No PSTN Calls using SRST on a Cisco 2851 IOS 15.1 CUCM 8.0.3
                   Hi All,
Can anyone help with this at all?
We have set up SRST fallback on our CUCM 8.0.3 in our lab. we have a both SIP and SCCP phone registered to CUCM and the endpoints fallback to the gateway as required and they can all call between each other.
The problem I have is there are no external calls able to be made.
The gateway is actually the MGCP gateway that CUCM uses to dial out to the E1 trunk via the BT ISDN30 and when CUCM is up I can make calls to PSTN all day long but the moment CUCM is down and the phones fallback to SRST its only internal calls.
Here is some of my configuration;
You can see here this is how call manager fallback is setup;
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.1.31.10 port 2000
max-ephones 20
max-dn 50
sip-ua
retry invite 3
retry register 3
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729br8
codec preference 4 g729r8
codec preference 5 g722-64
codec preference 6 g722-56
codec preference 7 g722-48
controller E1 0/3/0
pri-group timeslots 1-31 service mgcp
description E1 to PSTN for Cisco CUCM-8 BT Line
interface Serial0/3/0:15
description Used for PSTN on CUCM8 PSTN
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
dial-peer voice 10 pots
destination-pattern 0T
direct-inward-dial
port 0/3/0:15
forward-digits all
SBCISCOGW81#
SBCISCOGW81#
*Jun 22 10:40:14.647: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=01992706568, Called Number=01992706568, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=01992706568
   Result=Success(0) after DP_MATCH_DEST
*Jun 22 10:40:14.647: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=01992706568, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
*Jun 22 10:40:14.647: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=10
*Jun 22 10:40:14.647: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=4313, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=40002
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
*Jun 22 10:40:14.647: //-1/7C34AD26849D/DPM/dpAssociateIncomingPeerCore:
   Calling Number=4313, Called Number=01992706568, Voice-Interface=0x0,
*Jun 22 10:40:14.647: //-1/7C34AD26849D/DPM/dpMatchSafModulePlugin:
*Jun 22 10:40:14.655: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=01992706568, Peer Info Type=DIALPEER_INFO_SPEECH
*Jun 22 10:40:14.655: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=01992706568, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
*Jun 22 10:40:14.655: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Jun 22 10:40:14.659: //-1/7C34AD26849D/DPM/dpMatchPeersCore:
*Jun 22 10:40:14.659: //-1/7C34AD26849D/DPM/dpMatchSafModulePlugin:
*Jun 22 10:40:14.659: //-1/7C34AD26849D/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Jun 22 10:40:14.659: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Jun 22 10:40:14.663: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Jun 22 10:40:14.663: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Jun 22 10:40:14.663: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=01992706568, Called Number=, Voice-Interface=0x0,
   Result=NO_MATCH(-1) After All Match Rules Attempt
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
*Jun 22 10:40:14.663: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Jun 22 10:40:14.663: //-1/7C34AD26849D/DPM/dpMatchPeersCore:
*Jun 22 10:40:14.663: //-1/7C34AD26849D/DPM/dpMatchSafModulePlugin:
*Jun 22 10:40:14.663: //-1/7C34AD26849D/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
no ip address
encapsulation hdlc
no cdp enable
And then this Dial Peer;
direct-inward-dial
port 0/3/0:15
forward-digits all
This is the output from DEBUG VOICE DIALPEER when I dial the number from the phone;
It looks like it is matching the dial-peer but no call is being made;
SBCISCOGW81#
SBCISCOGW81#
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
Any help or advice I've appreciate it very much so.
2 ACCEPTED SOLUTIONS
VIP Super Bronze
Usually you get this when you are in a glare condition. This mean that both side of the circuit, i.e you ane your provider are using the same channel allocation direction. Lets change your channel order and see if it helps.
conf t
isdn bchan-number-order ascending.
Please send debug isdn q931 again.
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
Ok you need to know which number to mach what DDI to.
to match 449861 to 4561 and 449860 to 4313, do this.
conf t
voice translation-rule 1
rule 1 /^449861/ /4561/
rule 2 /^449860/ /4313/
voice translation-profile SRSTIN
translate called 1
dial-peer voice 9999 pots
incoming called number .
direct-inward-dial
translation-profile incoming SRSTIN
VIP Super Bronze
Re: No PSTN Calls using SRST on a Cisco 2851 IOS 15.1 CUCM 8.0.3
Try this on your gateway
Conf t
application
global
service alternate default
Enable "debug isdn q931"
Do a test call and send the output of debug
Thanks for your reply.
I have entered those commands but nothing has changed.
I have also enabled the debug isdn q931 but nothing is outputting.
I am getting the same output in debug voice dialpeer again too.
VIP Super Bronze
Can you send a sh run ..please attach in a text file.
can you also send a "sh isdn status" while in SRST.
Hey,
Config is attached, the debug is at the bottom of the txt file.
VIP Super Bronze
Joe,
Looking at the output of sh isdn status.
SBCISCOGW81#sh isdn status
Global ISDN Switchtype = primary-net5
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/3/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-net5
        L2 Protocol = Q.921 0x0000  L3 Protocol(s) = CCM MANAGER 0x0003
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x00000000
    Number of L2 Discards = 0, L2 Session ID = 0
    Total Allocated ISDN CCBs = 0
We can see that layer 1 is down in SRST.
Can you do this please. add the ff: command
ccm-manager fallback-mgcp.
I will suggest to put the system back to normal operation  after adding the command and then simualte SRST again
Configure
Hey,
Ok so I still am unable to make external calls but since adding that ccm-manager fallback-mgcp the layer 1 on the PRI is active now
This is what I get what I do debug isdn Q921
SBCISCOGW81#
*Jun 22 12:09:53.547: ISDN Se0/3/0:15 Q921: User RX <- RRp sapi=0 tei=0 nr=4
*Jun 22 12:09:53.547: ISDN Se0/3/0:15 Q921: User TX -> RRf sapi=0 tei=0 nr=4
*Jun 22 12:09:57.131: ISDN Se0/3/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=4 nr=4
*Jun 22 12:09:57.155: ISDN Se0/3/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=5
*Jun 22 12:09:57.207: ISDN Se0/3/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=4 nr=5
*Jun 22 12:09:57.211: ISDN Se0/3/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=5
and this is debug isdn q931
*Jun 22 12:13:03.871: ISDN Se0/3/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 4313
*Jun 22 12:13:03.871: ISDN Se0/3/0:15 Q931: Sending SETUP  callref = 0x0086 callID = 0x8007 switch = primary-net5 interface = User
*Jun 22 12:13:03.871: ISDN Se0/3/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0086
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Calling Party Number i = 0x0180, '4313'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0x81, '01992706568'
*Jun 22 12:13:03.951: ISDN Se0/3/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8086
        Cause i = 0x82AC - Requested circuit/channel not available
attached is the output from debug voice ccapi.
VIP Super Bronze
conf t
Thank you very much this now dials outside
This is the debug output;
*Jun 22 12:33:19.911: ISDN Se0/3/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 4313
*Jun 22 12:33:19.911: ISDN Se0/3/0:15 Q931: Sending SETUP  callref = 0x0089 callID = 0x800A switch = primary-net5 interface = User
*Jun 22 12:33:19.911: ISDN Se0/3/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0089
                Standard = CCITT
        Channel ID i = 0xA98381
                Exclusive, Channel 1
*Jun 22 12:33:20.103: ISDN Se0/3/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8089
*Jun 22 12:33:20.351: ISDN Se0/3/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8089
*Jun 22 12:33:32.011: ISDN Se0/3/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8089
        Progress Ind i = 0x8582 - Destination address is non-ISDN
*Jun 22 12:33:32.011: %ISDN-6-CONNECT: Interface Serial0/3/0:0 is now connected to 01992706568 N/A
*Jun 22 12:33:32.011: ISDN Se0/3/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0089
*Jun 22 12:33:38.595: ISDN Se0/3/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8089
        Cause i = 0x8590 - Normal call clearing
        Progress Ind i = 0x8288 - In-band info or appropriate now available
*Jun 22 12:33:38.595: %ISDN-6-DISCONNECT: Interface Serial0/3/0:0  disconnected from 01992706568 , call lasted 6 seconds
*Jun 22 12:33:38.595: ISDN Se0/3/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x800A
*Jun 22 12:33:46.155: ISDN Se0/3/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x0089
*Jun 22 12:33:46.211: ISDN Se0/3/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8089
                Standard = CCITT
Super Bronze
Hi Guys
The other common cause of 'Requested circuit/channel not available' is that you may have provisioned a fractional E1. For example 8 or 16 channels... in that scenario you have only the first x channels so the default of using the top channel for outbound isn't suitable.
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Oh yes I totally understand now! Well many thanks for your help both of you.
What would I need to do to configure this to accept incomming calls to a DDI?
Joe
VIP Super Bronze
In SRST?
You need to know how many digit your telco is sending and then configure translation profile to change the sent DDI to internal extension. Do a test call for incoming DDI. Send the output of debug isdn q931. Let me know what the internal number the DDI should macth and we can configure a xlation rule to match it
Yes my friend in SRST mode.
Outbound calls are working lovely now
This is the output when I try to dial inbound; The called party number is highlighted in bold text. the DDI's I am using are 4561, and 4313. 449860 is one DDI from the service provider and 449861 isd another. altogether I think we have 8 of them for testing in our labs but we will only use 449860 and 449861. with the area code the whole number will be 01992 44986X
*Jun 22 13:05:10.375: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0001
        Sending Complete
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
        Progress Ind i = 0x8583 - Origination address is non-ISDN
        Calling Party Number i = 0x2181, '1992706568'
                Plan:ISDN, Type:National
        Called Party Number i = 0x81, '449860'
*Jun 22 13:05:10.375: ISDN Se0/3/0:15 Q931: Received SETUP  callref = 0x8001 callID = 0x0002 switch = primary-net5 interface = User
*Jun 22 13:05:10.391: ISDN Se0/3/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8001
*Jun 22 13:05:10.391: ISDN Se0/3/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x8001
        Cause i = 0x8081 - Unallocated/unassigned number
*Jun 22 13:05:10.575: ISDN Se0/3/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x0001
*Jun 22 13:05:10.575: ISDN Se0/3/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8001
Many thanks for your help so far
VIP Super Bronze
conf t
translate called 1
direct-inward-dial
Thank you very much Sir,
this is now working how I want it to. really, many thanks for your help you have been fantastic!
VIP Super Bronze
Hey Joe, No sirs here. We are all buddies! Glad to help.
2318
