No ringback and no-way audio
CM 6 with MGCP gateway with two PRIs. Calls get completed but no ringback and no audio.
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-select 1 T1 0/0/0
network-clock-select 2 T1 0/1/0
isdn switch-type primary-ni
voice call send-alert
voice rtp send-recv
voice-card 0
dspfarm
dsp services dspfarm
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
Re: No ringback and no-way audio
Add the following under dial-peer pots:
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
Silver
No need to add the above config as you're using mgcp not h323. Anyway, is there a firewall involved in this setup at all? You could be dropping RTP packets (udp ports 16384-32xxx, sorry can't remember them off the top of my head). Either that or a routing issue. Can you Ping any of your ip phones from your voice gateway?
Connectivity is fine and no packet loss.
Try this:
mgcp behavior g729-variants static-pt
mgcp behavior dynamically-change-codec-pt disable
I think you may be hitting this issue:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsy10653
hth,
nick
239
