Showing results forĀ
Search instead forĀ
Did you mean:Ā
No. of VWIC3-4MFT-T1/E1 cards on 3945E
rajnishkjha18
Hi All,
I wanted to know if I can put  two VWIC3-4MFT-T1/E1 and two VWIC3-2MFT-T1/E1in the same slot ( I want to use slot0 preferrably but open to any suggestion) on a Cisco 3945E Voice ISR. Basically, I want to replicate the T1 & E1 voice PRI connections that we've on the 6509 CatOS (we've 1*6608 T1 and 1*6608 E1 module on the 6509) on the 3945E. Also, please advise on the PVDM3 needed to accommodate the calls. I think I should be good with 2*PVDM-256 and 1*PVDM-128 on the motherboard. Will highly appreciate your inputs.
Thanks.
7 Replies 7
paolo bevilacqua
You state that you need 12x T1/E1 ports. For that you can use 3 x VWIC3-4MFT-T1/E1. These will fit directly into VWIC slow of the router. Then for a full E1 configuration (360 channels), you will need a minimum ox 1x PVDM3-256 and 1 x PVDM3-128.
Thank You Paolo for your response.
I want to keep T1 and E1 separate i.e. 6 T1 and 6 E1 for which I'll need 2*4MFT and 2*2MFT cards. Can all these 4 cards go into the slot0 module together? I'm not sure how many VWIC cards are supported in slot0 on 3945. On 3845, I think only 2 VWIC cards are supported in slot 0. To use the VWIC cards in another slot, we'll need to use NM-HDV2 flavor, right? Thanks.
           Again, there is no need for NM modules. The cards fits directly in the router, up to four.
Please remember to rate useful posts clicking on the stars below.
Senir Christian
I am kind of new to this area, are the VWIC3-4MFT-T1/E1 cards hot swapable? or if I need to insert another one..can I just slide it in to the 3945?
Hi Senir,
I was just referring the link for OIR[Online Insertion Removal].
http://www.cisco.com/en/US/docs/routers/access/2900/hardware/installation/guide/appendix.html
Can u just check in offline mode for command hw-module slot[1-4] oir-stop ?
regds,
aman
Again: there is no support for OIR on VWIC, and no "surprise insertion" support for any module.
Hi Paolo,
Thanks for confirming(+5)
regds,
aman
