no register e164 with IP Phone ?
Is it possible to specify dial-peer voip to unregistered its E.164-ID onto the GK ?
Wit pots there is no register e164 command but nothing with voip dial-peer.
Bregards
Olivier
1 ACCEPTED SOLUTION
Re: no register e164 with IP Phone ?
Hi Olivier,
The no-reg keyword used with the number command on the ephone-dn should do it.
Also try executing a show telephony-service dial-peer command. You should notice that that dial-peers created based on your phones registering with CME are actually POTS dial peers.
Michael.
Hello Olivier,
It is not possible because voip dial-peers should not register E.164-ID to the gatekeeper. Are you finding otherwise?
You're true mowuor.
in fact this is the ephone that are configured on my CME that are registered on my GK.
any idea ?
Olivier
Hi Olivier,
Michael.
Bronze
Hi Olivier,
The purpose of the "no register e164" command on a pots dial-peer is to de-register the E.164 number of a directly connected FXS device from the GK. If you have a directly connected IP phone (if you are using SRST or CME) you can deregister the E164 number from a gatekeeper as follows.
conf t
ephone-dn x
number xxxx no-reg primary
Hope this helps, please rate if it does.
Dave
Right, but how it's possible to suppress E 164 GK registering from all the pots dial-peer (20002,20004,20006 and so on...) ??
CCME#show telephony-service dial-peer
dial-peer voice 20001 pots
destination-pattern 1001$
no e164 registration
huntstop
progress_ind setup enable 3
port 50/0/1
dial-peer voice 20002 pots
destination-pattern 604701001$
huntstop
port 50/0/1
dial-peer voice 20003 pots
destination-pattern 1002$
huntstop
port 50/0/2
dial-peer voice 20004 pots
destination-pattern 604701002$
huntstop
port 50/0/2
dial-peer voice 20005 pots
destination-pattern 1003$
huntstop
port 50/0/3
dial-peer voice 20006 pots
destination-pattern 604701003$
huntstop
port 50/0/3
dial-peer voice 20007 pots
destination-pattern 1004$
huntstop
port 50/0/4
dial-peer voice 20008 pots
destination-pattern 604701004$
huntstop
port 50/0/4
dial-peer voice 20011 pots
destination-pattern 1005$
huntstop
port 50/0/5
dial-peer voice 20012 pots
destination-pattern 604701005$
huntstop
port 50/0/5
dial-peer voice 20013 pots
destination-pattern 1095$
huntstop
port 50/0/95
dial-peer voice 20014 pots
destination-pattern 604701095$
huntstop
port 50/0/95
dial-peer voice 20015 pots
destination-pattern 1096$
huntstop
port 50/0/96
dial-peer voice 20016 pots
destination-pattern 604701096$
huntstop
port 50/0/96
dial-peer voice 20017 pots
destination-pattern 1097$
huntstop
port 50/0/97
dial-peer voice 20018 pots
destination-pattern 604701097$
huntstop
port 50/0/97
dial-peer voice 20019 pots
destination-pattern 1098$
huntstop
port 50/0/98
dial-peer voice 20020 pots
destination-pattern 604701098$
huntstop
port 50/0/98
dial-peer voice 20021 pots
destination-pattern 1099$
huntstop
port 50/0/99
dial-peer voice 20022 pots
destination-pattern 604701099$
huntstop
port 50/0/99
CCME#
it's ok I have found
telephony-service
dialplan-pattern 1 60470.... extension-length 4 no-reg
thanks
Olivier
1728
