no outbound dial on sip
while setting up my 1861E router i'm still facing problems with one sip-provider. While "sipgate.de" (when changing the translation rule 3 to the sipgate number and session target in dial-peer voice 1 voip to dns:sipgate.de) works fine, "tel.t-online.de" works only on incomming calls. Outgoing calls are not possible - there is always an busy signal after dialing the number.
Attached my configuration together with an sip debug of an outgoing call.
Anyone out there who has an idea?
Best regards, Frank
Everyone's tags (6)
2 ACCEPTED SOLUTIONS
Silver
You're getting a 404 Not Found from your SIP carrier.  Most likely your called number is not formatted properly.  You'll need to work with them to see what format the dialed number should be in.
It seems your TELCO doesnt like your Request URI. It seems the following number is not valid for your TELCO. Also the domain might be wrong, or the TELCO is not replying to that domain name.
INVITE sip:062092522707@tel.t-online.de:5060 SIP/2.0
Silver
Finally I made it by modifying the INVITE string by:
voice class sip-profiles 10
request INVITE sip-header From modify "<>phone-number@(.*)>" "<>phone-number@tel.t-online.de>"
request ANY sip-header From modify "Frank" "phone-number"
AND
voice service voip
   sip
     sip-profiles 10
Instead of "phone-number" you have to insert your sip phone number given by T-Online
T-Online expects the realm name in the From INVITE string. In addition the callers name needs to be replaced into the sip phone numer
Regards, Frank
797
