no Q921 or Q931 result on outgoing calls
I have customer which I installed about a month ago. It is a SRST site hanging of a Callmanager 5.1 cluster. We had some issue getting them working, but it was running fine since then, untill now. they have 3 bri interfaces. it does not matter if I configure it for H323 or MGCP, I only get incoming debugs. Nothing outgoing. It is as if the calls never even reach the Gateway. This is the same for q931 and Q921. An ideas?
1 REPLY
Hall of Fame Super Gold
Re: no Q921 or Q931 result on outgoing calls
Are these lines in hunt? Have you set isdn static-tei 0 ?
111
