No outside calls going
Hello.
I have a problem.
No ouside outgoing calls go((( To call outside we use SIP server. But it shuts our calls because it goes from private call numbers! In debug I see:
VOICE_REG_POOL: No entry found in contact table
Sent:
INVITE sip:0444555146@77.91.129.66:5060 SIP/2.0
Via: SIP/2.0/UDP 109.237.89.11:5060;branch=z9hG4bK1EA21F51
Remote-Party-ID: "IT Otdel" <sip:2202001@109.237.89.11>;party=calling;screen=yes;privacy=off
From: "IT Otdel" <sip:2202001@77.91.129.66>;tag=93D7D14-1055
To: <sip:0444555146@77.91.129.66>
Date: Mon, 07 Oct 2013 08:11:25 GMT
Call-ID: E4E37E75-2E5E11E3-91DC83E6-6A2C4466@109.237.89.11
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0233110016-0000065536-0000000225-3355705866
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M1
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1381133485
Contact: <sip:2202001@109.237.89.11:5060>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 69
Session-Expires:  1800
Content-Length: 0
Config for dial-peer is:
dial-peer voice 100 voip
translation-profile incoming 1
translation-profile outgoing 2
destination-pattern .T
session protocol sipv2
session target sip-server
incoming called-number .
dtmf-relay rtp-nte
codec g711alaw
Please help.
15 Replies 15
Ayodeji Okanlawon
Please send the full debug. You can also attach it here. Also send your sh run
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Debug:
debug ccsip messages
Sent:
REGISTER sip:77.91.129.66:5060 SIP/2.0
Via: SIP/2.0/UDP 109.237.89.11:5060;branch=z9hG4bK1EA92309
To: <2399>
Date: Mon, 07 Oct 2013 08:11:49 GMT
Call-ID: EC80112A-2CF611E3-800983E6-6A2C4466
Max-Forwards: 70
Timestamp: 1381133509
CSeq: 784 REGISTER
Contact: <2399>
Expires:  3600
Supported: path
Content-Length: 0
003515: Oct  7 10:11:49.904 UTC+2: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 109.237.89.11:5060;branch=z9hG4bK1EAA21B7
To: <2102>
Call-ID: EC80AD52-2CF611E3-800A83E6-6A2C4466
Max-Forwards: 70
CSeq: 784 REGISTER
Contact: <2102>
Expires:  3600
Supported: path
Content-Length: 0
003516: Oct  7 10:11:49.908 UTC+2: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 109.237.89.11:5060;branch=z9hG4bK1EAB2430
To: <2302>
Call-ID: ECA23EAC-2CF611E3-800B83E6-6A2C4466
Max-Forwards: 70
CSeq: 784 REGISTER
Contact: <2302>
Expires:  3600
Supported: path
Content-Length: 0
003517: Oct  7 10:11:53.588 UTC+2: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 109.237.89.11:5060;branch=z9hG4bK1EA31872
To: <1001>
Date: Mon, 07 Oct 2013 08:11:53 GMT
Call-ID: EC795A41-2CF611E3-800383E6-6A2C4466
Max-Forwards: 70
Timestamp: 1381133513
CSeq: 784 REGISTER
Contact: <1001>
Expires:  3600
Supported: path
Content-Length: 0
003518: Oct  7 10:11:53.860 UTC+2: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 109.237.89.11:5060;branch=z9hG4bK1EA4AB9
To: <2301>
Call-ID: EC79F669-2CF611E3-800483E6-6A2C4466
Max-Forwards: 70
CSeq: 784 REGISTER
Contact: <2301>
Expires:  3600
Supported: path
Content-Length: 0
003519: Oct  7 10:11:53.880 UTC+2: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 109.237.89.11:5060;branch=z9hG4bK1EA51AA1
To: <2202>
Call-ID: EC7B2EB9-2CF611E3-800583E6-6A2C4466
Max-Forwards: 70
CSeq: 784 REGISTER
Contact: <2202>
Expires:  3600
Supported: path
Content-Length: 0
003520: Oct  7 10:11:53.888 UTC+2: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 109.237.89.11:5060;branch=z9hG4bK1EA636C
To: <2203>
Call-ID: EC7C67A2-2CF611E3-800683E6-6A2C4466
Max-Forwards: 70
CSeq: 784 REGISTER
Contact: <2203>
Expires:  3600
Supported: path
Content-Length: 0
003521: Oct  7 10:11:53.888 UTC+2: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 109.237.89.11:5060;branch=z9hG4bK1EA72653
To: <2201>
Call-ID: EC7D9FF2-2CF611E3-800783E6-6A2C4466
Max-Forwards: 70
CSeq: 784 REGISTER
Contact: <2201>
Expires:  3600
Supported: path
Content-Length: 0
003522: Oct  7 10:11:53.888 UTC+2: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 109.237.89.11:5060;branch=z9hG4bK1EA826F3
To: <2101>
Call-ID: EC7ED842-2CF611E3-800883E6-6A2C4466
Max-Forwards: 70
CSeq: 784 REGISTER
Contact: <2101>
Expires:  3600
Supported: path
Content-Length: 0
003523: Oct  7 10:11:53.900 UTC+2: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <2399>
Max-Forwards: 70
CSeq: 784 REGISTER
Contact: <2399>
Expires:  3600
Supported: path
Content-Length: 0
003524: Oct  7 10:11:53.904 UTC+2: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <2102>
Max-Forwards: 70
CSeq: 784 REGISTER
Contact: <2102>
Expires:  3600
Supported: path
Content-Length: 0
003525: Oct  7 10:11:53.908 UTC+2: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <2302>
Max-Forwards: 70
CSeq: 784 REGISTER
Contact: <2302>
Expires:  3600
Supported: path
Content-Length: 0
003526: Oct  7 10:11:56.816 UTC+2: VOICE_REG_POOL: No entry for (0444555146) found in contact table
003527: Oct  7 10:11:56.816 UTC+2: //11184/0DE4FA000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Remote-Party-ID: "IT Otdel" <2202001>;party=calling;screen=yes;privacy=off
To: <0444555146>
Date: Mon, 07 Oct 2013 08:11:56 GMT
Min-SE:  1800
CSeq: 101 INVITE
Timestamp: 1381133516
Contact: <2202001>
Expires: 180
Max-Forwards: 69
Content-Length: 0
Output from SIP server:
07 11:44:53] NOTICE[3375]: chan_sip.c:17045 handle_request_register: Registration from '<sip:2302@77.91.129.66>' failed for '109.237.89.11' - No matching peer found
[2013-10-
Hi.
As requested, can you please send a show runn and a full debug ccisp messages of a call.
Registration problem can be better analyzed with the running config.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Building configuration...
Current configuration : 59971 bytes
! Last configuration change at 10:39:54 UTC+2 Mon Oct 7 2013 by admin2
! NVRAM config last updated at 10:39:41 UTC+2 Mon Oct 7 2013 by admin2
version 15.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime
service password-encryption
service sequence-numbers
hostname cisco2901
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.152-4.M1.bin
boot system flash:c2900-universalk9-mz.SPA.151-2.T1.bin
boot-end-marker
logging buffered 51200
logging console critical
aaa new-model
aaa accounting connection default start-stop group radius
aaa accounting connection h323 start-stop group radius
aaa accounting system default start-stop group radius
aaa accounting resource default start-stop group radius
aaa session-id common
clock timezone UTC+2 2 0
clock summer-time sumkiev recurring last Sun Mar 4:00 last Sun Sep 4:00
no ip source-route
no ip bootp server
no ip domain lookup
ip cef
l2tp-class l2tpclass1
no ipv6 cef
stcapp ccm-group 1
stcapp feature access-code
stcapp feature speed-dial
stcapp supplementary-services
port 0/0/0
  fallback-dn 2201
port 0/0/1
  fallback-dn 2101
port 0/0/2
  fallback-dn 2399
port 0/0/3
  fallback-dn 2102
crypto pki trustpoint TP-self-signed-703877443
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-703877443
revocation-check none
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
ip address trusted list
  ipv4 77.91.129.66 255.255.255.255
  ipv4 10.x.x.x 255.255.255.255
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  registrar server
voice class codec 10
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice register global
mode cme
max-dn 200
max-pool 42
create profile sync 0380025834254157
voice translation-rule 1
rule 1 /2202001/ /2300/
rule 2 /2202005/ /2399/
rule 3 /2204115/ /2400/
rule 4 /2203134/ /2411/
voice translation-rule 2
rule 1 /2399/ /2202005/
rule 2 /.*/ /2202001/
voice translation-rule 3
rule 1 /\.*/ /0\1/
voice translation-rule 4
rule 1 /^38\.*/ /\1/
voice translation-profile 1
translate calling 3
translate called 1
voice translation-profile 2
translate calling 2
voice translation-profile 3
translate calling 2
translate called 4
ivr prompt memory 1024
ivr prompt streamed flash
application
service aa flash:its-CISCO.2.0.2.0.tcl
  param operator 2300
  paramspace english language en
  paramspace english index 1
  paramspace english location flash:
  paramspace english prefix en
  param aa-pilot 2202001
service altis_ivr flash:altis_ivr.vxml
vxml version 2.0
license udi pid CISCO2901/K9 sn FCZ1446904G
license boot module c2900 technology-package securityk9
hw-module pvdm 0/0
redundancy
ip tcp synwait-time 10
ip ssh version 2
track 1 ip sla 1 reachability
class-map match-all exhmap
match access-group name exchsync
class-map match-all Telepresence
class-map match-all exchmap2
match qos-group 1023
class-map match-all exchsyncmap
class-map match-all video
match protocol rtp video
class-map match-all databases
class-map match-all voice
match protocol rtp audio
policy-map wanpolicy
class exchmap2
  police cir 10000000 conform-action transmit  exceed-action drop
policy-map OUTPUT
class voice
  priority 10000
class class-default
  fair-queue
policy-map exchpol
class exhmap
  set qos-group 1023
policy-map QoSforTP
class Telepresence
  priority 1000
class databases
class class-default
gw-accounting aaa
acct-template callhistory-detail
bridge irb
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Loopback1
ip address 1.1.1.2 255.255.255.255
interface Loopback2
ip address 1.1.1.3 255.255.255.255
interface Tunnel0
description KACHAVOVA MAIN TUNNEL
ip address 192.168.3.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
load-interval 30
qos pre-classify
tunnel source GigabitEthernet0/0.52
tunnel destination x.x.x.x
service-policy output wanpolicy
interface Tunnel1
description TO KACHALOVA BY TRANSBUD
ip address 192.168.6.1 255.255.255.252
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1400
shutdown
qos pre-classify
interface Tunnel2
description LVIV
ip address 192.168.10.1 255.255.255.0
interface Tunnel3
description sec
ip address 192.168.15.1 255.255.255.0
interface Tunnel4
description TEMP_GRE_TO_K5v_SERVERS
ip address 192.168.16.1 255.255.255.0
ip nat inside
shutdown
interface Embedded-Service-Engine0/0
no ip address
shutdown
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
no ip address
ip access-group wanin in
ip access-group extlist1out out
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip flow egress
load-interval 30
duplex auto
speed auto
no mop enabled
service-policy output OUTPUT
interface GigabitEthernet0/0.51
description isp1
encapsulation dot1Q 51
ip address x.x.x.x 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat outside
no cdp enable
interface GigabitEthernet0/0.52
description isp2
encapsulation dot1Q 52
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat outside
no cdp enable
interface GigabitEthernet0/1
no ip address
load-interval 30
duplex auto
speed auto
interface GigabitEthernet0/1.10
encapsulation dot1Q 10
ip address 10.2.1.254 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
no cdp enable
interface GigabitEthernet0/1.20
encapsulation dot1Q 20
ip address 10.2.2.1 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
no cdp enable
interface GigabitEthernet0/1.30
encapsulation dot1Q 30
ip address 10.2.3.1 255.255.255.0
ip access-group guestwifi in
ip access-group guestwifi out
ip flow ingress
ip flow egress
ip nat inside
no cdp enable
interface GigabitEthernet0/1.40
encapsulation dot1Q 40
ip address 10.2.4.254 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
no cdp enable
service-policy input exchpol
interface GigabitEthernet0/1.41
encapsulation dot1Q 41
ip address 10.2.41.1 255.255.255.0
no cdp enable
bridge-group 41
bridge-group 41 spanning-disabled
interface GigabitEthernet0/1.57
encapsulation dot1Q 57
ip address 10.2.57.254 255.255.255.0
ip access-group arch in
ip access-group arch out
ip nat inside
no cdp enable
interface GigabitEthernet0/1.70
encapsulation dot1Q 70
ip address 10.2.7.1 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
no cdp enable
interface GigabitEthernet0/1.80
encapsulation dot1Q 80
ip address 10.2.8.1 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
no cdp enable
interface GigabitEthernet0/1.90
encapsulation dot1Q 90
ip address 10.2.9.1 255.255.255.0
ip nat inside
no cdp enable
interface GigabitEthernet0/1.100
encapsulation dot1Q 100
ip address 10.2.10.1 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
no cdp enable
interface GigabitEthernet0/1.101
encapsulation dot1Q 101
ip address 10.2.11.1 255.255.255.0
ip nat inside
no cdp enable
interface GigabitEthernet0/1.110
encapsulation dot1Q 110
ip address 10.2.110.1 255.255.255.0
ip access-group pilad110 in
ip access-group pilad110 out
ip flow ingress
ip flow egress
ip nat inside
no cdp enable
interface GigabitEthernet0/1.120
description vcs
encapsulation dot1Q 120
ip address 10.2.120.254 255.255.255.0
ip nat inside
no cdp enable
interface GigabitEthernet0/1.252
encapsulation dot1Q 252
ip address 10.2.252.254 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
no cdp enable
interface GigabitEthernet0/1.253
encapsulation dot1Q 253
ip address 10.2.253.254 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
no cdp enable
interface GigabitEthernet0/1.254
encapsulation dot1Q 254
ip address 10.2.254.254 255.255.255.0
ip nat inside
no cdp enable
interface GigabitEthernet0/1.999
encapsulation dot1Q 999
ip address 10.2.99.1 255.255.255.0
ip access-group siemens in
ip access-group siemens out
ip nat inside
no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-export version 5
ip flow-export destination 10.2.4.50 8818
ip flow-top-talkers
top 50
sort-by bytes
cache-timeout 10
match protocol tcp
no cdp run
route-map isp2 permit 10
match ip address natlist
match interface GigabitEthernet0/0.52
route-map isp1 permit 10
match interface GigabitEthernet0/0.51
route-map nonat permit 10
match ip address 198
snmp-server view viewtemp ciscoEnvMonTemperatureStatusEntry.3 included
snmp-server community qwerty view viewtemp RO
snmp-server enable traps entity-sensor threshold
radius-server host 10.2.4.51 auth-port 1812 acct-port 1813
radius-server key 7 011204075F
radius-server vsa send cisco-nas-port
radius-server vsa send accounting
radius-server vsa send authentication
control-plane
bridge 41 protocol ieee
bridge 41 route ip
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp profile default
sccp local GigabitEthernet0/1.40
sccp ccm 10.2.4.200 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/1.40
associate ccm 1 priority 1
associate profile 1 register XCODE123456
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 6
associate application SCCP
dial-peer voice 1 voip
destination-pattern [2-9]......
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 2 voip
destination-pattern 0[1-9]........
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 3 voip
destination-pattern 0800.......
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 101 voip
destination-pattern 2444
session target ipv4:10.2.4.200
dial-peer voice 102 voip
translation-profile outgoing 4
destination-pattern 38..........
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 108 voip
destination-pattern 0332......
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 10 pots
destination-pattern 2201
port 0/0/0
no sip-register
dial-peer voice 11 pots
destination-pattern 2101
port 0/0/1
no sip-register
dial-peer voice 12 pots
destination-pattern 2399
port 0/0/2
no sip-register
dial-peer voice 13 pots
destination-pattern 2102
port 0/0/3
no sip-register
dial-peer voice 111 voip
destination-pattern 2331
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 4 voip
destination-pattern 2400
session target ipv4:10.2.4.203
dtmf-relay rtp-nte
dtmf-interworking rtp-nte
codec g711alaw
dial-peer voice 5 voip
destination-pattern 2411
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 113 voip
destination-pattern 1000
session target ipv4:10.2.4.120
dtmf-relay rtp-nte
codec g711alaw
gateway
timer receive-rtp 1200
sip-ua
credentials number xxxx username xxxx password 7 xxxx realm asterisk
authentication username xxxx password 7 xxxx
registrar ipv4:77.91.129.66 expires 3600
sip-server ipv4:77.91.129.66
gatekeeper
shutdown
telephony-service
sdspfarm units 1
sdspfarm transcode sessions 16
sdspfarm tag 1 XCODE123456
video
  maximum bit-rate 2000
max-ephones 11
max-dn 11
ip source-address 10.2.3.1 port 2000
service phone videoCapability 1
cnf-file location flash:
max-conferences 8 gain -6
moh "flash0:moh.au"
transfer-system full-consult
transfer-pattern 2555
transfer-pattern 2...
transfer-pattern 2777
transfer-pattern 2304
transfer-pattern 0952810902
transfer-pattern 3134
shutdown
ephone-dn  1
number 1001
ephone-dn  2
number 2301
ephone-dn  3
number 2202
ephone-dn  4  octo-line
number 2203
ephone-dn  5  octo-line
number 2201
ephone-dn  6  octo-line
number 2101
ephone-dn  7  octo-line
number 2399
ephone-dn  8  octo-line
number 2102
ephone-dn  9
number 2302
ephone  1
mac-address 0019.E8F2.7E3B
button  2:2
ephone  2
mac-address 8478.ACE6.3343
button  1:1
ephone  3
video
mac-address F04D.A2CA.F807
button  1:3
ephone  4
mac-address F0DE.F15F.2222
button  1:4
ephone  5
mac-address 1FE7.8944.8000
max-calls-per-button 2
type anl
button  1:5
ephone  6
mac-address 1FE7.8944.8001
type anl
button  1:6
ephone  7
mac-address 1FE7.8944.8002
type anl
button  1:7
ephone  8
mac-address 1FE7.8944.8003
type anl
button  1:8
ephone  9
mac-address 0004.F2F0.C5FF
button  1:9
banner exec ^C
exe^C
banner login ^C
hellow ^C
line con 0
exec-timeout 100 0
logging synchronous
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
exec-timeout 300 0
privilege level 15
logging synchronous
transport input ssh
line vty 5
access-class 23 in
exec-timeout 300 0
privilege level 15
transport input ssh
line vty 6 15
access-class 23 in
privilege level 15
transport input telnet ssh
scheduler allocate 20000 1000
ntp master
ntp server 78.152.160.1
time-range savchuk
periodic daily 18:30 to 22:00
time-range worktime
periodic weekdays 8:00 to 19:00
end
looking a your logs, Your registrar is not responding to your registration requests..You need to fix that first. I believe it may have something to do with your NAT config. They may not be receiving your requests. speak to them and find out why they are not responding to your registration requests
The problem is that SIP server does not register my cisco router. All my requests are gone with number. But as I was informed from provider they register clients by username and password. But my sip-ua config does not work and my router continue sending phone number as username(((
[2013-10-
- here you can see it
Hi.
You are sendig number as authentication username.
sip-ua
Try  credentials username user password password realm asterisk
Carlo
The registration requests are sent out correctly. It looks like the sip server doent like the ip that the requests are coming from..109.237.89.11...Is that the IP your telco expects traffic on?
I used with and without number. In case with number the registration is successful but for 30 seconds. Than private numbers are instead of username for sip trunk and I got rejection again(((
Sorry exactly 180 sec and than all private numbers try to register.
So, what I have. The initial registration is successful. But after nearby 180 sec or 120 sec all my private numbers try to register with sip server. My Sip ua config now is:
sip-ua
I also noticed that on cisco I have:
cisco2901#sh run | s telephony
telephony-service
sdspfarm units 1
video
max-ephones 11
max-dn 11
moh "flash0:moh.au"
shutdown
And
ephone-dn  1
number 1001
ephone-dn  2
number 2301
ephone-dn  3
number 2202
number 2203
number 2201
number 2101
number 2399
number 2102
ephone-dn  9
number 2302
Thay all try to register with server! What is going on?
[2013-10-07 14:05:35] NOTICE[3375]: chan_sip.c:17045 handle_request_register: Registration from '<sip:1001@77.91.129.66>' failed for '109.237.89.11' - No matching peer found
[2013-10-07 14:05:35] NOTICE[3375]: chan_sip.c:17045 handle_request_register: Registration from '<sip:2101@77.91.129.66>' failed for '109.237.89.11' - No matching peer found
[2013-10-07 14:05:35] NOTICE[3375]: chan_sip.c:17045 handle_request_register: Registration from '<sip:2102@77.91.129.66>' failed for '109.237.89.11' - No matching peer found
[2013-10-07 14:05:35] NOTICE[3375]: chan_sip.c:17045 handle_request_register: Registration from '<sip:2201@77.91.129.66>' failed for '109.237.89.11' - No matching peer found
[2013-10-07 14:05:35] NOTICE[3375]: chan_sip.c:17045 handle_request_register: Registration from '<sip:2202@77.91.129.66>' failed for '109.237.89.11' - No matching peer found
[2013-10-07 14:05:35] NOTICE[3375]: chan_sip.c:17045 handle_request_register: Registration from '<sip:2203@77.91.129.66>' failed for '109.237.89.11' - No matching peer found
[2013-10-07 14:05:35] NOTICE[3375]: chan_sip.c:17045 handle_request_register: Registration from '<sip:2301@77.91.129.66>' failed for '109.237.89.11' - No matching peer found
[2013-10-07 14:05:35] NOTICE[3375]: chan_sip.c:17045 handle_request_register: Registration from '<sip:2302@77.91.129.66>' failed for '109.237.89.11' - No matching peer found
[2013-10-07 14:05:35] NOTICE[3375]: chan_sip.c:17045 handle_request_register: Registration from '<sip:2399@77.91.129.66>' failed for '109.237.89.11' - No matching peer found
