No option to configure VoIP dial-peer???
Hi all,
I have seen a very weird problem with a 2811 Voice GW.
I am not able to configure VoIP dial-peer. It's giving just POTS options like below.
DHL-VG-TH(config)#dial-peer voice 1 ?
  pots  Telephony
  <cr>
I have attached the configurations and running on Voice IOS.
c2800nm-ipvoice-mz.124-4.t1.bin
Any advice?
Regards...
Ashok.
1 ACCEPTED SOLUTION
You have a Dial-peer 1 already
     dial-peer voice 1 pots
once a dial-peer is added as pots or voip you can not change it.
You will have to remove it or use another dial-peer number such as 10
Green
Can you post
show diag
Alex
Regards, Alex. Please rate useful posts.
Hi Alex,
Please find below....
VG-TH#sh diag
Slot 0:
        C2811 Motherboard with 2FE and integrated VPN Port adapter, 2 ports
        Port adapter is analyzed
        Port adapter insertion time unknown
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC10484PVK
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-26920-03
        Board Revision           : A0
        Deviation Number         : 0
        Fab Version              : 03
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 87
        Hardware date code       : 20061205
        Chassis Serial Number    : FHK1050F2BC
        Chassis MAC Address      : 001a.6d05.8b58
        MAC Address block size   : 24
        CLEI Code                : COM7C00ARA
        Product (FRU) Number     : CISCO2811
        Part Number              : 73-10258-04
        Version Identifier       : V04
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 30 34 38 34 50 56 4B 40
          0x10: 03 E7 41 01 00 C0 46 03 20 00 69 28 03 42 41 30
          0x20: 88 00 00 00 00 02 03 03 00 81 00 00 00 00 04 00
          0x30: 09 87 83 01 32 1C 15 C2 8B 46 48 4B 31 30 35 30
          0x40: 46 32 42 43 C3 06 00 1A 6D 05 8B 58 43 00 18 C6
          0x50: 8A 43 4F 4D 37 43 30 30 41 52 41 CB 8F 43 49 53
          0x60: 43 4F 32 38 31 31 20 20 20 20 20 20 82 49 28 12
          0x70: 04 89 56 30 34 20 D9 02 40 C1 FF FF FF FF FF FF
        WIC Slot 0:
        Serial 2T (12in1)
        Hardware revision 1.0           Board revision D0
        Serial number     24049180      Part number    800-03181-01
        FRU Part Number   WIC-2T=
        Test history      0x0           RMA number     00-00-00
        Connector type    PCI
        EEPROM format version 1
          0x20: 01 12 01 00 01 6E F6 1C 50 0C 6D 01 00 00 00 00
          0x30: 68 00 00 00 00 10 12 00 FF FF FF FF FF FF FF FF
        WIC Slot 2:
        2nd generation - FXS Voice daughter card (2 port)
        Hardware Revision        : 3.1
        Top Assy. Part Number    : 800-21341-02
        Board Revision           : B0
        Deviation Number         : 0-0
        Fab Version              : 01
        PCB Serial Number        : FOC111930T6
        RMA History              : 00
        Product (FRU) Number     : VIC2-2FXS
        Version Identifier       : V01
        CLEI Code                : CNUIAPPAAA
          0x00: 04 FF 40 00 47 41 03 01 C0 46 03 20 00 53 5D 02
          0x10: 42 42 30 80 00 00 00 00 02 01 C1 8B 46 4F 43 31
          0x20: 31 31 39 33 30 54 36 03 00 81 00 00 00 00 04 00
          0x30: CB 89 56 49 43 32 2D 32 46 58 53 89 56 30 31 20
          0x40: C6 8A 43 4E 55 49 41 50 50 41 41 41 FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
VG-TH#
Regards...
Ashok.
Green
Your diags shows that there is a lack of any DSP chips
Without the DSP you can not use VOIP
For 2 FXS ports you need a min of PVDM2-8
Alex
Hi Alex,
Ok.
But, I have other Voice GW with E1 card in it but no PVDMs. It's giving VoIP option.
VG-SG#sh diag
Slot 0:
        Port adapter insertion time 5d01h ago
        PCB Serial Number        : FOC1206028B
        Top Assy. Part Number    : 800-26920-04
        Board Revision           : A0
        Fab Version              : 04
        RMA History              : 00
        Processor type           : 87
        Hardware date code       : 20080202
        Chassis Serial Number    : FHK1207F3DZ
        Chassis MAC Address      : 001f.6c6f.7830
        CLEI Code                : COM7R00ARA
        Part Number              : 73-10258-05
        Version Identifier       : V05
          0x00: 04 FF C1 8B 46 4F 43 31 32 30 36 30 32 38 42 40
          0x10: 03 E7 41 01 00 C0 46 03 20 00 69 28 04 42 41 30
          0x20: 88 00 00 00 00 02 04 03 00 81 00 00 00 00 04 00
          0x30: 09 87 83 01 32 66 4A C2 8B 46 48 4B 31 32 30 37
          0x40: 46 33 44 5A C3 06 00 1F 6C 6F 78 30 43 00 18 C6
          0x50: 8A 43 4F 4D 37 52 30 30 41 52 41 CB 8F 43 49 53
          0x70: 05 89 56 30 35 20 D9 02 40 C1 FF FF FF FF FF FF
        WIC Slot 0:
        VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1
        Hardware Revision        : 0.0
        Top Assy. Part Number    : 800-22628-05
        Board Revision           : B0
        Fab Version              : 04
        PCB Serial Number        : FOC12294W2D
        RMA History              : 00
        Product (FRU) Number     : VWIC2-1MFT-T1/E1
          0x00: 04 FF 40 03 FD 41 00 00 C0 46 03 20 00 58 64 05
          0x10: 42 42 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 32 32 39 34 57 32 44 03 00 81 00 00 00 00 04 00
          0x30: CB 90 56 57 49 43 32 2D 31 4D 46 54 2D 54 31 2F
          0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
DHL-VG-SG#sh diag  | in PVDM
DHL-VG-SG#sh diag
Slot 0:
        Board Revision           : A0
        Fab Version              : 04
        RMA History              : 00
        Processor type           : 87
        WIC Slot 0:
        Board Revision           : B0
        Fab Version              : 04
        RMA History              : 00
VG-SG#
VG-SG(config)#dial-peer voice 1 ?
  mmoip  Multi Media Over IP
  pots   Telephony
  voatm  Voice over ATM
  vofr   Voice over Frame Relay
  voip   Voice over IP
Green
This is probably due to the IOS versions
Your 2811 is using 12.4.4T1  this has been retired by Cisco.
Not sure abot your other gateway.
Still think you need the DSP for VOIP working
Alex
Hi Kgroves,
Excellent observation.
Yes, that's the issue. Thanks a lot
Regards...
Ashok.
524
