip route 10.10.10.2 255.255.255.255 Integrated-Service-Engine0/0
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 1 permit 192.168.2.0 0.0.0.255
control-plane
voice-port 0/0/0
cptone DE
station-id number 94
caller-id enable
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control
description Music On Hold Port
mgcp profile default
dial-peer voice 4 voip
description **Outgoing VOIP**
translation-profile outgoing OUT
destination-pattern ...T
session protocol sipv2
session target dns:tel.t-online.de
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 10 voip
description **Incoming VOIP**
translation-profile incoming IN
session target ipv4:10.10.10.1
incoming called-number 123456
dtmf-relay rtp-nte
no vad
dial-peer voice 20 voip
description **Mailbox**
destination-pattern 99.
session target ipv4:10.10.10.2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 19 pots
destination-pattern 94
port 0/0/0
no sip-register
presence
presence call-list
sip-ua
credentials username 123456 password ***password*** realm tel.t-online.de
authentication username ***user*** password ***password*** realm tel.t-online.de
nat symmetric role active
nat symmetric check-media-src
no remote-party-id
retry invite 4
retry response 3
retry bye 2
retry cancel 2
retry notify 6
retry register 5
retry options 10
timers connect 100
timers notify 100
timers register 250
mwi-server ipv4:10.10.10.2 expires 3600 port 5060 transport udp
registrar 1 dns:tel.t-online.de expires 3600
sip-server dns:tel.t-online.de
connection-reuse
host-registrar
presence enable
telephony-service
no auto-reg-ephone
max-ephones 12
max-dn 30
ip source-address 10.10.10.1 port 2000
max-redirect 5
timeouts interdigit 2
url services http://10.10.10.2/voiceview/common/login.do
cnf-file location flash:
user-locale U1 load CME-locale-de_DE-German-8.8.2.5.tar
load 7925 CP7925G-1.4.4.3.LOADS
time-zone 23
time-format 24
date-format dd-mm-yy
voicemail 999
max-conferences 4 gain -6
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 Nov 11 2013 14:07:24
ephone-dn  1  dual-line
number 92 no-reg primary
label IP-Mobil-1
description IP-Mobil-1
name IP-Mobil-1
allow watch
ephone-dn  2  dual-line
number 93 no-reg primary
label IP-Mobil-2
description IP-Mobil-2
name IP-Mobil-2
allow watch
ephone  1
device-security-mode none
mac-address E05F.B9BC.74CE
max-calls-per-button 4
type 7925
button  1:1
ephone  2
mac-address E05F.B9BB.F4D9
type 7925
button  1:2
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
access-class 102 in
privilege level 15
transport input all
transport output all
line vty 5 15
access-class 101 in
exec-timeout 30 0
privilege level 15
transport input all
end
**********debug (SIP Phone calls Unity Express Mailbox System) ***********
*Nov 11 19:29:14.642: //-1/6226DD5D8211/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabledimageattr parse payload numtok not foundimageattr payload found, specific is 255
*Nov 11 19:29:14.642: //556/6226DD5D8211/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.10.10.1
*Nov 11 19:29:14.642: //556/6226DD5D8211/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 2 = 10.10.10.1
*Nov 11 19:29:14.642: //556/6226DD5D8211/SIP/Media/sipSPIDoMediaNegotiation: DO_Media_Negotiation: video m-line detected.
*Nov 11 19:29:14.642: //556/6226DD5D8211/SIP/Media/sipSPIUpdCallWithSdpInfo:
Preferred Codec        : g711alaw, bytes :160
Preferred  DTMF relay  : inband-voice
Preferred NTE payload  : 101
Early Media            : No
Delayed Media          : No
Bridge Done            : No
New Media              : No
DSP DNLD Reqd          : No
*Nov 11 19:29:14.646: //556/6226DD5D8211/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.10.10.1
*Nov 11 19:29:14.646: //556/6226DD5D8211/SIP/Media/sipSPISelectCodecVersion: g729r8 flavor of g729 codec will be used
*Nov 11 19:29:14.646: //556/6226DD5D8211/SIP/Media/sipSPISelectCodecVersion: g722-64  flavor of G722 codec will be used
*Nov 11 19:29:14.646: //556/6226DD5D8211/SIP/Media/sipSPIDisplayStreamInfo:
  Stream type            : voice-only
  Media line             : 1
  State                  : STREAM_ADDING (2)
  Stream address type    : 1
  Callid                 : 556
  Peer Callid            : -1
  RTP/SRTP Negotiated     : 8
  Negotiated Codec       : g711alaw, bytes :160
  Nego. Codec payload    : 8 (tx), 8 (rx)
  Negotiated DTMF relay  : inband-voice
  Negotiated NTE payload : 0 (tx), 0 (rx)
  Negotiated CN payload  : 0
  Media Srce Addr/Port   : [10.10.10.1]:0
  Media Dest Addr/Port   : [10.10.10.12]:17166
  Stream type            : video
  Media line             : 2
  Callid                 : 557
  Peer Callid            : -1
  Negotiated Codec       : h264, bytes
  Nego. Codec payload    : 97 (tx), 119 (rx)
  Media Dest Addr/Port   : [10.10.10.12]:28736
*Nov 11 19:29:14.646: //556/6226DD5D8211/SIP/Media/sipSPIUpdCallWithSdpInfo:
  Media line             : 1
  Callid                 : 556
*Nov 11 19:29:14.646: //556/6226DD5D8211/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 2 = 10.10.10.1
  Stream type            : video
  Media line             : 2
  Callid                 : 557
*Nov 11 19:29:14.646: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 16662 for stream 1
*Nov 11 19:29:14.646: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 16664 for stream 2
*Nov 11 19:29:14.650: //556/6226DD5D8211/SIP/Media/sipSPIDisplayStreamInfo:
  Media line             : 1
  Callid                 : 556
  Peer Callid            : -1
  Media Srce Addr/Port   : [10.10.10.1]:16662
  Stream type            : video
  Media line             : 2
  Callid                 : 557
  Peer Callid            : -1
  Media Srce Addr/Port   : [10.10.10.1]:16664
*Nov 11 19:29:14.682: //558/6226DD5D8211/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
*Nov 11 19:29:14.682: //558/6226DD5D8211/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.10.10.1
*Nov 11 19:29:14.682: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 16666 for stream 1
*Nov 11 19:29:14.682: //558/6226DD5D8211/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
*Nov 11 19:29:14.682: //558/6226DD5D8211/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 2 = 10.10.10.1
*Nov 11 19:29:14.682: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 16668 for stream 2
*Nov 11 19:29:14.682: //558/6226DD5D8211/SIP/Media/sipSPI_ipip_UpdateSDPVideoMediaPayload: update ccb->pld.negotiated_bandwidth with current_max_bit_rate (100bps):10000
*Nov 11 19:29:14.682: //558/6226DD5D8211/SIP/Media/sipSPI_ipip_UpdateSDPVideoMediaPayload: VIDEO m-line 2, set ccb negotiated_bandwidth (kbps):1000; current_max_bit_rate:10000, local_bandwidth_req (kbps):0, remote_bandwidth_req (kbps):0
*Nov 11 19:29:14.682: //558/6226DD5D8211/SIP/Media/sipSPIProcessRtpSessions: Processing stream state = STREAM_IDLE
*Nov 11 19:29:14.682: //558/6226DD5D8211/SIP/Media/sipSPIProcessRtpSessions: No active streams.
*Nov 11 19:29:14.686: //558/6226DD5D8211/SIP/Media/sipSPIProcessRtpSessions: Processing stream state = STREAM_ADDING
*Nov 11 19:29:14.686: //558/6226DD5D8211/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 558) to the VOIP RTP library
*Nov 11 19:29:14.686: //558/6226DD5D8211/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.10.10.1
*Nov 11 19:29:14.686: //558/6226DD5D8211/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
*Nov 11 19:29:14.690: //558/6226DD5D8211/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 10.10.10.1, lport = 16666, raddr = 0.0.0.0, rport=0, do_rtcp=FALSE
src_callid = 558, dest_callid = -1, stream type = voice+dtmf, stream direction = RECVONLY
media_ip_addr =  - , vrf tableid = 0 media_addr_type = 1          negotiated_bandwidth (kbps) = 0
*Nov 11 19:29:14.690: //558/6226DD5D8211/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
*Nov 11 19:29:14.690: //558/6226DD5D8211/SIP/Media/sipSPICreateRtpSession: stun is disabled
*Nov 11 19:29:14.690: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: Voice quality monitoring is not enabled for this RTP session due to sdp passthru enabled
*Nov 11 19:29:14.690: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: VQM: gccb=0x0, gccb->callId=0, ccb->ccCallID=558
*Nov 11 19:29:14.806: //558/6226DD5D8211/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.10.10.1
*Nov 11 19:29:14.810: //558/6226DD5D8211/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
*Nov 11 19:29:14.810: //558/6226DD5D8211/SIP/Media/sipSPIUpdCallWithSdpInfo:
Preferred  DTMF relay  : rtp-nte
Early Media            : No
Delayed Media          : No
Bridge Done            : No
New Media              : No
DSP DNLD Reqd          : No
*Nov 11 19:29:14.810: //558/6226DD5D8211/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.10.10.1
*Nov 11 19:29:14.810: //558/6226DD5D8211/SIP/Media/sipSPIDisplayStreamInfo:
  Stream type            : voice+dtmf
  Media line             : 1
  Callid                 : 558
  Peer Callid            : -1
  Negotiated Codec       : g711ulaw, bytes :160
  Nego. Codec payload    : 0 (tx), 0 (rx)
  Negotiated DTMF relay  : rtp-nte
  Negotiated NTE payload : 101 (tx), 101 (rx)
  Media Srce Addr/Port   : [10.10.10.1]:16666
  Media Dest Addr/Port   : [10.10.10.2]:21046
*Nov 11 19:29:14.810: //556/6226DD5D8211/SIP/Media/sipSPISetStreamInfo: 0 Active Streams
*Nov 11 19:29:14.810: //556/6226DD5D8211/SIP/Media/sipSPISetStreamInfo: Number of active streams is zero (0)!
caps.stream_count=0,caps.stream[0].stream_type=0xFFFF, caps.stream_list.xmitFunc=
*Nov 11 19:29:14.810: //556/6226DD5D8211/SIP/Media/sipSPISetStreamInfo: ??unknown??, caps.stream_list.context=
*Nov 11 19:29:14.810: //556/6226DD5D8211/SIP/Media/sipSPISetStreamInfo: 0x0 (gccb)
  Media line             : 1
  Callid                 : 558
*Nov 11 19:29:14.814: //558/6226DD5D8211/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:8B7786D0
*Nov 11 19:29:14.818: //556/6226DD5D8211/SIP/Media/sipSPIProcessRtpSessions: Processing stream state = STREAM_ADDING
*Nov 11 19:29:14.818: //556/6226DD5D8211/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice-only (callid 556) to the VOIP RTP library
*Nov 11 19:29:14.818: //556/6226DD5D8211/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.10.10.1
*Nov 11 19:29:14.818: //556/6226DD5D8211/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
*Nov 11 19:29:14.818: //556/6226DD5D8211/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 10.10.10.1, lport = 16662, raddr = 10.10.10.12, rport=17166, do_rtcp=TRUE
src_callid = 556, dest_callid = 558, stream type = voice-only, stream direction = SENDRECV
media_ip_addr = 10.10.10.12, vrf tableid = 0 media_addr_type = 1          negotiated_bandwidth (kbps) = 0
*Nov 11 19:29:14.818: //556/6226DD5D8211/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
*Nov 11 19:29:14.818: //556/6226DD5D8211/SIP/Media/sipSPICreateRtpSession: stun is disabled
*Nov 11 19:29:14.818: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: Voice quality monitoring is not enabled for this RTP session due to sdp passthru enabled
*Nov 11 19:29:14.818: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: VQM: gccb=0x0, gccb->callId=0, ccb->ccCallID=556
*Nov 11 19:29:14.818: //556/6226DD5D8211/SIP/Media/sipSPIGetNewLocalMediaDirection:
New Remote Media Direction = SENDRECV
Present Local Media Direction = SENDRECV
New Local Media Direction = SENDRECV
retVal = 0
*Nov 11 19:29:14.822: //558/6226DD5D8211/SIP/Media/sipSPIProcessRtpSessions: Processing stream state = STREAM_ADDING
*Nov 11 19:29:14.822: //558/6226DD5D8211/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 558) to the VOIP RTP library
*Nov 11 19:29:14.822: //558/6226DD5D8211/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.10.10.1
*Nov 11 19:29:14.822: //558/6226DD5D8211/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
*Nov 11 19:29:14.822: //558/6226DD5D8211/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 10.10.10.1, lport = 16666, raddr = 10.10.10.2, rport=21046, do_rtcp=TRUE
src_callid = 558, dest_callid = 556, stream type = voice+dtmf, stream direction = SENDRECV
media_ip_addr = 10.10.10.2, vrf tableid = 0 media_addr_type = 1          negotiated_bandwidth (kbps) = 0
*Nov 11 19:29:14.822: //558/6226DD5D8211/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
*Nov 11 19:29:14.822: //558/6226DD5D8211/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:8B7786D0
*Nov 11 19:29:14.822: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: VQM: gccb=0x0, gccb->callId=0, ccb->ccCallID=558
*Nov 11 19:29:14.822: //558/6226DD5D8211/SIP/Media/sipSPIGetNewLocalMediaDirection:
retVal = 0
*Nov 11 19:29:14.850: //558/6226DD5D8211/SIP/Media/act_update_nat_media: NEW: rtp session to be updated with the new src info, old addr:port [10.10.10.2]:21046 , newaddr:port [10.10.10.2]:21046
*Nov 11 19:29:14.850: //558/6226DD5D8211/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:8B7786D0
*Nov 11 19:29:14.898: //556/6226DD5D8211/SIP/Media/act_update_nat_media: NEW: rtp session to be updated with the new src info, old addr:port [10.10.10.12]:17166 , newaddr:port [10.10.10.12]:17166
*Nov 11 19:29:14.902: //556/6226DD5D8211/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:8D6F25F8
*Nov 11 19:29:34.322: //556/6226DD5D8211/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:8D6F25F8
*Nov 11 19:29:34.322: //558/6226DD5D8211/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:8B7786D0
*Nov 11 19:29:34.326: //556/6226DD5D8211/SIP/Media/sipSPIHandleDestroyRtpSession: stream:8D6F25F8
*Nov 11 19:29:34.338: //558/6226DD5D8211/SIP/Media/sipSPIHandleDestroyRtpSession: stream:8B7786D0
*Nov 11 19:31:36.042: //565/B61D0194821B/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
*Nov 11 19:31:36.042: //565/B61D0194821B/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.10.10.1
*Nov 11 19:31:36.042: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 16670 for stream 1
*Nov 11 19:31:36.042: //565/B61D0194821B/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
*Nov 11 19:31:36.042: //565/B61D0194821B/SIP/Media/sipSPIProcessRtpSessions: Processing stream state = STREAM_IDLE
*Nov 11 19:31:36.042: //565/B61D0194821B/SIP/Media/sipSPIProcessRtpSessions: No active streams.
*Nov 11 19:31:36.046: //565/B61D0194821B/SIP/Media/sipSPIProcessRtpSessions: Processing stream state = STREAM_ADDING
*Nov 11 19:31:36.046: //565/B61D0194821B/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 565) to the VOIP RTP library
*Nov 11 19:31:36.046: //565/B61D0194821B/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.10.10.1
*Nov 11 19:31:36.046: //565/B61D0194821B/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
*Nov 11 19:31:36.046: //565/B61D0194821B/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 10.10.10.1, lport = 16670, raddr = 0.0.0.0, rport=0, do_rtcp=FALSE
src_callid = 565, dest_callid = -1, stream type = voice+dtmf, stream direction = RECVONLY
*Nov 11 19:31:36.046: //565/B61D0194821B/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
*Nov 11 19:31:36.046: //565/B61D0194821B/SIP/Media/sipSPICreateRtpSession: stun is disabled
*Nov 11 19:31:36.046: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: Voice quality monitoring is not enabled for this RTP session due to sdp passthru enabled
*Nov 11 19:31:36.046: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: VQM: gccb=0x0, gccb->callId=0, ccb->ccCallID=565
*Nov 11 19:31:36.170: //565/B61D0194821B/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.10.10.1
*Nov 11 19:31:36.170: //565/B61D0194821B/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
*Nov 11 19:31:36.170: //565/B61D0194821B/SIP/Media/sipSPIUpdCallWithSdpInfo:
Early Media            : No
Delayed Media          : No
Bridge Done            : No
New Media              : No
DSP DNLD Reqd          : No
*Nov 11 19:31:36.174: //565/B61D0194821B/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.10.10.1
*Nov 11 19:31:36.174: //565/B61D0194821B/SIP/Media/sipSPIUpdCallWithSdpInfo:
  Media line             : 1
  Callid                 : 565
  Media Srce Addr/Port   : [10.10.10.1]:16670
  Media Dest Addr/Port   : [10.10.10.2]:21114
*Nov 11 19:31:36.174: //565/B61D0194821B/SIP/Media/sipSPIProcessRtpSessions: Processing stream state = STREAM_ADDING
*Nov 11 19:31:36.178: //565/B61D0194821B/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 565) to the VOIP RTP library
*Nov 11 19:31:36.178: //565/B61D0194821B/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.10.10.1
*Nov 11 19:31:36.178: //565/B61D0194821B/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
*Nov 11 19:31:36.178: //565/B61D0194821B/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 10.10.10.1, lport = 16670, raddr = 10.10.10.2, rport=21114, do_rtcp=TRUE
src_callid = 565, dest_callid = 564, stream type = voice+dtmf, stream direction = SENDRECV
*Nov 11 19:31:36.178: //565/B61D0194821B/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
*Nov 11 19:31:36.178: //565/B61D0194821B/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:8D6C478C
*Nov 11 19:31:36.178: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: VQM: gccb=0x0, gccb->callId=0, ccb->ccCallID=565
*Nov 11 19:31:36.178: //565/B61D0194821B/SIP/Media/sipSPIGetNewLocalMediaDirection:
retVal = 0
*Nov 11 19:31:36.178: //565/B61D0194821B/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
*Nov 11 19:31:36.178: //565/B61D0194821B/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice+dtmf) from media
line 1 codec g711ulaw
caps.stream_count=1,caps.stream[0].stream_type=0x3, caps.stream_list.xmitFunc=
*Nov 11 19:31:36.178: //565/B61D0194821B/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
*Nov 11 19:31:36.178: //565/B61D0194821B/SIP/Media/sipSPISetStreamInfo: 0x8D6F1880 (gccb)
*Nov 11 19:31:36.218: //565/B61D0194821B/SIP/Media/act_update_nat_media: NEW: rtp session to be updated with the new src info, old addr:port [10.10.10.2]:21114 , newaddr:port [10.10.10.2]:21114
*Nov 11 19:31:36.218: //565/B61D0194821B/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:8D6C478C
*Nov 11 19:31:43.474: //565/B61D0194821B/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:8D6C478C
*Nov 11 19:31:43.490: //565/B61D0194821B/SIP/Media/sipSPIHandleDestroyRtpSession: stream:8D6C478C
*Nov 11 19:45:41.206: //-1/AE3093EE8227/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabledimageattr parse payload numtok not foundimageattr payload found, specific is 255
*Nov 11 19:45:41.206: //589/AE3093EE8227/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.10.10.1
*Nov 11 19:45:41.210: //589/AE3093EE8227/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 2 = 10.10.10.1
*Nov 11 19:45:41.210: //589/AE3093EE8227/SIP/Media/sipSPIDoMediaNegotiation: DO_Media_Negotiation: video m-line detected.
*Nov 11 19:45:41.210: //589/AE3093EE8227/SIP/Media/sipSPIUpdCallWithSdpInfo:
Early Media            : No
Delayed Media          : No
Bridge Done            : No
New Media              : No
DSP DNLD Reqd          : No
*Nov 11 19:45:41.210: //589/AE3093EE8227/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.10.10.1
*Nov 11 19:45:41.210: //589/AE3093EE8227/SIP/Media/sipSPISelectCodecVersion: g729r8 flavor of g729 codec will be used
*Nov 11 19:45:41.210: //589/AE3093EE8227/SIP/Media/sipSPISelectCodecVersion: g722-64  flavor of G722 codec will be used
*Nov 11 19:45:41.210: //589/AE3093EE8227/SIP/Media/sipSPIDisplayStreamInfo:
  Media line             : 1
  Callid                 : 589
  Peer Callid            : -1
  Media Dest Addr/Port   : [10.10.10.12]:20200
  Stream type            : video
  Media line             : 2
  Callid                 : 590
  Peer Callid            : -1
  Media Dest Addr/Port   : [10.10.10.12]:22496
  Media line             : 1
  Callid                 : 589
  Stream type            : video
  Media line             : 2
  Callid                 : 590
*Nov 11 19:45:41.210: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 16672 for stream 1
*Nov 11 19:45:41.210: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 16674 for stream 2
*Nov 11 19:45:41.214: //589/AE3093EE8227/SIP/Media/sipSPIDisplayStreamInfo:
  Media line             : 1
  Callid                 : 589
  Peer Callid            : -1
  Media Srce Addr/Port   : [10.10.10.1]:16672
  Stream type            : video
  Media line             : 2
  Callid                 : 590
  Peer Callid            : -1
  Media Srce Addr/Port   : [10.10.10.1]:16674
*Nov 11 19:45:41.230: //591/AE3093EE8227/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
*Nov 11 19:45:41.230: //591/AE3093EE8227/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.10.10.1
*Nov 11 19:45:41.230: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 16676 for stream 1
*Nov 11 19:45:41.230: //591/AE3093EE8227/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
*Nov 11 19:45:41.234: //591/AE3093EE8227/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 2 = 10.10.10.1
*Nov 11 19:45:41.234: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 16678 for stream 2
*Nov 11 19:45:41.234: //591/AE3093EE8227/SIP/Media/sipSPI_ipip_UpdateSDPVideoMediaPayload: update ccb->pld.negotiated_bandwidth with current_max_bit_rate (100bps):10000
*Nov 11 19:45:41.234: //591/AE3093EE8227/SIP/Media/sipSPI_ipip_UpdateSDPVideoMediaPayload: VIDEO m-line 2, set ccb negotiated_bandwidth (kbps):1000; current_max_bit_rate:10000, local_bandwidth_req (kbps):0, remote_bandwidth_req (kbps):0
*Nov 11 19:45:41.234: //591/AE3093EE8227/SIP/Media/sipSPIProcessRtpSessions: Processing stream state = STREAM_IDLE
*Nov 11 19:45:41.234: //591/AE3093EE8227/SIP/Media/sipSPIProcessRtpSessions: No active streams.
*Nov 11 19:45:41.238: //591/AE3093EE8227/SIP/Media/sipSPIProcessRtpSessions: Processing stream state = STREAM_ADDING
*Nov 11 19:45:41.238: //591/AE3093EE8227/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 591) to the VOIP RTP library
*Nov 11 19:45:41.238: //591/AE3093EE8227/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.10.10.1
*Nov 11 19:45:41.238: //591/AE3093EE8227/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
*Nov 11 19:45:41.238: //591/AE3093EE8227/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 10.10.10.1, lport = 16676, raddr = 0.0.0.0, rport=0, do_rtcp=FALSE
src_callid = 591, dest_callid = -1, stream type = voice+dtmf, stream direction = RECVONLY
*Nov 11 19:45:41.238: //591/AE3093EE8227/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
*Nov 11 19:45:41.238: //591/AE3093EE8227/SIP/Media/sipSPICreateRtpSession: stun is disabled
*Nov 11 19:45:41.238: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: Voice quality monitoring is not enabled for this RTP session due to sdp passthru enabled
*Nov 11 19:45:41.238: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: VQM: gccb=0x0, gccb->callId=0, ccb->ccCallID=591
*Nov 11 19:45:41.350: //591/AE3093EE8227/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.10.10.1
*Nov 11 19:45:41.350: //591/AE3093EE8227/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
*Nov 11 19:45:41.350: //591/AE3093EE8227/SIP/Media/sipSPIUpdCallWithSdpInfo:
Early Media            : No
Delayed Media          : No
Bridge Done            : No
New Media              : No
DSP DNLD Reqd          : No
*Nov 11 19:45:41.350: //591/AE3093EE8227/SIP/Media/sipSPIDisplayStreamInfo:
  Media line             : 1
  Callid                 : 591
  Peer Callid            : -1
  Media Srce Addr/Port   : [10.10.10.1]:16676
  Media Dest Addr/Port   : [10.10.10.2]:20670
*Nov 11 19:45:41.354: //589/AE3093EE8227/SIP/Media/sipSPISetStreamInfo: 0 Active Streams
*Nov 11 19:45:41.354: //589/AE3093EE8227/SIP/Media/sipSPISetStreamInfo: Number of active streams is zero (0)!
*Nov 11 19:45:41.354: //589/AE3093EE8227/SIP/Media/sipSPISetStreamInfo: ??unknown??, caps.stream_list.context=
*Nov 11 19:45:41.354: //589/AE3093EE8227/SIP/Media/sipSPISetStreamInfo: 0x0 (gccb)
*Nov 11 19:45:41.354: //591/AE3093EE8227/SIP/Media/sipSPIUpdCallWithSdpInfo:
  Media line             : 1
  Callid                 : 591
*Nov 11 19:45:41.354: //591/AE3093EE8227/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:8D6E4A28
*Nov 11 19:45:41.362: //589/AE3093EE8227/SIP/Media/sipSPIProcessRtpSessions: Processing stream state = STREAM_ADDING
*Nov 11 19:45:41.362: //589/AE3093EE8227/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice-only (callid 589) to the VOIP RTP library
*Nov 11 19:45:41.362: //589/AE3093EE8227/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.10.10.1
*Nov 11 19:45:41.362: //589/AE3093EE8227/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
*Nov 11 19:45:41.362: //589/AE3093EE8227/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 10.10.10.1, lport = 16672, raddr = 10.10.10.12, rport=20200, do_rtcp=TRUE
src_callid = 589, dest_callid = 591, stream type = voice-only, stream direction = SENDRECV
*Nov 11 19:45:41.362: //589/AE3093EE8227/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
*Nov 11 19:45:41.362: //589/AE3093EE8227/SIP/Media/sipSPICreateRtpSession: stun is disabled
*Nov 11 19:45:41.362: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: Voice quality monitoring is not enabled for this RTP session due to sdp passthru enabled
*Nov 11 19:45:41.362: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: VQM: gccb=0x0, gccb->callId=0, ccb->ccCallID=589
*Nov 11 19:45:41.362: //589/AE3093EE8227/SIP/Media/sipSPIGetNewLocalMediaDirection:
retVal = 0
*Nov 11 19:45:41.362: //591/AE3093EE8227/SIP/Media/sipSPIProcessRtpSessions: Processing stream state = STREAM_ADDING
*Nov 11 19:45:41.362: //591/AE3093EE8227/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 591) to the VOIP RTP library
*Nov 11 19:45:41.362: //591/AE3093EE8227/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.10.10.1
*Nov 11 19:45:41.362: //591/AE3093EE8227/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
*Nov 11 19:45:41.362: //591/AE3093EE8227/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 10.10.10.1, lport = 16676, raddr = 10.10.10.2, rport=20670, do_rtcp=TRUE
src_callid = 591, dest_callid = 589, stream type = voice+dtmf, stream direction = SENDRECV
*Nov 11 19:45:41.362: //591/AE3093EE8227/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
*Nov 11 19:45:41.362: //591/AE3093EE8227/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:8D6E4A28
*Nov 11 19:45:41.362: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: VQM: gccb=0x0, gccb->callId=0, ccb->ccCallID=591
*Nov 11 19:45:41.362: //591/AE3093EE8227/SIP/Media/sipSPIGetNewLocalMediaDirection:
retVal = 0
*Nov 11 19:45:41.386: //591/AE3093EE8227/SIP/Media/act_update_nat_media: NEW: rtp session to be updated with the new src info, old addr:port [10.10.10.2]:20670 , newaddr:port [10.10.10.2]:20670
*Nov 11 19:45:41.386: //591/AE3093EE8227/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:8D6E4A28
*Nov 11 19:45:41.438: //589/AE3093EE8227/SIP/Media/act_update_nat_media: NEW: rtp session to be updated with the new src info, old addr:port [10.10.10.12]:20200 , newaddr:port [10.10.10.12]:20200
*Nov 11 19:45:41.438: //589/AE3093EE8227/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:8EE45620
*Nov 11 19:45:47.322: //589/AE3093EE8227/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:8EE45620
*Nov 11 19:45:47.322: //591/AE3093EE8227/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:8D6E4A28
*Nov 11 19:45:47.326: //589/AE3093EE8227/SIP/Media/sipSPIHandleDestroyRtpSession: stream:8EE45620
*Nov 11 19:45:47.338: //591/AE3093EE8227/SIP/Media/sipSPIHandleDestroyRtpSession: stream:8D6E4A28
Everyone's tags (3)
1 ACCEPTED SOLUTION
VIP Super Bronze
can you try this..
dtmf-relay rtp-nte
If it doesnt work pls send debug ccsip messages.
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
1 REPLY
VIP Super Bronze
can you try this..
dtmf-relay rtp-nte
1655
