No outgoing calls on an MGCP gateway
Hi, can anyone please guide me as to what a fault this could be.
I have installed a gateway which is accessed from the voice vlan via a routed link. The router has 2 E1 (Vwic 2MFT G703) connections, one to a remote site, and the other to the PSTN for voice calls. I am getting the same error message when trying to make a voice call ?Resource Unavailable?. If I put the same gateway on the voice vlan with the remote site connections on another router, all work well( this was only carried out for testing purposes to check hardware)
The debug isdn q931 output is below:-
Config on next post
*Dec 6 23:54:58.983: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0001
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x0081, '01534814831'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '123'
*Dec 6 23:54:59.155: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8001
*Dec 6 23:54:59.167: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x0001
Cause i = 0x80AF - Resource unavailable, unspecified
*Dec 6 23:54:59.315: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x8001
*Dec 6 23:54:59.335: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0001
Re: No outgoing calls on an MGCP gateway
Building configuration...
Current configuration : 6762 bytes
version 12.4
hostname bedjesy2821vg1
boot-start-marker
boot system flash:c3845-spservicesk9-mz.124-10a.bin
boot-end-marker
card type e1 0 3
logging buffered 51200 warnings
no aaa new-model
resource policy
clock timezone GMT 0
clock summer-time BST recurring last Sun Mar 1:00 last Sun Oct 1:00
network-clock-participate wic 1
network-clock-participate wic 3
ip subnet-zero
ip cef
ip domain name xxxxxx
ip host ZJCM01 172.31.1.250
ip host ZJCM02 172.30.1.250
isdn switch-type primary-net5
voice-card 0
dspfarm
voice rtp send-recv
controller E1 0/1/0
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
description Connection to PSTN
controller E1 0/3/0
channel-group 0 unframed
controller E1 0/3/1
shutdown
interface GigabitEthernet0/0
description Private LAN
ip address 172.16.2.12 255.255.255.0
duplex auto
speed auto
no keepalive
interface Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/1
ip address 192.168.12.1 255.255.255.252
duplex full
speed 10
no keepalive
interface FastEthernet0/2/0
switchport access vlan 5
duplex half
speed 10
interface FastEthernet0/2/1
interface FastEthernet0/2/2
switchport access vlan 150
duplex full
speed 100
interface FastEthernet0/2/3
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/3/0:0
description ** London Megastream **
bandwidth 2048
ip address 192.168.11.1 255.255.255.252
interface Vlan1
no ip address
interface Vlan5
ip address 192.168.12.5 255.255.255.252
delay 150
interface Vlan150
ip address 192.168.150.1 255.255.255.248
router eigrp 12
redistribute connected
redistribute static
passive-interface GigabitEthernet0/0
passive-interface Serial0/3/0:0
network 10.0.0.0
network 192.168.12.0 0.0.0.3
network 192.168.12.4 0.0.0.3
no auto-summary
ip classless
ip route 10.10.0.0 255.255.0.0 172.16.2.253
ip route 10.11.0.0 255.255.0.0 192.168.11.2
ip route 172.30.1.0 255.255.255.0 192.168.150.2
ip route 172.31.1.0 255.255.255.0 192.168.150.2
ip route 192.168.100.0 255.255.255.0 172.16.2.253
ip route 192.168.100.59 255.255.255.255 192.168.150.2
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
access-list 10 permit 192.168.100.0 0.0.0.255
access-list 10 permit 10.10.0.0 0.0.255.255
access-list 10 permit 172.16.2.0 0.0.0.255
access-list 10 permit 192.168.12.0 0.0.0.255
access-list 10 permit 10.11.0.0 0.0.255.255
access-list 10 permit any
access-list 11 permit 172.16.2.239
control-plane
voice-port 0/1/0:15
cptone GB
ccm-manager redundant-host 172.31.1.250
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 172.31.1.250
ccm-manager config
mgcp
mgcp call-agent 172.30.1.250 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp default-package fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface Vlan150
mgcp bind media source-interface Vlan150
mgcp profile default
gateway
timer receive-rtp 1200
Hey there, if you look at the debug, 0x80AF is an ISDN cause code specifying that the Call Manager is complaining of this. It appears that it went out on channel 15 on the PRI. How many channels do you have allocated on the gateway as I believe E1 is 30 B and 1 D so if it is not busy, the first call should in theory go out on channel 30 as out of the box, CCM selects from the bottom up which is last to first.
Check to make sure your timeslots on the router is in synch with the telco.
pri-group timeslots 1-14,24 service mgcp (fractional example).
What does debug isdn q921 say?
Hey Kelvin, Q921 is L2 which where he is getting Q931 output means L2 is up. If he typed "sh isd stat" from CLI, he would see Multiple Frames Established which validates TEI.
459
